Question about Texas Instruments TI-83 Plus Calculator
Ti-83 Plus weird display problem (detail included)
Whenever the screen is full and a line with calculation result comes up at the bottom of the screen, the screen all of a sudden shows things in a weird way and can't be read. By press "2nd+mode"(=quit), it gets back to normal. but this pattern repeats forever. Every time screen is full, and a new line comes up at the botton of the screen, the weird display problem repeats. Does anybody can help me?
  • 4 more comments
  • james lxglobus Jun 05, 2007
    no, it doesn't have a hole.
  • Anonymous Feb 19, 2008
    I have exactly the same problem. I've installed the latest OS and even called Texas Instruments. They tried everything they knew of and couldn't get it fixed. I guess we either have to deal with it or buy a new calculator.
    Sorry.
  • Jacksta Mar 12, 2008
    YEAH I ALSO HAVE THIS PROBLEM!! ANYONE KNOW HOW TO FIX IT?!
  • brunowilson May 26, 2008
    i have the same problem there is some vertical lines that come up everywhere .... when graphing when doing normal calculation and everything... i try to reset all thinking that that was the problem ... it didnt fix it ... then magically after a while it was back to normal ... and now the day before a math test the calculator went nuts again...
  • Anonymous Oct 16, 2008
    sounds like mine, i tried reseting to the factory defaults, and that did not change the problem. only really happens when i hit the last lines of the screen. and in menus where there are words all over the page, there is strange distortion all over the page.
  • momojj May 08, 2009
    no, nothing has worked and i realllyy don't want a new calculator!!! what can i do???? columns on my screen (5th and 3rd-to-last) don't even work, and random vertical lines appear!!! is there some way to fix this? :'(
Warning the following tip will erase apps and programs from calculator!
The following will run the self-test mode
Press mode then press alpha then press s then press enter
If you want to get out of the self test press the on button in case you want to attempt to save/transfer apps, programs, variables etc.
The calculator will start to test itself it'll countdown and display numbers on the screen. It can get better sometimes other times a replacement of both the cr1616/cr1620 lithium battery and the 4 AAAA batteries work. Also ensure that you've attempted to clear out all the memory and reset the calculator. To delete all variables, tables, graphs, etc: Press 2nd button then press MEM then press 2 then press 1.
To reset the calculator press 2nd button then press MEM then press 7 then press the left arrow then press 1 then press 2.
Posted on Feb 14, 2012
  • saythanks111
    saythanks111 Jan 26, 2014
    Thanks, helped me
I had the same problem for a long time, I just let it sit there without the batteries for a while (a few weeks) and then plugged the batteries back in, hit 2nd+MODE(Quit) and it worked just fine after that. Also try to take out the little battery in the back, the memory battery, maybe that will fix it. Good luck.
Posted on Jun 13, 2008
Complete memory reset. it worked for me.
Posted on Jun 01, 2009
  • 883 Answers
Is there a tiny hole in the unit to push in a pin to reset it?
Posted on Jun 04, 2007
There's a blank bar that runs horizontal in the middle of my TI-84 plus that's about 16 pixels wide(high?). It's the same color as when the device is turned off. I've tried a memory reset and no results....
SPLIT SCREEN.
It sounds as if you might have split screen mode on. I've got a TI-83 as well as a TI-89 Titanium, both offer a split screen mode. The latter allows for choosing which applications are displayed on each half screen. I am presuming that you may have accidentally put your TI-84 in this mode.
So, if it is a split screen deal then all you have to do is go to the mode screen, find the option for switching from split screen to full screen, and switch it back to full.
I hope that helps. Give us your results!
Adios
Mar 11, 2011 | Texas Instruments TI-84 Plus Silver...
Horizontal blank line across ti 83 display please help
Press MODE on the calculator.
Select Full on the screen.
You should now have a full screen.
You could also reset the memory.
**THIS WILL DELETE EVERYTHING ON YOUR CALCULATOR**
Press 2nd + (+) which is MEM
Go to Reset which should be number 7
Select All RAM which should be number 1
Press Reset which should be number 2
Mar 03, 2011 | Texas Instruments TI-84 Plus Calculator
I'm using a TI-83 Plus calculator. Halfway through my screen there is a straight line preventing me from using the top half of the screen. No matter what I do I can only use the bottom half. Is there...
