Question about Farberware FAC900R Toaster Oven with Convection Cooking
Need to activater self-clean
It is self-cleaning in theory. how do i activate that feature?
  • nys_t1_2 Jan 12, 2009
    I don't have the manual for my Farberware FAC900R Toaster Oven with Convection. I don't see anything that says self-clean, now what?
    President:
  • 1,952 Answers
Every self-cleaning oven is different. It's best to consult the owner's manual for the correct procedure for your oven. But often the steps are:
  1. Set the Start time for the time you want the cleaning to begin.
  2. Set the Stop time to a time 2-3 hours after the start time.
  3. Close and latch the oven door.
  4. Set the selector switch and/or thermostat to "Clean."
Posted on Jan 09, 2009
  • mohammed marika thambi
    mohammed marika thambi Jan 09, 2009
    Ovens reach
    extremely high temperatures (800 to 1,000 degrees) during the
    self-clean cycle--to incinerate the grease, food splatterings, and
    drippings inside the oven. When all of that burns, it can smell pretty
    bad. Make sure you have good ventilation in the room where the oven
    is--at least when using the self-cleaning feature.
    Ovens reach
Waring pro toaster oven: the toaster part spring would not stay down. How to repair?
Most of the time this problem is caused by a build-up of toast crumbs in the latch mechanism. Unplug the toaster oven and follow the instruction manual directions for cleaning the toaster section. Try cycling the toaster lever up and down a few times, then clean out the crumb tray again. If that doesn't solve the problem, you'll have to look for an access to the latch mechanism to clean it out and perhaps gently straighten the latch hook if needed. Note: these are generic directions for all such toasters. I can't be more specific without knowing which model in the Waring Pro line you have.
Jul 02, 2017 | Waring Toaster Ovens
Frigidaire gallery error code f9
How do I reset an F9 on Frigidaire oven? ' ShopYourWay
www.shopyourway.com > Manage My Life > Questions
Oct 26, 2009 - My Frigidaire oven, model feb24s5asb, door is locked and says f9. The door locked is beeping, I need code to know what the code means and how to unlock it.How do I reset an f9, door ... F-9 Error Possible causes: Door motor failure/jammed. Latch motor switch failure. ... Frigidaire Ovens Gallery 30 in.
F9 Error Code - Can't get it to stop beeping - Appliance Repair Forum
forum.appliancepartspros.com/.../400915-f9-error-code-cant-get-stop-be...
Jan 9, 2012 - 6 posts - ‎5 authors After that it flashed betwed F9 and dr and won't stop beeping. ... say that the last time I used the self clean, the dorr would not unlock and I got similar error codes. ...Frigidaire BFEF374EB1 Frigidaire Canada/electric Range Frigidaire Door Lock F9 error code and now F1
1 post
Dec 6, 2010
Frigidaire Door Lock and F9 error code
Jul 10, 2010
Frigidaire Error Code F20 - Upon Cleaning
Dec 3, 2008
Frigidaire error F-9
Feb 18, 2008
More results from forum.appliancepartspros.com
Oct 29, 2015 | Toaster Ovens
Mi plancha modelo G1490 no calienta, no prenden los lod diodos wool silk y linen coton y max.
follow this steps and fix it. God bless you
f the iron doesn't heat, make sure power is on to the outlet, check the electric cord , and check the thermostat and replace if necessary. If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below).
If the iron produces too much or too little heat, test the electrical cord. Also test and, if needed, adjust calibration of the thermostat .
If the iron does not spray properly, inspect and clean the nozzle (see below).
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
Oct 27, 2013 | Tefal T-fal E9421364 Castiron Plancha...
Euro-Pro Bravetti Model To283B
You may have to start all over again with a replacement oven. Never, never, never use oven cleaner in this type of appliance!
Oct 13, 2013 | Euro-Pro Toaster Ovens
Amana self clean oven has the locke on with the door open I can't take the lock off tu close the oven
Hi there.
Check the door interlock switch, contacts may be bad and needs replacement.
Regards.
Aug 03, 2011 | Toaster Ovens
The interior of my euro-pro kitchen rotisserie convection oven model TO241R needs major soot and grease cleaning. Is there a way to clean it on high temperature setting? If not, please recommend a...
Most toaster ovens don't have a self clean function, because they are not made of the same sturdy metal that full ovens are made of. Clorox Clean-Up works pretty well if you spray it on the grime and let it sit for 5-10 minutes before wiping it away. Let it sit longer for tougher dirt.
May 03, 2011 | Toaster Ovens
How to change the lower element on a delonghi AD 699 toaster oven?
  • Preheat ovens only when necessary. With conventional ovens, keep the preheating time to a minimum. Unless you're baking breads or pastries, you may not need to preheat the oven at all.
  • Food cooks more quickly and efficiently in ovens when air can circulate freely. Don't lay foils on racks. If possible, stagger pans on upper and lower racks to improve air flow.
  • Use glass or ceramic pans in ovens. You can turn down the temperature about 25°F and cook foods just as quickly.
  • Do not open the oven door often to preview the food. Each time you open the door the oven temperature drops by 25°F. Watch the clock or use a timer instead.
  • Full-size ovens are not very efficient for cooking small- to medium-sized meals, it generally pays to use toaster ovens or microwave ovens.
  • Check to be sure the oven door gasket is tight. Adjust or replace gaskets as required.
  • If you have a self-cleaning oven, consider using the self-cleaning feature immediately after regular baking when the oven is still hot. Less energy will be required to reach the cleaning temperature. Try not to use the self-cleaning feature too often.
  • Keep range-top burners and reflectors clean; they will reflect the heat better and save energy.
  • Match the size of the pan to the heating element; more heat will get to the pan and less will be lost to the surrounding air. A 6-inch pan on a 8-inch burner will waste over 40% of the energy.
  • On electric stove-tops, use only flat-bottomed pans that make full contact with the element. A warped or rounded pan will waste most of the heat.
  • When cooking with a gas range-top burner, use moderate flame settings to conserve gas. Also make sure the pilot light is burning efficiently, with a blue flame. A yellowish flame indicates an adjustment is needed because the gas is burning inefficiently.
  • Whenever possible, use a pressure cooker. By cooking food at a higher temperature and pressure, cooking time is reduced dramatically and energy use is cut by 50-75%.
  • Hope this work ..........
    Jul 07, 2010 | DeLonghi AD699 Airstream Digital 1500...
    Oven won't work
    It might be the timer knob needs cleaning. Take it out and clean the 2 leads on it.
    Mar 29, 2009 | Wolfgang Puck BCOB0020 Toaster Oven with...
    Farberware convection broil oven modle T-4850
    I have the same problem. www.repairshack.com has replacement doors but they are out of stock. You may want to check with them to see when it comes back in. Specifically http://www.repairshack.com/detail.aspx?ID=705 or call
    1-888-464-0797.
    Jul 30, 2008 | Farberware T490C 1500 Watts Toaster Oven...
    Farberware FAC900R Toaster Oven with Convection Cooking Logo
    95 people viewed this question
    Top Farberware Toaster Ovens Experts
    Andrew Taylor
    Andrew Taylor
    ray gallant
    Are you a Farberware Toaster Oven Expert? Answer questions, earn points and help others
