Question about Classic Accessories Classic Bicycle Dynamo Generator Unit 12v 6w
I would like to know how to wire a bottle dynamo to bike lights
The bottle dynamo is not connected to the lights on my new bike. there are no instructions. please could someone explain how to connect them. Thanks, Christina
    President:
  • 2,692 Answers
The bottle dynamo rides against the tire turning it . The wires from it go to the front liht. The same two wires  may also be hoked to a back light. The  direction of flow is not that important but most put the same (one of the two ) wire on the center connection. If you generator has only one wire, then the light(s) will have to be grounded through the frame.
Posted on Jan 09, 2009
Touched wires for headlight together now no power?.
Have you checked the bulb is good? If that's okay, it has to be a bad connection on the bulb holder or you missed a blown fuse that maybe looks okay.
May 31, 2015 | 2006 Bikemaster-2008 Kawasaki Ex650a Ninja...
2009 ninja 500 not starting and headlight does not go on when on.
Hi i have a 750 zxr ninja and i parked it up at work went to go home from work would not start i took the seat of to have a look and checked the fuse 30 amp just behind the battery its on the the rear left hand side just behind the battery it was blown put a new green 30 amp fuse in turned on the ignition started first time hope it helps
Apr 20, 2012 | kawasaki Ex500d7 Ninja 500r Motorcycle...
No power from starter solenoid to starter, also headlights are not switch onas normally
most newer bikes have a fuse on the selenoid itself. if not check the fusebox for bad fuse. also the kickstand switch will not let the bike start in gear with the stand down.
Jan 29, 2012 | kawasaki Ninja Zx7r Zx9r '94 To '04
I WANT TO KNOW HOW TO CONNECT MY BYCICLE LIGHT GENERATOR
The generator, or dynamo, fits onto the back fork bar of the bike. The top, which rotates, should be close to the tyre of the back wheel. There's a little lever which you press downwards. When you press it the dynamo moves in against the tyre so that when you're cycling the movement of the wheel causes the top of the dynamo to rotate. To stop it, or turn off your lights, you pull the dynamo back out from the tyre. You need to adjust the dynamo so that the top of the dynamo makes contact when the lever is pressed but doesn't when it's pulled back out.
Normally a dynamo has only one wire which connects to the lights. You need to use lights designed for it. This carries the positive current. The frame of the bike usually acts as the negative. Some dynamos may have 2 wires. In this case the positive connects to the centre of the light and the negative to the outer.
Apr 13, 2011 | Cycling
Polorized generator as per manual. went from no output to .2-.4 amps. do I need to rebuild the generator?
Hi, I own a 1976 XLCH1000 and had a similar problem some years ago.
The dynamo must be energized correctly as if not it wouldn't work.
Disconnect the two wire on the dynamo.
Connect a volt meter from the armature connection to the bike frame, negative.
Start the bike up and on a fast tickover there should be 2 to 5 volts present. Momentarily connect, while still monitoring the voltage, a wire link from the field connection to the bikes frame (earth or negative of the battery). The voltage should shoot up to about 25 to 30 volts. If it does you have a good dynamo. If the dynamo is flashed the wrong way around then a negative voltage instead of a possitive voltage will be produced and damage the regulator if it is the electronic type, like on mine.
If the voltage is low, change the brushes and clean the commutator with some wet and dry paper scraping out between the segments to clear the dead carbon deposits. Don't forget the end bearings are "Oilite Bearings" Don't use grease a drop of 20-50 is fine.
Anywhere else in the world, we put voltage on to the field terminal to produce current at the armature, trust the Americans to be different!
Ride safe and loud pipes save lives!
Hope this solves your problem.
Nov 09, 2010 | 1979 Harley Davidson XLH 1000 Sportster
1985 700 vulcan , the bike starts , runs , everything works but the headlight , fuses look good , what am i missing?
Try taking off the switch. use a jumper wire across the leads. if your headlight comes on, replace the switch.
Aug 29, 2010 | Clymer Kawasaki Vulcan 700 Vulcan 750...
Wiring of a Panasonic CQ-C1001N Car CD Player into a Morris 1000
You can get wiring diagrams on line, do a search using the players full name. Is your morris positive on negative earth? you will have to swap it if it is positive as the player is negative earth only (usually dynamo is +ve and alternators are-ve ) I have changed lots over when dynamos were common, turn the battery round and pull the 2 wires off the dynamo take a wire from the +ve battery terminal  and "wipe it across the 2 terminals on the dynamo, this will make it -ve earth too, re connect the dynamo and off you go
Mar 17, 2009 | Panasonic CQ-C1103U CD Player
I would like to know how to connect the dynamo lights on my bike
You want to attach this item to the rear of the bike. Mount it so that when you hit the switch the item lean over and hits the rear tire. Hook up the wire to the lights and your all set. Now I can tell you that with this item NOT engaged you will be able to ride with no problems, but with this item engaged it will give you resistance. Meaning that you will know how much harder it is to pedel the bike. I had this item and then went and purchased a battery power item.
Jan 09, 2009 | Classic Accessories Classic Bicycle Dynamo...
Classic Accessories Classic Bicycle Dynamo Generator Unit 12v 6w Logo
2,769 people viewed this question
Top Classic Accessories Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Classic Accessories Cycling Expert? Answer questions, earn points and help others