You've got the split-screen turned on. To turn it off, press MODE to open the mode screen. Use the arrow-keys to move to the second-to-the-last line, highlight "FULL," and press ENTER. Press 2ND [QUIT] to exit the mode screen.
Jan 27, 2011 | Texas Instruments TI-83 Plus Calculator
You probably have your calculator set to display the graph on the home screen. Try pressing MODE and going to the last option, then changing it from "Horiz" to "Full". "Horiz" means it is displaying the graph (probably without axes since your screen is otherwise blank) on half the screen.
Turned on ti 86 and have a black screen. I have replaced all of the batteries and still is black.
Whenever the screen is full and a line with calculation result comes up at the bottom of the screen, the screen all of a sudden shows things in a weird way and can't be read. By press "2nd+mode"(=quit), or try reset button (a small hole which a pin can only be used to press it to RESET. Gud Luck
Aug 25, 2010 | Texas Instruments TI-86 Calculator
I was on my finance app on my ti 83 plus and touched a wrong button ( i'm not sure which) now my general screen has a weird display of p/y=1 and some horizontal lines. it has stopped giving answers. the...
I was able to reproduce the output p/y 1 but I have no isea what the horizontal lines come from. (maybe you set the split screen in mode Horizontal) but that would be touching more than one button.
Press [2nd][MEM][3: Clear Entries][ENTER]
or Press [2nd][MEM][7:Reset][1:All Ram][2:Reset]
In case you are interested, here is what you did to get the p/y =1.
You pressed [APPS][->>][VARS][6:P/Y][ENTER] to get 1.
Hope it helps.
Oct 24, 2009 | Texas Instruments TI-83 Plus Calculator
My TI-83 Plus Calculator will not turn on
This is from TI FAQS:
Solution 11900: Troubleshooting a TI Graphing Calculator That Will Not Turn On.
For the TI-83 Plus Family, TI-84 Plus Family:
Caution: The resets described in these troubleshooting steps will cause a loss of applications, programs and data. If at all possible please create a backup using TI Connect™ first.
  1. Try a new set of AAA batteries.
  2. Adjust the contrast by pressing and releasing the [2nd] key followed by pressing and releasing the up arrow; repeat as necessary. To adjust or lighten the display, use the down arrow.
  3. Remove one of the AAA batteries. Press and hold the [CLEAR] key. While holding [CLEAR], reinsert the AAA battery and then turn the calculator on. The calculator should display the message "RAM Cleared". Release the [CLEAR] key and then press it one more time to remove the message.
  4. Remove one of the AAA batteries. Press and hold the [DEL] key. While holding [DEL], reinsert the AAA battery and then turn the calculator on. The calculator should display "Waiting...Please install calculator software now". Follow the instructions for the TI-83 family or TI-84 Plus family to reinstall the calculator operating system.
  5. Remove all of the batteries including the round lithium battery for 5 minutes. After the 5 minute period, reinsert all of the batteries and turn the calculator on. Adjust the contrast if necessary.
Aug 06, 2009 | Texas Instruments TI-83 Plus Calculator
RAM Cleared
This is kinda a weird situation. Because it's usually the other way around. Your ram will clear if your calculator is frozen. So take out all 5 batteries from the back. Even the back up battery. Then reset it again. 2nd then + then 7 then 1 Then 2. Good luck.
Oct 22, 2008 | Texas Instruments TI-84 Plus Calculator
My ti-83 has a weird display problem. I updated os versiyon but still it has got weird display. what can I do?
There maybe electrical shorts connecting the two motherboards, logic part and screen display part, or within the screen display part, causing the weird display when the calculator appears otherwise functional. Open the TI 83+ case following the U Of Washington posting on fixing TI 83+ problem on inability to communicate with TI link cable between calculator and computer. I used the plastic tools in an IPod battery replacement set to open the TI 83+ case as plastic tools will cause less damage to the TI case. Under the aluminun foil are the two motherboards, each a work of beauty. Good work TI. Connecting the two motherboards is a adhesive enbedded connectors sheet. Above that adhesive connector sheet was a different adhesive connectors sheet in the screen display part, which in my case, some of connectors were exposed. I wiped that adhesive connector sheet and the weird display disappeared with calculator functioning. I may buy some heat resistant clear adhesive tape to put over the exposed connectors part for insulation if problem occurs again. The above may or may not be helpful.
Mar 18, 2007 | Texas Instruments TI-83 Plus Calculator
Texas Instruments TI-83 Plus Calculator Logo
13,980 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
