Question about Dewalt 18 Volt Compact Drill Kit
Chuck will not open just spins on shaft how can I repair this? Its a dc925.
  • David Ford
    David Ford May 11, 2010
    Is the tool selector midway between high/low? Or is the motor/gearbox stationary and the chuck collar spinning freely not engaging the jaws
  • 3 Answers
Replace 629828-00 chuck & spindle assy
Posted on Feb 16, 2009
How to remove keyless chuck
open the chuck right up and look for a Phillips headed screw at the bottom. This is a left handed screw which means that you will have to turn it in the direction as if you are doing it up to undo it. On the shaft there may be a flat section on the drive shaft that you can use a spanner on to hold the shaft and use a pair of multigrips undo the chuck normally. If there is no place you can hold the shaft you may have to take the front of the drill off to get to the shaft so you can hold it there.
Jun 19, 2013 | Dewalt 18v Battery Hammer Drill Dcd950...
Removing chuck from dewalt dcd925
open chuck and look in the bottom of it (chuck)there is probably a screw there. think it will be left hand thread
Oct 25, 2012 | Dewalt 18v Battery Hammer Drill Dcd950...
Dewalt dc925 drill, the chuck jaws appear to be jammed tight shut and will not open. any ideas?
Hi, soak the chuck in crc overnight then put the drill in low speed and reverse. Hold the chuck by hand or with multi grips and pull the trigger. Hope this helps, regards Phil.
Jul 23, 2011 | Dewalt 18v Battery Hammer Drill Dcd950...
How do I take a bit out?
It is a keyless chuck. Put the drill in reverse (chuck should spin to the left when viewed from the back) and hold the main body area of the chuck with your hand while slowly running the drill. The chuck will open (unless it is broke) and release the bit. You do the opposite (slowing running the drill in forward) for tightening a bit in the chuck.
Jul 16, 2011 | Dewalt 18v Battery Hammer Drill Dcd950...
DCD 950, How do you remove the chuck
open up the jaws ,look in the now open area there is a standard screw at the base remove it chuck will come off ,,some are stubborn,,
Jul 08, 2011 | Dewalt 18v Battery Hammer Drill Dcd950...
How do i change the chuck on my dc925
under my handle for this site, go to the tip section and I have detailed instructions on how to remove this chuck. Let me know if you need more assistance.
Apr 19, 2011 | Dewalt DC925 Cordless Drill
How can i remove the chuck from my cordless dewalt power drill
Hello, W/D here.
To remove your chuck, open the jaws of the chuck fully, but don't open them so tight that they lock in the open position. Remove the screw inside the chuck. Spray the inside of the chuck with penetrating oil. Tap around the edge of the chuck, while pulling it away from the motor.
It should come right off, with a little effort.
Best regards, --W/D--
Feb 08, 2011 | Dewalt 18v Battery Hammer Drill Dcd950...
How do i remove the chuck from dewalt dc925 cordless drill, dosnt have a screw inside the chuck, read somewhere that i need a special tool but no instruction or picture of the tool. please help., thank you
The dc925 and the current model dcd950 along with several other models of Dewalt 's line of cordless hammer drills DO NOT have a screw inside removal requires a CHUCK REMOVAL FIXTURE part #
233804-40 also you can't use a generic replacement chuck. As of 2/2/2010 the prices on the Dewaltservicenet web site are $72.74 for
the tool and $69.70 for the chuck, part # 330075-90.
Oct 17, 2009 | Dewalt Heavy Duty Xrp 1/2" 18V Cordless...
I want to switch the drill chuck.model dc 925.how to do it?
CONTACT YOUR NEAREST TOOLKING STORE THEY WILL ADVISE YOU
Aug 13, 2009 | Dewalt DC925 Cordless Drill
Removing the chuck on a dewalt DC925 cordless drill.
I just changed the chuck on my 18 volt xrp half inch hammer drill,yes first you must remove the torx screw with #15 torx bit,note this is a left handed thread screw,knowing the bad chuck was bad I added some heat from a propane torch to the chuck then making sure it was in 1st gear i took some vise grips and the chuck is screwed on with normal right handed threads,it broke loose (was stubborn but needs a lot of torque )ahhhhhh wat a pain.
Oct 18, 2008 | Dewalt 18 Volt Compact Drill Kit
Dewalt 18 Volt Compact Drill Kit Logo
268 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
