Home | Ulead | Videostudio 8 for PC | EasyCAP Video Ada...
Ulead Videostudio 8 for PC
Problem for Ulead Videostudio 8 for PC
EasyCAP Video Adapter with no video
By p_w_newton on Jan 09, 2009
I am having a problem with the EasyCap USB video capture modules that I have purchased. The problem is below and any help you can offer would be helpful
The Syntek STK1160 driver has installed OK and there are no errors in
the device manager.
I have installed the Ulead Video Studio program that came with the
EasyCap.
The problem is when I try to capture composite video from a video
camera I don't get anything displayed on the screen, it's as though
I don't have it connected to a video source. I get the same results
using the S-Video source as well.
I also have a Belkin dvice of the same type and that works OK on both
composite and S-Video using the Ulead Video Studio program that came with the EasyCap
Any Ideals
Same Problem
May 20, 2009
-   I have the same problem. No video, except mine is intermittent. Have had for three months. Used it last night for 2.5 hrs- worked fine. Next day, no video. Im thinking its the capture unit, but not for sure. Any fixes?-   smokintdi
Mar 04, 2009
-   I have the same exact problem. I'm using XP pro sp3. I've tried installing the driver several different ways, but nothing works. -   Guest
Feb 14, 2009
-   Same problem no picture, no sound, all drivers ay they are working and installed correctly. ?-   rljc14
Feb 03, 2009
-   I have the same problem, i purchased mine off ebay, it worked ok for the first couple of times, now it will not work at all even after re installing the software a number of times, i also tried a system restore but nothing seems to work, i now wish i had never wasted my money, it's a complete load of ****.-   swiftnick69
Jan 25, 2009
-   Everything installed, driver is good. does not work at all. Is this thing ****, please tell me so I will stop trying and move on to something better.
No video, no sound, as if nothing is connected. Please help.
-   ibrw1
Best Solution
posted on May 20, 2009
Helpful)
smokintdi
Rank: Guide
Rating: 91%, 4 votes
Ok, here is what is going on. The default video setting in control panel> scanners and cameras> syntek 1160 is pal-b it should be NTSC_M. Right click on the Syntek 1160 and click Video Decoder Property. Change it to NTSC_M from Pal. Do this with the unit plugged in or it wont be displayed in the Scanners/Cameras options box. Right away the signal line should rear 1 from 0 with video hooked up. Keeping that setting to stay is my issue right now. I was so excited to figure it out, I had to post. I was about ready to throw the unit away. Its a program driver error. Hope this helps!!!
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #2
posted on Jun 19, 2009
Not Rated)
aj-styles
Rank: Apprentice
Rating: 0%, 0 votes
when i go to scanners and cameras i dont see syntec 1160?
Was this helpful?
Yes
No
Popular Solutions for Ulead Videostudio 8 for PC
Questions and Unsolved Problems for Ulead Videostudio 8 for PC
Do you recommend Ulead Videostudio 8 for PC?
Answer
Answer
I use EasyCap Video Adapter with Audio I connect My VHS Player output to easycap, the Ulead... (More)
Answer
having trouble getting audio with capture of the video what am i doing wrong
Answer
Hello I have a ezcap usb grabber I am running vista and installed the drivers as well as... (More)
Answer
Can not run VideoStudio 12(X2) after clean installation. Click on ico and get try and buy screen and... (More)
Answer
after installation the green light do not work and trying to discharge I see nothing
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Ulead Videostudio 8 for PC:
Top Graphics Pub... Experts
Rank: Guru Guru
Solutions: 437
Experience: Experienced a lot in computer troubleshooting. Knowledgeable about cellular phones.
Ask Me
Find more Graphics Pub... Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
