Televison & Video Logo
A
Anonymous Posted on Dec 19, 2017
Philips TV 42PFL7403D/F7 Remote no longer controls Volume & ON/OFF
All of a sudden the remote no longer works to control the VOLUME or to power the TV ON/OFF. We've had it about 2 years. New batteries installed in remote, still not working. Tried unplugging TV for a few minutes, still does not work. The book Troubleshooting guide does not cover this problem. Please help?
lauwereins
Level 1:
New Friend:
Problem Solver:
  • Contributor 13 Answers
  • Posted on Dec 19, 2017
lauwereins
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
13
Questions
0
Helped
706
Points
27
You can start with opening the remote control and clean the buttons on your remote control. don't use any aceton based products. there can be some grease on the buttons.
if you used the on/off and volume more then the other buttons.
5 Related Answers
Anonymous
  • 41 Answers
  • Posted on Apr 21, 2009
SOURCE: My Sony Bravia remote control is slowly loosing it's functions.
You can repair some of these remotes. Usually the hard part is getting the cover off. they are not really made to be serviced. The problem with most all remotes that start doing what you describe is either wear or something spilled on it. You can fix it. Sony remotes may have 1 screw in the battery compartment. remove it and try sliding the front and back. If that dosen't work try prying from one side with a sharp edege. If you do manage to get it open take the PC board out. You will see a rubber like membrane that lays against the board. Try cleaning that with a qtip and rubbing alcahol. Then clean the PC board the same way especially where the pads of rubber contact the board. Make sure it's completely dry and snap it back together. If it works better good, if not the pads are to worn and you just have to replace. Good Luck.
Anonymous
  • Posted on May 10, 2009
SOURCE: The volume is turning itself down all by itself. The volume on the remote won't work, but the remote is fine with the other TV controls.
It sounds like the button is stuck. Take the remote apart if you can and see if the key is stuck somewhere. This happened to me once with a rubber key type of remote. It drove me crazy.
Anonymous
  • Posted on May 25, 2009
SOURCE: vizio remote control not working
Wow, I feel stupid! Solution #2 did it! There are 2 Tv buttons, one on the top right and one on bottom right. You have to press the bottom one!! THANK YOU PPL!!!
Anonymous
  • 52 Answers
  • Posted on Jun 18, 2009
SOURCE: Cox Cable Remote wont program to my Sylvania LC320ss8 tv.
there are different codes for the devices that you are using. When you want to insert the code for the tv. > Switch tv on and then switch all the other devices off. Insert code. For digi box > switch on and all other devices off. Insert code for digibox. You must then switch between tv and digi box using the buttons on the top of the remote. Toggle between tv/ digi box.
Have a go with the codes below with the tv and the digibox both on, you never know you might get lucky as these are new codes, if not revert back to 1st solution.
Universal Codes (both should work using these, i think!!!!! try 'em)
002,
008,
155,
198,
227,
231
Here are the codes for the 1st solution.
Good Luck,
Hughie.
Tv
0062
0004
0009
0135
0189
0183
1141
0227
0456
0008
0068
0075
0141
0161
Digi Box.
0899
0227
0287
0290
0225
0456
0251
0292
0236
0458
1106
Anonymous
  • 45 Answers
  • Posted on Jul 28, 2009
SOURCE: I have an Olevia 542-B11
its hard to find a remote that will work an olevia , since this brand is new and alot of manf. that make universal remotes have not updated there system..
This company called Amergence Technology sells the Olevia Remote and will control any olevia television.
Contact them at 866-965-3842 (just ask to purchase a remote)
My Philips 46PFL3608/F7 tv remote will not work. I can only manually turn on the tv and control the volume from the back of the tv. No controls work from the tv remote. Batteries have been replaced in the...
If multiple remotes used to work (your xfinity and the one that came with the tv), and don't anymore, my first thought would be the issue is with the TV and not the remotes. Is there something physically in the way of the infrared sensor on the TV? Often the sensor is on the at the bottom of the screen on the front, so if your TV is on a table, it's easy to set something in front of it.
Aside from that, there's the normal troubleshooting stuff, see attached images.
remote_troubleshooting2-xpnqcryvoxbslrst3kzoppjq-4-5.jpg remote_troubleshooting4-xpnqcryvoxbslrst3kzoppjq-4-9.jpg
I bought 2008 Subaru tribeca and the DVD remote si not working so i bought a new one from Subaru but it's still not working but the unit is ok any idea?
remote volume control not working Questions & Answers ...
www.fixya.com > Forum > Tags
I bought a Philips PM3S universal remote contro today, thinking that the TV needed one specifically. After one code try, . ... Volume buttons of Sony Remote control is not working for Akai TV. ... not working for Akai TV ... Radio volume control on 2008 Subaru Tribeca does not ... www.fixya.com/. ... RCA TruFlat 27F520T 27" TV.
Media Center Entertainment for Tribeca - SB9T.com
The power on/off button on the remote control works but the channel & volume buttons no longer work
Check the remote control for its infrared emission. Check it with fresh batteries. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
I need the cox remote code for philips sound bar css 2123/f7
I too need this code, if such a code exists. I have found several that control the mute and volume, but none so far control power.
My philips srp5107wm/17 only changes the volume on my tv no matter what device i have it set on
The Philips remote is set to "push trough" the volume/mute to the TV for devices that typically don't have a volume function. Older versions of Philips remote used to allow you to select the device to push volume to, but for some reason this is no longer available (or at least I haven't found out how to). So here is the solution I used.
Teach (learning function) the remote to use whatever device you like for volume/mute.
1, Press the button for the device you would like to change
2. Hold down "learn" and the button you want to teach ex. "volume up" until the red light comes on
3. Place the original remote of the device you would like to change the volume on 5-10 cm away from your Philips remote and press "volume up" for this example
4. Repeat these steps for the "volume down" and "mute" buttons
5. Repeat these steps for other devices you would like to "push through" volume/mute to a device other than TV
Hope this helps others. I did find that some devices like SAT may not allow you to change the volume/mute, but otherwise this workaround does the trick.
How do I find Philips css2123/f7 sound bar remote code for directv remote rc65r
32459 is what worked for me on the RC65. Note that the power button doesn't work, but volume and mute will. If you use the on-screen programming instructions, ignore the instruction to test the code using the PWR button on the remote. Instead, test the code using the Volume UP (+) button to see if the volume increases.
I have a new TV Model 47PFL3603D/F7 and am hooked up to comcast digital box and cannot figure out how to get my comcast remote to regulate the volume. I have the set on channel 3 and everything works...
Usually on a universal remote (after programmed) the volume is controlled by pressing the cable button then adjusting the volume. When you turn your tv on by pressing tv power---then flipping through the channels by pressing cable--channel up or down. The remote (in my experience usually only controls the volume while in the cable mode)
11helpful
6answers
Philips TV HDMI CEC EasyLink tries to control Cable set top box
I finally found a fix to this! YAY. I thought I might have to return the TV. I have the Phillips 42PFL5603D, but should work for other models.
On the TV press menu picture settings---picture---dynamic contrast (turn off) AND active control, turn off
If you have Comcast Moto box: on the Cable box go menu--->setup--->cablebox set up---RF BYbass set to ON
If you have a non-Comcast Moto Box, I'm sure there is an RF bypass setting in the menu. You'll just have to look for it. Another fix was close saying to only turn of the active control, but it took all 3 of these for it to work consistently. The latter let it work for all of 30 seconds.
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
