Question about General Brass Plumb Bob
Plumb weight How we calculate the plumb weight i want to know that It will be vary depand up on height any standard for that
  • 10,865 Answers
No standard. Just use a scientific scale to determine weight. Your local druggist will have one.
Posted on Jan 18, 2009
Assuming you are in the USA and use these units:
W is your weight in pounds
H is your height in inches
BMI = W / H^2 x 703.
So if your height is 5' 10" (70") and weight is 180 lbs
BMI = 180 / (70 x70) x 703 = 25.82
So <18.5 is thin
18.6 to 24.9 is healthy
25 to 29.9 is overweight
>30 is obese
Sep 16, 2014 | The Learning Company Achieve! Math &...
Toilet flapper doesn't stay up unless handle is held down until tank empties.
If the flapper won't stay up, you may be lifting it too high - you want to retain a little air inside it when it's lifted. Try adjusting it to a lower lift height.
Jan 12, 2014 | Plumb Pak Plumbing
Where do you get the overall height measurement at
3 measurments here
*static height-
*dynamic height-
*suspention height(extended fork length)
static height is measured with a plumb line to the ground at the center of the fork tube top with the motorcycle standing upright and no rider on on it
*dynamic height is the same except your sitting on the motorcycle.
*suspention height /extended fork length is with the front wheel off the ground and measured from the center of the front axle to the top of the fork tube.if tube cap/valve is recessed you still use the top of tube measurement but if it has a cap that screws in on top of the tube then imagine the fork cap removed (measurement stops at the top of tube itself.(most always)
Mar 01, 2012 | 2004 Honda VTX 1300 Retro
What is the weight of a 6 1/2' feet Gammon reel? Can I use it to work with a 3oz small Plumb Bob?
Bon Tool's 6 1/2' Gammon Reel weighs .10 pounds, and may be used with several sizes of Plumb Bobs, including a small 3 oz Plumb Bob.
Jan 03, 2011 | Bon Tool Co Gammon Reel Surveyors 12 ft
Not sure how to find actual length of hip rafters from plumb cut at ridge to birdsmouth at wallplate.I have 2 stanley quick squares but have misplaced the little instruction books.I would appreciate your...
Use Pythagorus. Measure the horizontal length from the plumb ridge cut to the position where the horizontal birds mouth touches the top plate on the wall closest to the ridge. This point should be 1 1/2" in from the outside edge of the wall. This is your run.
Now measure the vertical height from the top of your wall plate to the where the bottom of your vertical cut from the rafter will end up on your ridge. This is your rise.
A squared plus B squared equals C squared. Get your calculator out, if the run is 12 feet and the rise is 4 feet, then 12 squared (144) + 4 squared (16) equals 160. The square root of 160 is 12.65 ft. or 12 feet 7.79" long. There are other ways, but this is most accurate. Make sure your ridge is parallel to you wall.
Sep 29, 2009 | Stanley 46 - 050 10 - 3/4" x 6" Quick...
No instructions
Open the cardboard dust cover on the rear of the ice box and connect your water line to the water valve. Here is a pic: a8e6c7c.jpg
Jan 31, 2009 | Admiral 26 cu. ft. Side-By-Side...
General Brass Plumb Bob Logo
263 people viewed this question
Top General Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a General Measuring Tool and Sensor Expert? Answer questions, earn points and help others
