Question about Lexmark X4550 InkJet Printer
My lexmark x4550 will not load paper at all - Lexmark X4550 InkJet Printer
  • jplongford May 09, 2009
    Paper pulls in then print run starts but paper doesn't feed through. Can't see any paper jam.
  • 535 Answers
Hello
u have to need chak your printer gare box or roller u have to change the roller becose of due furicsion roller has been damged its cant pick up papaer so u nyour printer roller eed to change
Posted on Jan 09, 2009
Is that "change the gear box?"   and " change the friction roller?"
Posted on May 09, 2009
I have a paper jam in the printer lexmark x4550 and don't know how to get to it
If you're having trouble getting the paper jam from the feeder, you can open the cartridge area. You should be able to get a better hold of jammed paper out from there.
Apr 11, 2011 | Lexmark X4550 InkJet Printer
Grepipwilko I need a disc to load my x4550,I.ve mislaid it since xmas.can,t find it anywhere.have just bought another...
You can download the Lexmark X4550 from the Lexmark website for free using this link Lexmark X4550 Drivers. Select your operating system by clicking on change OS.
Then click on FILTER.
Click on the Complete Driver under Recommended Downloads. Download, execute the file and follow the instructions on the software. Hope this helps. Thanks.
Jan 11, 2011 | Lexmark Inkjet Z517 Photo Printer
Why does my paper jam half way as it tends to
I had this problem till I started using heavier weight paper. My wife was buying the cheap really thin paper and it was no end of trouble.
May 27, 2010 | Lexmark X4550 InkJet Printer
My Lexmark x4550 printer is not working . How can
Try uninstalling and installing the drivers again making sure you PC is talking to the printer correctly. See if this helps. Try to setup the printer from scratch.
Apr 11, 2010 | Lexmark X4550 Multifunction Wireless Color...
Where do I load the paper?
Here is a link to the User's Guide of the printer. Page 34 will show you exactly how to load paper and the different types of papers that you can use.
http://bit.ly/cVcVYr
Jan 28, 2010 | Lexmark X4550 Multifunction Wireless Color...
Paper does not feed into printer
Printer Lexmark X4550 not taking paper, (Quick Fix)
Hi, yes my printer had the same problem with the pick up rollers not taking paper,
and thought it would be a simple job to adjust the springs inside the printer? But no, I could not find to open the printer. So I devised a simple modification using a
thin flat spring I had taken from an old windscreen wiper blade. see instructions
Good luck, bigvern
Jan 10, 2010 | Lexmark X4550 Multifunction Wireless Color...
Hi, i have a lexmark x4550. The pick up roller (the roller that grabs the paper and feeds it into the printer to get printed on), is not working, at least one of them isnt (there are two i think,,, but on...
Try the following: take an A4 sheet of paper and glue a 2 - inch strip of sanding paper onto the top of the sheet (full width of the page). sanding paper should be about 120 grain.
Now feed the page with the sand paper first (rough surface on top) into the paper inlet. grab and hold the paper, then press paper feed or send a print job. The printer tries to feed you special sheet, but you won't let go. This will sand off the gunk from you feed rollers and give a bit of rough surface to the rubber. Repeat if needed, it should cure the problem.
This works if the problem is the roller surface, it will not fix a problem with misalignment or a missing/broken spring in the feed roller mechanism.
regards, the perfessa
Aug 23, 2009 | Lexmark X4550 Multifunction Wireless Color...
Lexmark X4550 - paper jam
My Lexmark did the same thing-if you can get in at the rollers to clean them that might help.
Jun 09, 2009 | Lexmark X4550 InkJet Printer
Paper being fed crooked on my lexmark x4550 printer
Make sure your printer trays are lined up properly for the paper size you are loading.
May 10, 2009 | Office Equipment & Supplies
Paper jam in the lexmark x4550
If you know someone who is handy with this kind of stuff, you should get them to open the printer up and remove the paper. You could also try to just send sheets of paper through to see if they can dislodge it (but that may cause paper jams as well).
Apr 11, 2009 | Lexmark X4550 Multifunction Wireless Color...
Lexmark X4550 InkJet Printer Logo
317 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
