Question about Samsung LN-T4042H 40 in. LCD HDTV
Sound but no picture
I own a samsung LNT4042H and 2 days ago the picture went out. It looks as if the tv is off when powered on but you can here the channel its on. Any way you can tell me whats wrong with it?
  • mgflores84 Jan 11, 2009
    Hey you were right on the inverter. Do you know were I can get a new one at a reasonable price?
  • 362 Answers
It is most likely the inverter, here is a trick to check it. Turn the tv on a channel where you have audio(sound)
Take a flashlight or a lamp with a bare buld and shine it on the screen. Look very closely at the screen, if you see a video image your inverter is bad.
Let me know and I can instruct you on replacement.
lone99star
Posted on Jan 09, 2009
  • 1 more comment
  • Jason Morris Jan 12, 2009
    Glad I could help, SHOPJIMMY.COM is where I buy most of my parts, they have your board in stock for less than $100.
    Let me know if I can assist in the installtion. lone99star
  • nquartuccio
    nquartuccio Apr 13, 2013
    Jason hello, I dont see a picture but there are thin lines running vertically, like thin pin stripes on a suit
  • nquartuccio
    Jason Morris. Thanks. I just replaced the capacitors on this tv. I have no picture now. When on I see thin pin stripes running vertically when I shine a flashlight on the tv? same problem?
2 Suggested Answers
jsinex2421
  • 62 Answers
SOURCE: Sound but no picture
Your lamp is burned out.
Posted on Jan 10, 2009
Lost picture have sound on 55" Samsung led TV. Just went black all of a sudden two days ago.
Does the power light indicate power when it's plugged into the wall? When you press power, do you hear a clicking noise? If so, google your model # plus clicking noise power on
Not sure how old a Samsung TV you are talking about, but they had major problems with capacitors (widespread issue) in their TV's. Easy fix and something you can do yourself.
Mar 28, 2017 | Samsung Televison & Video
LNT4042H TV will not power on. No sound, no video.
Check the power supply module voltages first, it should have 5vdc standby voltage at all time the minute the TV is plugged into the wall outlet, try turn on the TV, then the main 5vdc, 12~16vdc and the 24vdc should be on. Look at the supply for burnt parts, blown fuse, etc.
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=Samsung+LN-T4042H+
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Jun 15, 2010 | Samsung LN-T4042H 40 in. LCD HDTV
I have a samsung lnt4042h and it has worked fine until about a week ago, it started making a clicking sound, and wouldnt turn on, the clicking goes on repeatedly until 5 secs after i unplug it. i kept ti...
Howdy,
It sounds like you have a Power Supply Board problem. The PSB is the center Board (towards left) after you remove the back off the TV. Remove Board from TV with the 6-7 screws. Replace capacitors CM811, CM812, CM817 & CS806; 1000ufd 25volts.
Good Luck, big IRISH.
Oct 21, 2009 | Samsung LN-T4042H 40 in. LCD HDTV
Clicking on Samsung LNT4042H
go here and fix it yourself for less than $10
www.earthinfo.org/samsung-tv-makes-a-strange-clicking-sound
Jul 12, 2009 | Samsung LN-T4042H 40 in. LCD HDTV
No picture, no sound, no lights, faint clicking sound, fuse ok
HT transistor, or rectfying diode from chopper transformer is blown.
Apr 24, 2009 | Samsung DynaFlat TXN2668WHF 26" TV
you've lost your backlight, the inverter board are part of the panel, so hopefully u just los a couple caps on your power supply. You should check your powersupply for lifted caps.
Mar 21, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Jan 09, 2009 | Televison & Video
Zenith 13in flat screen tv has no picture...
Welcome to FIXya
did you try to unplug it and plug it back in
or maybe goto the menu and try to redo the stations
make sure you have the tv pluged in to a power strip
hope this idea helps out if not please let me know have a good day:)
Jul 16, 2008 | Zenith L13V36 13" Flat Panel LCD Monitor
NO PICTURE
sounds like the vertical output is causing the CRTs to shutdown for protection. Try resoldering the vertical output IC that will often correct the problem. If not the vertical output IC may be defective.
May 17, 2008 | Samsung HCN4226W 42" Rear Projection...
Samsung LN-T4042H 40 in. LCD HDTV Logo
199 people viewed this question
Henry  Thomas
Henry Thomas
