Question about Panasonic PT-47WX49 47" Rear Projection Television
No red in picture
My rear projection tvs ic's went out and the repairman replaced them when he got the tv back on there was no red in the picture.(all the red items on tv are grey). Any ideas?
    President:
  • 3,130 Answers
If this happened at the same rime that the repairman replaced the IC's in the set, I would say he is responsible to repair this problem. I would tend to think that the red picture tube socket is loose, or the repairman pulled a cable or connector loose, unless he turned on the set while something on the chassis was touching something else and blew something out. Good Luck
Posted on Jun 04, 2007
My Toshiba 53H71 rear projection TV's picture looks like double vision with a heavy tint outline how can I fix this???
Double vision/ picture problem occurs due to failure of convergence output ICs in rear projection tv and it is common problem of projection tvs.
Please replace convergence output ICs in tv to solve the issue, there is convergence repair kit available for $70 on This Site that has required parts/ ICs, instructions about how to replace ICs etc for a handy person.
Hope these info will help.
Thanks.
Jun 11, 2011 | Toshiba 53H71 53 in. Rear Projection...
My panasonic rear projection tv does not turn on the red light blinks 3 times
3 times red light blinking indicates that tv got problem of convergence output ICs failure and need to replace two big black ICs (convergence output) to solve this problem.
IC replacement requires soldering work and good knowledge of electronics stuff repair, please cal local tv repairman if you do not have prior experience of such work to avoid any damage.
Hope this will help.
Thanks.
Feb 28, 2011 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic (PT-56HX41PF) rear-projection tv with no picture
The three blinks indicates a convergence IC fault. The convergence ICs must be replaced with the manufacturer replacement part. Use only the original replacement part. Your set uses STK392-110 convergence ICs.
These ICs are mounted on a large heat sink. Yes, you can replace it yourself and save few hundred bucks. But you must be knowledgeable enough on how to solder, resolder and use a multimeter.
You will need:
  1. Convergence ICs
  2. Heat sink grease or thermal compound
  3. Soldering iron
  4. Solder lead.
  5. Digital multimeter
  6. Solder pump
  7. Small side cutter
Feel free to inform me if you decide to replace the ICs yourself
Dec 03, 2009 | Panasonic PT-56HX41 56" Rear Projection...
Tv red light blinks off and on. Unplugged for an hour Tv worked for 10 monutes and then picture went to top left corner and got blurry. TV HAS BLINKING RED LIGHT AGAIN.
Replace Both of your convergence ICs one is bad ,but replace both STKs big black ICs also CK two resistors in same circuit 2.7ohms
Aug 11, 2009 | Samsung HCM4215W 42" Rear Projection...
I have no picture and my power red light is
Tell all users of this site that the issue you seem to be facing is common in alot of rear projection tvs. When they shut down and the red light flashes, it may need a component known as a large signal board/deflection board for particular model and brand of tv. Ask a technician for more advice. But i believe this is the issue
Mar 10, 2009 | Toshiba 50H81 50" Rear Projection...
Panasonic projuction screen tv.
3 blinks is the error code for the convergence ICs. You need to replace both STK392-110 convergence ICs. You can get replacement ICs at the following link and they provide installation instructions with pictures.
http://servicemanuals.vstore.ca/
Oct 12, 2008 | Panasonic PT-47WX42 47" Rear Projection...
SONY TV MODEL # KV-L34SN11
hello that is a common problem with this sony tvs, just replace the vertical IC am sure that is your problem, now if you do not the skills to replace it call the repairman
caypianan@yahoo.com
Oct 12, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Toshba CF27E50/CF30E50/CF32E50
The convergence IC needed are STK 392-110 two of them and possibly a resistor or two If you don't know how to unsolder and solder I would suggest an honest repairman. most Parts distributors won't sell unless you have a business but you could try anyway. A volt-ohm meter is required "IF" a resistor needs to be checked or is burned. Convergence IC's are a common problem with all projection tv's. It may last another 5 years especially if you don't buy the generic ic's
Dec 30, 2007 | Toshiba 55H70 55" Rear Projection...
Panasonic PT-47WX49 47" Rear Projection Television Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
