Question about HP Photosmart 2610 All-In-One InkJet Printer
Very slow printing
Quality of the print is still first class but very very very slow!!!
    Scholar:
  • 35 Answers
I'm not sure that there is a problem here.  The correlation between print speed and print quality,
especially on InkJet printers, is a negative one.  That is, the higher the quality setting, the lower
the speed. So, if you're selecting the greatest quality for your print option you will suffer the
lowest output speed.  This is because the printer is taking time to ensure that it prints each
minute detail onto the page.
If you are looking to keep the quality optimal, one solution may be to select a different grade of
photo paper (or perhaps one with a different coating [matte, semi, gloss]) and test to see if you
can lower the quality setting on these higher-end paper types and still achieve your desired
results.
To get what you want from your printing paper, you will have to consider what you like in a print,
how you intend to use your prints, and what you are willing to pay to achieve this at home.
Some things to think about include: paper thickness, color brilliance and resistance to fading.
1. Paper Thickness
When it comes to paper thickness, paper that resembles the look and feel of traditional prints
will be the best if you like to print a lot of photos and pass them around. Thick paper just feels
right in your hands and will also stand up better to handling. However, if you are going to put
the majority of your photos straight into an album, a thinner paper may work just as well for you.
2. Color Brilliance
To ensure the photo paper you purchase produces good color, you can purchase small sheaves
of a short list of photo papers which you think will suit you. Next, print a series of colorful test
photos on each to see which has the best color. If you can incorporate colorful photos that also
have prominent straight lines and people in them, you will also be able to check the quality of
sharpness and skin tones in the same test.
3. Resistance to Fading
Always try to check the resistance of the paper to fading. Simply take your batch of test photos
and tape them to the window that gets the most sunlight throughout the day. Then, before you
go in to pick up a batch of replacement paper, check to see which photos, if any, are showing
signs of fading. Any paper that shows signs of fading in this short time frame should be avoided.
4. Changing Your Ink
It is also important to remember that any time you change ink for your printer, you may find
yourself getting dramatically different results.
Posted on Jan 09, 2009
2 Suggested Answers
  • 75 Answers
SOURCE: print quality stuck on fine
Did you check in the software? There should be a print quality option in your driver software.
Posted on Dec 05, 2008
My canon MX882 printer has become VERY slow at printing pictures. Almost undo able
This all comes down to file size of the picture and the quality you are printing in. Check your printer settings and see if you are printing in least, normal or best quality. Also look at the actual size in pixels of the picture you are printing.
Feb 20, 2015 | Canon Office Equipment & Supplies
Canon image class 3010 slow printting
Hi there:
The main cause of slow printing is due to a bad print cartridge. To troubleshoot this please remove one of your cartridges and see if your printing speeds up. If that does not work. Replace the cartridge and remove the other cartridge. If your printing speeds up. That print cartridge is at fault.
Apr 16, 2014 | Canon LBP2900
Slow printing
Check that the default setting for print quality on your printer driver hasn't been set to "Fine".
In your Opertaing System, find your printer (in XP it's under Control Panel / Printers and Faxes) and select Properties. This should then bring up the settings for the driver.
Fine printing quality takes over double the time "Normal" quality takes so would considerably slow your printing.
Apr 10, 2014 | Brother MFC 210C All-In-One InkJet Printer
It takes a looong time for the printer to print just a few lines
What print quality are you using? Go to the print window, check properties. Under the features tab check print quality. If you are using anything above normal such as Best or Maximum DPI, more memory is necessary to print and will slow down printing. If you don't need high quality printing, change the setting.
Jul 27, 2010 | HP Photosmart C3180 All-In-One InkJet...
920c is printing very slow, like 1 copy in 5
it is possible that your printer settings is set print high quality for a photo paper. try to check if you are printing on plain paper, select paper type as plain paper and quality to normal.
Nov 06, 2009 | HP DeskJet 920c InkJet Printer
Our printer is printing too slow more slow than before
Perhaps someone changed the print quality setting to a higher one, or chose a different media (paper) type in the printer preferences?
If you choose standard paper and standard quality (or something to that effect) does it speed up?
When you choose enhanced/photo quality and special photo paper, the printer will print up to 8 times slower, putting much more and much finer dots on the paper, resulting in indeed much higher print quality - but you don't always need that kind of quality, like when you print documents.
Nov 03, 2009 | HP DeskJet 5550 InkJet Printer
Printing is really slow almost 10 mins to print i am using Vista and have had updated the driver for vista but still
Epson R230 print slow at PHOTO, very slow at BEST PHOTO, if you do not need photo quality prints try printng at TEXT AND IMAGE for faster printing and the quality is still good. Also try to lower the resolution of that you are about to print, high the resoluton images takes longer time to print. Hope this will help you, Good luck!
Oct 14, 2009 | Epson STYLUS R230 InkJet Photo Printer
Prints slow
Check to see what quality you are printing in, all printers print slower in normal mode compared to fast or draft mode. When you go to print click on property and change the quality. This is normally a temporary fix to keep the settings you need to do the same thing inside the printers folder.
Mar 15, 2009 | HP DeskJet 648c InkJet Printer
Printing is very, very slow
Issue The printer is printing slow. Solution Follow the instructions below to manually select the paper type and print speed.
  1. In the application you are printing from, click File , Print , and then Properties . The Printer Properties screen opens.
  2. Click the Paper/Quality tab.
  3. Change the Print Quality from Automatic to the desired setting.
  4. Change the Type is selection from Automatic to the appropriate paper type that you are printing on.
  5. Click OK .
Mar 03, 2009 | HP - HP Photosmart 8250 printer
HP Photosmart 2610 All-In-One InkJet Printer Logo
118 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
