Question about Epson AcuLaser C900 Printer
Touble re-fitting transfere unit
I need to replace the transfere unit on my epson c900. I have removed the old unit but cannot re-fit the new unit as the aligning pegs dont seem to line and prevents the new unit from locating fully back into the printer. I have tried twisting the unit so that the end aligning peg and multi plug are in line but it still wont go home fully. Can you suggest where i am going wrong.
Thanks
  • 163 Answers
At the back of the printer where the transfer unit locates is a white plastic cam. This has probably moved a few segrees and you just need to rotate it back into position before you can locate the new transfer unit.
Posted on Feb 15, 2009
I have found that you can install the transfer unit as far as possible and leave the top retaining screw out, slightly tighten the lower screw (it may flex the transfer housing very slightly).
Put the waste tonner back on and close the door.
Power up the machine and listen for the click, thats the unit moving into the correct position when the cam rotates.
Turn the machine off install and tighten both retaining screws and you should be all done.
Posted on Aug 27, 2009
HI tigertail
I've got the same problem, but I can't manage to turn the cam around so that it will stay in place? How did you manage to do this?
Thanks,
Ashley
Posted on Jul 23, 2009
How to install printer catridge
Locate Empty Toner Cartridge
  • Turn off your Epson C900 printer and unplug it from your computer and from the electrical socket. Open the left-side panel of your C900 printer and locate the toner cartridge you want to replace. Epson has labeled each of the four cartridges.
Remove Old Toner Cartridge
  • Stick a finger in each of the holes in the empty toner cartridge. Pinch your fingers together and then slide the cartridge out from the printer's interior.
Insert New Toner Cartridge
  • Remove the new toner cartridge from its packaging and shake it vigorously to remix any settled toner. Take the cover off of the new cartridge by lifting it up and out to the right. Slide the new toner cartridge into the empty slot in your C900 printer. Close the left-side panel of your C900.
Oct 07, 2012 | Epson AcuLaser C900 laser toner
How to replace catridge
Oct 07, 2012 | Epson AcuLaser C900 Printer
Can you tell an Epson C900 that you have put in a new Transfer Unit, even if you haven't?
You can tell it but it wont believe you
You dont have a choice with this printer
Please rate my help++++Thanks for using Fixya
May 19, 2010 | Epson AcuLaser C900 Printer
After i change a used transfer unit into the c900, why is it still stated need to change transfer unit?
Is this a remanufatured part?
Epson's printers have microchipsets that indicate when a unit is blown. Some remanufatured parts may still have defective chipsets that prevent printers from using these parts. Try buying an orignal part or another comaptable but new part to see if this works.
Let me know how it goes :)
Mar 06, 2010 | Epson AcuLaser C900 Printer
How do I clean print heads re Epson Aculaser c900
you can clean print head unit
first remove opc and transfer belt ,then move front cover,then rmove
the Drum Unit Slide Cover,then
Remove the Laser Lens Cover.
now you can see printhead unit .Clean it and its ok.
Jun 07, 2009 | Epson AcuLaser C1900 Printer
Transfer Belt
You need to reset the printer in the menu. There is a option in the menu where you tell the printer that you installed a new transfer kit.
Mar 03, 2008 | Epson AcuLaser C900 Printer
Transfer Unit replacement
Because the C900 does not have a button panel, there is no easy way of getting into a service mode to clear the counters. The short answer to your question is no
Have you considered trying to buy a used transfer unit from like of eBay
Oct 11, 2007 | Epson AcuLaser C900 Printer
Transfer Unit Replacement
Hey Coldwell, Check my previous post about a similar problem and see if it helps you out with your situation. Previous Post: http://www.fixya.com/support/t146110-epson_aculaser_c900_photoconductor
May 22, 2007 | Epson AcuLaser C900 Printer
Epson Aculaser C900 photoconductor inserted incorrectly message after changing
Hey Marts Try this: Remove the PCU and the Transfer belt assy's Look inside the machine to the back, top left where you will see the cam as detailed in the picture below Open the right door and you will see a Green Wheel about half way down on the back side. Turn this wheel so the cam inside turns untill it is about 100 - 110 degrees further round (anti clockwise) than it is in the picture - basically make it go as far round anti clockwise as it will go Now try reinserting the TFB and PCU assy's in turn. You do not need to insert the 2 big silver screws that hold these units in place Close her up and see how you get on. If this has no effect, let me know and I will see what else you can do.
May 03, 2007 | Epson AcuLaser C900 Printer
Epson AcuLaser C900 Printer Logo
269 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
