Question about Sony Ericsson K750i Cellular Phone
Fall in water
When i get him out he worked,after 10 minutes nothing
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 72 Answers
Keep in Heat For Nearly a Day.
OR Hold it Below a High POwered Bulb Fluoresent.
Posted on Jan 09, 2009
Tip
What to do if your phone fall into water
first of all remove the phone from the water
then remove the battery but make sure not to switch it on to avoid short circuits inside the phone
then dry it with a towel
then dry it with a hair dryer for at least 15 minutes
then place the phone in a bowl of rice for at least 4 hours
then again dry it with a hair dryer for 10 minutes
and then your phone works as it used to
i tried it several times and it worked
on Nov 10, 2011 | AT&T Cell Phones
Tip
Fight hair fall with natural ingedients.
In summer we sweat a lot. Our head is no different. Due to excessive sweating hair may fall and can create a concern for you. Here are 5 remedies you can try.
1. Mix 5 teaspoon coconut milk, 1 teaspoon Indian gooseberry (Amla) juice, 1 teaspoon water melon juice, 1 teaspoon tender coconut water and 1 teaspoon lemon juice together. Apply this mixture on the scalp and hair. Keep it for 20 minutes. Then wash it off with cold water. You can prevent hair fall.
2. Mix cucumber juice, tender coconut water, raw mango pulp, Indian gooseberry paste, fenugreek seed paste and egg yolk together. Apply this mixture to your sculp. Keep it for some time and wash it with normal water.
3. Due to dandruff hair may fall. The day you put anti dandruff shampoo your scalp is free from dandruff. The same day you must wash your comb, towel and pillow cover with anti-bacterial solution like Detol, Savlon. So dandruff will not come back from these things.
4. Aloe Vera gel is very helpful for hair. It gives nourishment to hair in many respects. It is very easy to collect the gel. You have to just open up the thick leaf from one side. For one person 50 grams of gel is enough. You have to rub the gel all over your scalp and keep it for 10 minutes. After that wash your head with plain water.
5. Please, do not comb your hair when it is wet. Ladies should not make knot when the hair is wet.
on Jan 18, 2011 | Health & Beauty
Water fall into my laptop, whenever i switched it on nothing appear on the screen and also it shut down automatically after 20 secs
did u try to dry the wet portion if not blow hot air trough the slots of body to dry the moisture about 10 min then try to power on
Dec 15, 2013 | HP ProBook 4510s FM849UT Notebook
No it's not beyond the sleep problem but the problem is that I work on my pc will fall to sleep and as I alume alume does not and remains in standby and I have nothing to do that will stop
You can program your "Power Button" to do a lot of things or even nothing.
To program go to "Control Panel" "Hardware and Sounds" then select "Power Options". Here you can "Change When the computer sleeps".
Hope this helps.
May 31, 2012 | Dell Optiplex GX280 Intel Desktop PC -...
Hello...i have a sunbeam filter free warm mist humidifier,and i put the water in and turn it on but it doesn't seem to be working. All the lites are on but nothing and it's brand new too never been used.
Hi, have you given it a while? That humidifier usually takes about 10 minutes to get going. After 10 minutes or so you should be able to feel the warm mist coming out, and soon after you should feel a difference in the moisture in the air.
Nov 28, 2010 | Sunbeam Health at Home Warm Mist...
We poured the amount of water needed to make the amount of coffee desired but 30 minutes later no coffee was made. Does the bottom "warmer" button need to be on or does the maker just need to be...
The tank inside holds about 2 and a hlalf pots of water. Once the tank is full, whatever you pour in will come out. The unit has to be plugged in to make coffee. Leave a pot under the brew funnel and pour a pot of water in. If nothing comes out within a minute, pour another pot of water in. Still if nothing comes out do it again. This time for sure water will come out. It will take avout 10 minutes to get hot enough the first time it is full to make coffee. If you have a thermometer, the water should be about 190 degrees F to make coffee correctly.
Oct 28, 2010 | Bunn VPR Coffee Maker
When trying to set my salt water system the down button works but when I push the up button it doesn't set the pool to 00
Are you holding the up arrow long enough Push hard and steady ti'll it beeps
Then it is short pushes on the up arrow to set time
Then down and up again to lock it
It will take 2-10 minutes for the second light to come on and start generating
Jul 19, 2010 | Intex Automatic Salt Water System for ...
Problem with Maytag MAH2400 AWW
As for the user whose machine will not drain and sounds as though a chain is clanking, the solution is probably a coin caught in the drain pump. I just had the same problem. Access the pump from the bottom of the machine. 4 screws hold the mounting bracket on undo those, the electrical connection and two hose to the pump. Undo three screws holding impeller to motor and coin can fall out. Examine for damage if it is not too tore up, put back together. Keep in mind that when you unclamp the hoses that water will come out.
Dec 28, 2007 | Maytag MAH2400A Front Load Washer
Sony Ericsson K750i Cellular Phone Logo
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
