Sony Laptop PCG-F450 Display
My display on my laptop has become tempermental working when it wants to. I have it hooked up to an external monitor because other wise I get nothing but a blank blank screen, however every so often the screen will work. What is causing this?
  • mspattyjohns Jan 10, 2009
    You wrote "if you do a search for your model # and lcd inverter and see if you can find any...also you will be able to very faintly see what is on the screen althought it looks black..." I am sorry but what am I trying to find? I'm 51 and the tech mind has slipped away...Please explain. Thanks
  • 28 Answers
Usually it is the lcd inverter going bad...if you do a search for your model # and lcd inverter and see if you can find any...also you will be able to very faintly see what is on the screen althought it looks black...if that doesn't work then i may be the backlight in the lcd and a new screen may be needed.
Hope this helps
Posted on Jan 09, 2009
  • Terry Shackleton
    Terry Shackleton Jan 10, 2009
    you are looking for an inverter ...it is a small cuircut board that runs the backlight on the lcd ...it is located just behind the plastic at the bottom of the screen...but usually you can see a very faint image on the lcd screen if it is bad ...if you can see no image then the backlight is gone and may need a whole new screen .... try here http://www.sparepartswarehouse.com/Sony,... have a look any way if you don't know how to fix your self then better take it in....the inverter is about $80....a new screen is anywhere from $150 -$300 .
SONY VAIO PCG-61813M
I have the same problem, It works at an external display and the lcd and lcd cable work on another laptop.
The problem is that i have a sony vaio and it has no inverter, or at least i dont see one like an hp laptop for example. i tried to switch image from external monitor to lcd and it doesnt work. i tried everything. dont know what to do more, Hope you can help.
I have a Sony Vaio pcg-61813M.
Thanks.
Aug 29, 2012 | Sony VAIO Laptop Intel Core i3 Processor...
Sony VAIO PCG-392L screenwith striped colors
Hook a spare monitor to the video output of the laptop, if picture okay! the LCD panel display is defective and most be replaced. But if symptom is the same on both screens it indicates a bad Video Graphic Card normally built into the motherboard.
Mar 19, 2012 | Sony VAIO PCG-505TR Laptop
Dear sir i have sony laptop pcg-81114l when i turned on my laptop there is no display on laptop screen or external monitor i have been testing ram lcd and processor these things are ok but no display plz...
In my opinion it sounds like the onboard video chipset has failed. That would explain why neither LCD nor outside monitor are showing any output. This is especially likely if you are not even getting the initial logo or Power on Self Test showing on the screens when you first turn on the laptop.
Aug 14, 2017 | Sony VAIO PCG-K35 Notebook
My laptop comes on, and the screen stays blank, (black ) nothing, I tried hooking up an external monitor but it does nothing also, could the invertor be the cause? Unit is a Sony VAIO PCG-TR3A
If the invertor was faulty you would get a picture on the external monitor, assuming that the external monitor and the laptop was configured to work. Check the Fn key and F5 at the same time. That should switch between internal/ external or both displays.
Hope that helps.
Dec 09, 2010 | Sony VAIO PCG-TR3AP1 Notebook
Hi there i have a sony viao laptop pcg-7121m, there is no power to the display so when i switch on the laptop the power button lights up but there the screen stays blank, how can i try and trace back the...
Try holding down the function button on the keyboard and tap the F key with the (O) symbol above it, Its the symbol for monitor. You may have to press them a few times. That will toggle computer from its external only monitor mode. If not then hook up an external monitor to the computers vga jack and try again. If you get the external monitor to work that way and not the built on display then the built on display will need replacing and if it does not go to working at all then its most likely a motherboard issue. If the external display does work then you can continue to use it that way until you get the screen repaired/replaced.
Aug 25, 2010 | Computers & Internet
I want to use a NEC Multisync 1700V monitor as an external display for my Thinkpad T400. However I get no image when I hook up the laptop and change the display scheme to display on my laptop screen +...
The only I can think of is the resolution setting that your T400 is putting out that your NEC does not like andcannot display, look at the T42 resolution when the NEC is hooked up to it and try to set it to be the same in the T400.
Mar 25, 2010 | NEC MultiSync LCD1700V 17" Flat Panel LCD...
Can't connect to external monitor or to Sony bravia tv. When vga connected nothing happens at all on laptop but external monitor says " check cable" ( have tried another cable ). If connected in power off...
You need to:
- Connect everything with the laptop turned off
- Boot the laptop
- Use the Fn key plus F8 or F9 (I'm trying from a small picture of the keyboard!) to cycle through the external display options.
Dec 22, 2009 | Toshiba Satellite Pro L300 Notebook
My Sony PCG-FR130 laptop has a screen problem. The screen flickers and is very dim. When I hook up an external monitor it does not display.
Most laptops have a setting to change to external or some will display both at the same time. See what the settings are capable of in your user manual. If you do not have it, look it up on the web.
Sep 25, 2009 | Sony Computers & Internet
I have a Sony Vaio PCG-8A8M with display problems.
sounds like the display/monitor is about to go... backup your files...externally
Sep 13, 2009 | Computers & Internet
Sony Viao Display Problem
Sounds like you have some internal issues going on with this Laptop! If you are getting the same response when you connect an external monitor, then you more than likely have a few things going on here: A bad VGA port for starters, Issues with the Data card, and your graphic card is cetainly not helping. In addition you may want to check appropriate drivers as they are sometimes updated! But my best guess is that you are having issues internally! That could be costly! Sorry!
Nov 26, 2007 | Sony PCG-FR130 Notebook
Computers & Internet Logo
247 people viewed this question
David Payne
David Payne
