FixYa.com
Tags:
Mach Speed P4MBMS Motherboard
P4MBMS Motherboard Problem (by 2 users)
posted by flexiron on Jun 03, 2007
I hope some can help me, I just installed a new Mach Speed MoBo and I can not get to the Bios, all I get is a black screen. I'm trying to install win Xp Pro and having no luck.
I've switched mem. sticks, tried the on board video and checked the processor several times.
Using an Intel P4 3.2 processor, (2) DDR 512 sticks and an Nvidia 5500 256MB card, 400 watt supply and a creative sound card (Audigy).
Please Help! Tony
Comment by flexiron, posted on Jun 04, 2007
24 Seven,
Tried reseting jumper, no go. Also did an out of case MoBo start, still no go. Screen is still black, can not get to the Bios. What next? Tony
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by nonoks, posted on Mar 29, 2008
the power is ok, but i cant get into the bios, all black scree.....
Best Solution
posted on Jun 06, 2007
Helpful (85)
juandelacruz
Rank:Wiz Wiz
Rating: 82%, 218 votes
Try to solve th eproblem by process of ellimination. On another PC or working mother board, chaeck the video card and memory modules.
Unless you are sure that the memory and video card is OK, trying them all together with an untested motherboard will difficult.
If you are sure that the Video and memory is OK and still the motherboard will not start, we can narrow down the problem to the mo bo, CPU and Power supply.
If the board switches on (LED lights and CPU fan starts) we can rule out th epower supply and we are sure that the problem is in the motherboard / CPU. if this is the case, return the board for replacement.
If it eill not power on ( no LED lights and the CPU fan will not start), then it might be that the power switch is not connected properly to the motherboard or the Power supply is defective.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Jun 03, 2007
Thanks for Trying (70)
24 seven
Rank:Wiz Wiz
Rating: 82%, 1139 votes
look for the reset jumper on the board and then reset it then try again
Comment by 24 seven, posted on Jun 05, 2007
try another keyboard? and re-check power supply connection to MOBO.
Rating Locked! (?) flexiron has rated this solution as Thanks for Trying
Can you Help with these Motherboards problems?
Motherboards
laptop will not come on
ispiron B130 Answer This...
Motherboards
compaq presario c500
my compaq c500 does not run ... Answer This...
Motherboards
Intel 915 mother bord
The system gets hanged and does... Answer This...
Motherboards
MSI MS-6754 mother board won't...
I've got a working PC with a... Answer This...
Motherboards
mother board jumpers setting
sis mother board jumper setting... Answer This...
Repair Service
Find Motherboard Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
