Question about Goldstar R8000 Air Conditioner
Room air conditioner
Water is dripping inside my room. It isnt consistant though, it stops then will start again.
  • ralvarez460 Jul 01, 2008
    My Goldstar is leaking inside and it will not stop. how do you clean the hose or inside? Do you have to take the unit out of the window. Please help me.
    Roberta
    Ralvarez@aandsmetal.com
    Scholar:
  • 125 Answers
There is a drain outlet that is connected to a hose or pipe for the condensation build-up. Most probably it is clogged with dirt. have it cleaned.
Posted on Jun 04, 2007
  • 883 Answers
The unit needs to be tipped outward so that the lowest point of the unit is actually outside the window.
Posted on Jun 03, 2007
My ac isnt draining water and creating mold in the house on my furniture & clothing
drill hole in cabinet to let water drain but be careful of wherer u drill. 3/8 bit is big enough
Jul 23, 2014 | Frigidaire FAC125P1A Window Air...
My dehumidier blows very hot air while working. Makes it hotter than it was before starting. Like a furnace.
It is normal for a dehumidifier to discharge warm air. A dehumidifier is really an air conditioner - a fan blows humid room air across a cold fin coil that causes the moisture to condense on it and drip into a container - thus cooling AND dehumidifying the air. The cool air is blown over the warm coil and discharged out the back. A dehumidifier WILL normally increase the temperature of the room it is in.
You can do the same thing with sitting an A/C unit on a stool in a room. Room air will be drawn in, cold air will come out the front, hot air out the back and water will drip on the floor. And, the room will get hotter, due to what is called "heat of compression" even though you're running an A/C unit.
Jun 26, 2013 | Windchaser WDH928 Dehumidifier
Pipe from inside to outside heater is leaking water when burner ignited
This is a natural occurance do to atmospheric conditions. As the heat from the gas burner warms the inside lining of the cold metal flue vent, the humidity in the room air creates condensation. In some cases, enough to drip down on the burner assembly. It is nothing to worrying about, unless it does not stop dripping after the burner has shut off.
Oct 23, 2010 | Plumbing
Fills with water, doesn't evaporate. Leaks. HAIER HPR09XC7
There is nothing to resolve. Your humidifier is working properly.
A humidifier works by condensing water out of air. This is the job of the cold coil, which you have found to have water dripping off. The Warm coil is not intended to re-evaporate the water, as this would just bring the relative humidity back to the origanal high level, rather, the warm coil is used to re-warm the air, going back into the room so the room does not get too cold. It is normal to have to empty the bucket and restart the process on a periodic basis.
Jul 20, 2010 | Haier HPR09XC7 Portable Air Conditioner
The ac is dripping inside the room
Hello.
You need to clean out the drain pan.Also unit shold be tilted back a little so water will run outside.
Remove the front grill and using an old tooth brush clean out the bottom pan where water is laying.Also be sure the drian hole outside the unit is clear.
May 27, 2010 | Panasonic CW-C100AU Air Conditioner
My Frigidaire side-by-side leaks inside, from water filter
the gasket that holds the water pressure in between the water inlet line and filter is not in proper position, or your filter sir is nt properly inserted into the slot,the cycle starts when the water comes in,pressure will build up and it will start t pass in between the gap, as the pressure goes down, dripping will stop, then cycle start again, check the connector sirandhose connected into the filter
Mar 18, 2010 | Amana ACD2232HR Side by Side Refrigerator
The water from the door of my GE Profile fridge doesnt work consistently. Sometimes it does and sometimes is does not provide water. It has started dripping inside the freezer leaving icicles.What to do???
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
You have two points where you can check the dispenser water. At the rear where the water supply comes in is the water inlet valve. If you disconnect the dispenser water line and then see if the water comes out when you try the dispenser. You should hear the valve work when you try the dispenser. If you don’t hear it there is a dispenser actuator switch problem. If you do hear it but water doesn’t work here there is a valve or water supply problem. If it's normal, disconnect it at the bottom of the freezer door and try again.If it's normal here it may be frozen in the door. If this is the case open the door till it thaws. A blanket over the opening will prevent thawing of all the food.
Dec 01, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE WHDSR315 washer randomly drips still after done filling
you looking for a new water valve assembly...not very hard to replace..maybe a lil' messy
Aug 28, 2009 | Washing Machines
Oasis water cooler taps started dripping
if the cooler is a hot and cold, even if its a cook and cold, the cooler always needs to be cleaned and maintained, not only on the inside but on the outside, as the cooler is used calcium builds up over time. that is why your taps are leaking, there is a build up in the taps, therefor the taps are not sealing properly and letting some water thru. i say take the taps out and clean them with vinegar.
the second thing u can do is the taps do come apart into smaller peices once u disconnect them from the cooler. take the taps apart and find the spring located within it, stretch the spring and than reconnect the peices together than reconnect to the water cooler.
Nov 14, 2008 | Oasis P1AQ
Goldstar R8000 Air Conditioner Logo
150 people viewed this question
Top Goldstar Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Goldstar Heating and Cooling Expert? Answer questions, earn points and help others
