Question about Rio Nitrus MP3 Player
Saving Settings My Rio Nitrus will power down and get stuck on saving settings. It then will not turn off completely. It has only done this once before and eventually turned off. Then It could be used normally. Any suggestions on how to avoid this problem?
  • 102 Answers
1) Make sure that you use your MP3 Player carefully. Don't drop it. and put it in a safe place. 2) Charge your Player only when its battery nearly empty. 3) leave some storage available, like 10% of your storage. 4) Unplug it from your PC when you aren't using it. 5) Use safe removal when removing it from your PC. 6) When you don't use it, Shut it down. Good Luck
Posted on Jun 09, 2007
SOURCE:
Settings wont save. I CANT GETMY SETTINGS TO SAVE. I PUT IT DOWN GO DO THINGS COME BACK & LOOKS AS IF ITS TURNED OFF. THE BRIGHTMNESS SETTING ON ITS OWN GETS TURNEDVALMOST OFF & SAME WITH OTHER...
If you have power saving mode on, it goes by those settings. Check settings, my device, then scroll down to power saving mode and if it's on turn it off, that might help.
Dec 23, 2013 | Samsung Galaxy Cell Phones
Battery status incorrect
This recalibrate's the battery.
Charge the battery completely. Monitor the battery indicator, which is usually found that the bottom of your computer screen, to check if the battery is already fully charged.
Plug off the power adapter and use the laptop until the battery is completely drained. To drain the battery faster, run several programs at once and keep the contrast of your screen to its highest levels. Turn off all power-saving features as well. Turn off sleep mode.
Make sure that the battery is totally drained by waiting for your laptop to shut off or go into sleep mode automatically because of very low battery charge.
Plug the power adapter again and charge the battery again completely. Once this is done, restore the power-saving features and adjust the contract settings of your screen to normal.
Apr 08, 2013 | Dell Vostro Computers & Internet
Gateway desktop enters power save mode while in use.
boot and adjust the power settings for all "when on A/C" to never. to take it out of power save press any key on the keyboard or press the power button (but dont hold it down)
Jul 08, 2012 | Gateway Computers & Internet
Power off
That is because of the invention of power saving modes, where a single touch puts it in sleep mode and a 4+ second touch turns it off.
Check the bios to see if there is an option under the power saving section. You may be able to change this function to suit you.
Jun 10, 2009 | Panasonic Toughbook T2 Notebook
Rio carbon
Insert a paper clip end into the small hole to the right of the headphone socket. This will reset it (if it's not already gone flat!)
Mowcius
Jul 04, 2008 | Rio Carbon MP3 Player
RIO Nitrus
It says "upgrader" because it is looking for a firmware upgrade - you will not be able to get rid of this message without doing the firmware upgrade - go to the rio website and follow the instructions for doing a fimrware upgrade - the msg will be removed, and you will be good to go
-Tha Mp3 Doctor
May 28, 2008 | Rio Nitrus MP3 Player
"RESTARTING"
I encountered the same issue with my Nitrus. After following instructions to upgrade firmware, I had the "restarting" message on screen. I then took the unit apart once again. I could hear the drive making a noise. I tapped on the back of the drive with a screwdriver and the player started working properly.
Mar 27, 2008 | Rio Nitrus MP3 Player
Ok Rio nitrus is great litle thing, and I had the same problem. This is what you should do:
1) download latest firmware for rio nitrus http://www.rioaudio.com/support/rio/downloads/Nitrus/RioNitrus_firmware_123.exe
2) unpack firmware
3) connect Rio Nitrus to your comp;
4)While holding menu buton press power button, you sholud see on display showing UPGRADER text;
5) Then upgrade the firmware ( note that this will erase all the songs- read the read me file that come with firmware);
Although I allready have the same version of firmware v.123 like the one that upgreded this solved the problemm.
Feb 27, 2008 | Rio Nitrus MP3 Player
Transfer error - Disagreement between player and software
I had the same issue and I eventually re-formatted the player. Once I had finished that, it seemed to work again, letting me add songs.
Feb 25, 2007 | Rio Nitrus MP3 Player
Rio nitrus will not power up
I took ny Rio Nitrus apart trying to fix the screen & noticed that the rechargable battery connects to the motherboard with two flimsy little wires and a pinhead worth of solder. If you've tried everything else, it'd be worth your time to take off the back and have a look 'cuz a drop could easily have shaken one of these wires loose.
Jan 21, 2007 | Rio Nitrus MP3 Player
Rio Nitrus MP3 Player Logo
Top Rio Audio Players & Recorders Experts
Marvin
Marvin
Joseph Hoffmann
Andrew Taylor
Andrew Taylor
Are you a Rio Audio Player and Recorder Expert? Answer questions, earn points and help others
