Question about JVC GZ-MG330 HDD Camcorder
AV cables don't work
When trying to watch playback on tv through av cables video does not work the sound will work but not video tried different TVs and can't get it to show video. Please help
    President:
  • 1,223 Answers
Ur av cable is faulty try changing it, try the sound cable normally the red one on video port on both sides check if video works or not , if thats the case ur av cable is faulty
Posted on Feb 23, 2009
I am trying to playback videos on my JVC Everio Camcorder using the colored AV cords. I hear the audio coming through my TV but there is no video/picture. I have tried adjusting the settings and tried...
First, set [SWITCH TO ANALOG I/O] to [OUTPUT]
then turn off the (camcorder) unit.
After you connect the cable (from AV connector to the TV's AV Input Connector (accepting the 3 color cables), set the TV to VIDEO mode, selecting the AV input (from your Camcorder).
Then start your playback on the camcorder ...
slide the mode switch to select the (video) mode (instead of the picture/photo mode)... press the PLAY/REC to select the playback mode, and select the desired files/frames to play.
Hope this works for you. Have you tried using the HDMI mini connector instead ? (same process, just set your TV to accept input from the HDMI input)
Jun 03, 2014 | Video Cameras
No audio after recording from sat. Reciever
Double-check your input cables from the receiver to the LG 389. Do you have the sat. receiver AV out connected to the front AV In on the LG DRT389? Make sure that you haven't mixed up the L and R audio connections on either side. (I've done something similar with RCA cables myself.) Next, try a different set of cables.
If that doesn't work, there may be a problem with the audio jacks on either your receiver or the 389. To check, plug the AV cables from the Sat. Receiver directly into the TV. If you have sound and video, then the input jacks on the recorder may be damaged.
Try using another input. (It looks like some models have the SCART input; you may need to set the input source in the menu under AV2 Decoder.)
The fact that you have audio output on USB and DVD's means that cables/connections between the LG289 and the TV are fine.
I hope this helps. Please add a comment with the details of which AV port you are using on the LG389 for additional assistance.
Aug 31, 2012 | LG DR389 MULTISYSTEM DVD RECORDER FOR...
What channel do I set the TV on so that the dvd will play
Hook audio/ video cable from dvd player to AV input of tv and select that AV input in tv to watch dvd playback picture.
You will see yellow jack (for video signal output) and red-white jacks (for audio left-right output signal) at rear of dvd player, plug AV Cable and hook it in AV input of tv, make sure yellow pin connected in yellow jacks of dvd and tv.
Thanks.
Feb 18, 2011 | Sony DVP-SR200P DVD Player
Why dont my isound av cables give me the video? the sound works fine but the video hasnt worked on 3 different tvs. ive tried turning on and off my iphone 3 as well as my tv but nothing works.
Welcome to fixya
Hello
I have a solution for this
Press Ok, Accept or replay so we may get started
Your pre-solution is coming up shortly
PLEASE REPLY OR LEAVE COMMENT TO CONFIRM YOU RECEIVED THIS EMAIL
My name is Bruce
Jan 16, 2011 | DreamGear ISOUND AV CABLE FOR IPHONE
MY PS3 IS PLUGGED IN PROPERLY BUT HAS NO PICTURE OR SOUND???? ive tried over 3 tvs and multiple outlets,sony you just keep letting me down
try connecting it with a different av cable or hdmi cable and see what happens. i wouldn't say it is a coincidence that all 3 tvs are not compatible but also ensure that they are high grade tvs that would probably support the graphics of the ps3. if it still doesnt work, try using your av cable for a ps3 system you know is working with a particular tv and see if it works. if it does, then you know you have to return the console to where it was bought or take it for repairs and let them check it out
Nov 07, 2010 | Sony Playstation 3 (PS3) Console
My Sony CCDTR517handycam
You need to hook Mini jack to RCA video cable between camcorder AV Out and TV AV Input to watch tape playback picture on TV screen.
Above said cable is available in Radio Shake and Amazon etc.
Mar 25, 2009 | Sony Handycam CCD-TR517 Camcorder
Av-s cable problems
You got a major problem with the cable.Better buy a new one.
Jan 03, 2009 | Sony PlayStation Portable (PSP) Console
Can't get signal to TV with AV cable
may have a proprietary cable format. try switching up the colors on the TV end (red to yellow / white to yellow.)
may work, depending on the cable you bought.
Nov 07, 2008 | Nikon Coolpix 4500 Digital Camera
Stand Alone VCRs do not play pictures on my Insignia 24" TV
Did you try using teh SV cables supplied or the RF cable?
Easier to use the AV Cables. 100% should work. Connect Video OUT of VCR ro VIDEO IN of TV and AUDIO OUT (L) and (R) of VCR to AUDIO IN (L) & (R) of TV. Select AV or VIDEO on TV using TVs remote. Play a Cassette. should work!!
Apr 04, 2008 | Insignia IS-DVD1001 DVD Recorder/VCR
How to use ipod to watch videos out on tv
For the ipod touch, you can't use the simple AV cable that we all enjoyed with the older models. I have the 3G Ipod Video and love the ease and simplicity of plugging it in to my ipod and watching videos on TV. I also have an Iphone, so i don't have this luxury with this device.
There is a cable you can purchase that will allow playback with the newer models of iPod. You can check it out here: http://www.bhphotovideo.com/c/product/520691-REG/Apple_MB129LL_A_Composite_AV_Cable_for.html
Mar 05, 2008 | Apple iPod touch
JVC GZ-MG330 HDD Camcorder Logo
195 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
