Question about Fujitsu 24C1 Air Conditioner
Fujitsu wall mounted air conditioner.
Help! My air conditioner is leaking water into the room. Any ideas?
  • Myrlene Nov 07, 2007
    The AC is leaking water thru the front. I have cleaned the filters and it is mounted right, as it has been here for serveral years. What I need to know is where the drain pan is, so I can empty it. We never got a booklet when this home was built. Just send me the location of the drain, and I am sure that is what is causing this problem. Thank you very much.
  • moby113 Jan 23, 2009
    It is hot time  - and AirCon has been on for few day at 19c - but now start leaking water from the front? Any Help??
 during Cooling and Dry modes, if the unit is used under conditions of
lower temperature (18C)  the heat-exchanger may freeze, leading to water leakage and other damage.
If the unit is used for long periods under high-humidity conditions, condensation may form on the surface of the indoor
unit, and drip onto the floor or other objects underneath. (About 80% or more)
Increase Temp to 20 and also run coil dry cycle,
Posted on Jan 23, 2009
Yes I do. My units were leaking. I had an aircon tech come out and clean the blower. I was full of mold. It is not an easy task. Most aircond techs don't want to touch these units. Each machine took about an hour to clean. I am so glad that I had that done, now the house smells cleaner. Inge
Posted on Oct 30, 2010
Is it a split system? I had the same problem with my split system and and it was because the condenser line was mounted wrong. The line was mounted so the water had to go uphill and it was causing the condensation to leak through the front of the unit.
Posted on Aug 14, 2007
Try cleaning the filters?
Posted on Jun 08, 2007
2 Suggested Answers
  • 105 Answers
SOURCE: Fujitsu wall mounted air conditioner leaks into the room
Make sure the unit is level, this is very important. Check for blocked drain tube, which runs from the bottom of the drain pan under the cold coil to the outside. Clear tube with a piece of coathanger wire, be gentle.
Posted on Jul 15, 2007
WATER COMING THROUG FRONT OF FUJITSU fan coil unit
vent pipes are not sealed properly and condensation is building up and leaking out .
Jun 10, 2017 | Fujitsu 12RLS Halycon Wall Mounted Air...
I have a Fujitsu air conditioner, model # ASUI8CI serial # ACA010576. It drips water into the room from the right side. After switching off the air conditioner and wiping the water, I switch it on again...
chances are either the unit is not level or the drain hose is not pitched properly going through the wall when water is leaking is there water coming out of the hose outside
Jul 11, 2011 | Fujitsu 24R1 Air Conditioner
Our fujitsu reverse cycle AC is leaking water at bottom left hand side of the internally mounted blower unit
Your drain for the inside unit is stopped up and the water condensate that drips off of the coils when the AC is running has no where to go, so it drips off of the collection channel and over flows to the bottom of the air handler, gravity dictates the place where it leaks. You are going to have to unstop the drain.
Feb 01, 2011 | Fujitsu 24C1 Air Conditioner
Hi I have a problem with my Fujitsu wall mounted air conditioner ,model AST24RGB-W the outdoor unit fan is running but there is no cold air coming out from the inside unit I put it on high cool to get cold...
I think, your compressor is not working. Check with amphs meter. If less amphs gas leak. Arrest the leak and re charge gas. If tripping with high amphs change capacitor. Still high amps, compressor is defective.
Dec 26, 2010 | Fujitsu Heating & Cooling
Fujitsu Air CONDITIONER LEAKING AT FRONT INTO ROOM MODEL NO AST18
Ithought the service was free from the advertising..silly me...I use trades people who come and tell me what is wrong , that is a free quote, then I decide what I can afford.
Thank youfor your time.
Feb 01, 2010 | Fujitsu 24C1 Air Conditioner
Water dripping from air con use
If the unit is mounted on an outside wall check the condensate drain that comes out with the line-set to the outdoor unit. If the pipping goes up into the attic than you have a small condensate pump that may have failed. The float in the pump may have stuck in the down position not allowing the pump to come on.
Nov 08, 2009 | Fujitsu 24C1 Air Conditioner
LEAKING SPLIT TYPE AC
drain line is more and likely stopped up
Dec 02, 2008 | Fujitsu 18C1 Air Conditioner
Fujitsu air conditioner - too much humidity
This can happen if the unit is too small for the room. Going by the model number I sounds like a big unit. I would also try cleaning the filters. Also set the temperature higher.
I take the time to help and answer your question so please rate me
Thankyou
Mat
Jul 02, 2008 | Fujitsu 18C1 Air Conditioner
Jun 03, 2007 | Fujitsu 24C1 Air Conditioner
Fujitsu 24C1 Air Conditioner Logo
2,268 people viewed this question
Top Fujitsu Heating & Cooling Experts
Felizardo Erilla
Felizardo Erilla
AJMAL KHAN
Donni Steen
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
