Question about Sony Cyber-Shot DSC-F717 Digital Camera
Slow shutter speed
I have had this camera a year and love it but i need help with the shutter speed i have been through all the settings i can find in the menu , and yes read the owners manual but i cant find a way to set the shutter speed. The shutter is so slow i cant take any pictures where someone moves, and i cant take any pics of sporting events,waterfalls etc.Does anyone have a suggestion?
  • 883 Answers
From the manual: Using Shutter-Priority Mode 1. Set the mode dial to S (shutter-priority) and a yellow arrowhead on the screen points to the current shutter speed. Press the jog dial and the current shutter speed turns yellow. 2. With the current shutter speed displayed in yellow, rotate the jog dial to select the speed you want to use. 3. Take the picture. If a workable aperture isn?t available for the shutter speed you?ve selected, the shutter speed indicator on the screen flashes when you press the shutter button halfway down. You can use the setting as is, or press the jog dial down to select the shutter speed again and rotate it to select a new shutter speed.
Posted on Jun 04, 2007
Shutter speed
If there is nada in the menu you are SOL.
Aug 23, 2017 | Kodak M590 Digital Camera
My shutter speed is very slow and when I take pictures I think when it's dark is when I notice the problem but the picture will not take. Also if someone moves their face is blurry.
What mode are you shooting in? It seems you may either have your shutter speed set manually to a slow speed or, alternatively you have set your apperture set to a high number e.g f/20 or there abouts. Because this is a very narrow apperture the camera will compensate by using a slow shutter speed.
Try some shots in fully automatic mode and see what happens. With a slow shutter speed you can expect any movement to produce blurred images.
Oct 21, 2011 | Nikon D90 Digital Camera with 18-105mm...
Pictures are blurry
There are a few things to consider:
-- Are your hands steady as you take the shot, and are you moving the camera before the shutter actually clicks? As a test, put the camera down on a table top and take a picture without moving the camera until well after the shutter clicks. If the resulting image is not blurry--you just proved that your holding technique needs improvement!
--This camera has image stabilization to help you deal with camera shake--do you have this feature turned on in the menu?
--If your subjects are moving and your shutter speed is slow (meaning that the shutter stays open a relatively long time to gather enough light) then you will get blur. And, even if your subject is not moving but the shutter speed is slow, then your camera shake will come back to haunt you.
To fix slow shutter speed, you can either use a flash to freeze the action, or you can manually increase the ISO setting to a higher number, or you can choose a preset like "sports" which will tell the camera you want faster shutter speeds. A higher ISO setting will allow for faster shutter speeds, but it can also result in a grainy look, called "noise" if you set it too high.
Most likely it is your holding technique and the setting you are choosing that is causing the blur. If you are in decently bright light outdoors, you hold your camera steady and wait for the shutter to click, and you have image stabilization on, then you should have sharp pictures. If you are indoors, expect to need a flash.
Nov 25, 2010 | Canon PowerShot SX100 IS Digital Camera
Photos are blurred.
Blurred images are caused by several reasons: motion due to camera shake, use of slow shutter speeds and failure of the camera to focus correctly.
Slow shutter speeds
When light is low, wide apertures and slow shutter speeds will be selected automatically by the camera. Most people can't take blur-free, hand-held shots when the shutter speed is under 1/60th of a second.
Cameras that have optical Image Stabilization help but even IS has its limits. Increase room lighting, increase the ISO setting or use a tripod, or use a combination of all three.
Blurred images or misfocus
If an image is blurred due to camera shake, the blur will appear throughout the entire image. If parts of an image are in focus, and others are not, you've misfocused.
Sep 16, 2010 | Cameras
Shutter speed on the auto mode of my s1000 camera seems slow. how can it be increased in the auto mode? This is a Fuji camera and by the time I press the shutter button subjects have moved. I have set the...
You need to press the shutter button half-way and allow the camera to lock in the focus before you press the rest of the way. This eliminates "shutter lag".
Dec 30, 2009 | Fuji FinePix S1000FD Digital Camera
How do I set shutter speed to photograph without a flash
You can take the photograps at P mode while keeping the flash off. In this mode the camera will set the speed and the appature according to the available light. This may slow down the speed so make sure you keep the camera stable.
Apr 03, 2009 | Nikon D50 Digital Camera with 18-55mm Lens
Is there anyway to resolve shutter lag on the Nikon Coolpix 8700?
oh what mode is your camera in? auto- adjust your Iso it is too bright or dark for your current setting
c1-(manual) change your f-stop and Iso. set the iso to 200 and move the F-stop to any number and test the speed.
c2-same as c1
If you need further clarification write back i'd love to help!
Jan 12, 2009 | Nikon Coolpix 8700 Digital Camera
Shutter speed
shutter speed has nothing to do with battery power. If you have a SLR camera you use the shutter speed option when you want to have control of the shutter speed, slow shutter speed means if your taking a picture of a waterfall and you want to see the actual droplets you set a slow shutter speed, if you want it to look more smooth/flowing you set a faster shutter speed, if you do not have a SLR camera you probably dont have much say so in shutter speed...
May 28, 2008 | Nikon FE 35mm SLR Camera
Digiscope
Hey timpo,
I would definitely use some kind of remote release since even the smallest amount of camera shake (pressing the shutter button) can cause blurry images in high magnification images. At the type of magnifications usually involved in digiscopeing the depth of field of your images will be greatly reduced and you will need to set the camera to a smaller aperture than usual, which should result in slower shutter speeds. I would definitely have the camera set to manual exposure mode so you can control both the shutter and the aperture although aperture priority should also work well. I would not set the camera to a higher iso since you will lose quality, and since I am assuming you are using a tripod slow shutter speeds should not be an issue. Any movement by the subject will blur the subject if you are using slow shutter speeds so if this becomes an issue you can set the camera to a wider aperture at the loss of depth of field to achieve a faster shutter speed. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
May 27, 2008 | Nikon Coolpix 5700 Digital Camera
Sony Cyber-Shot DSC-F717 Digital Camera Logo
2,044 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Terry Weaver
Terry Weaver
Are you a Sony Camera Expert? Answer questions, earn points and help others
