Question about Canon I960 InkJet Photo Printer
Paper pulling to one side
I have a cannon mp460 every time i load paper it pulls to one side and jams can anyone help me please
  • 3 Answers
Check the paper feeder if there are things blocking one side of paper loading.if so, remove it then try printing.
Posted on Jan 13, 2009
Paper feeder pulls multiple sheets of paper
PULL ALL PAPER OUT OF MACHINE EVEN THE SUPPLY, UNPLUG OR TURN OFF THE POWER TO THE UNIT, PUT A STACK OF PAPER IN THE SUPPLY TRAY & GENTLY PUSH FORWARD NOT FORCING IT UNTIL IT STOPS. TURN POWER BACK ON & TRY AGAIN. YOU MAY HAVE TO REPEAT THIS 2-4 TIMES BUT IT WORKED FOR MY HP DESKJET F4180 ALL IN ONE.
Dec 28, 2012 | Canon PIXMA MP460 All-In-One InkJet...
Please describe your cannon laserbase 5630 showing paper check error after printing one print problem:
Hi mani4u58,
After the print,does the alarm indicator show?
Are the papers loaded and aligned in the correct way in the printers cassette?Please align them well and also note that the cassette can hold only around 250 sheets at a go.Remove the cassette completely when loading the papers and after paper load,insert the cassette as far as it can go.Does the printer feed paper correctly?If not,there may be a paper jam.To clear the jam,open the front cover by pulling it towards you.Remove the cartridge and inspect the compartment.Also make sure the orange adhesive tape around the cartridge is full removed to free its connections.You can also unplug the printer and leave it for a while and then plug it back to clear jam.
Hope it helps.Thanks!
Mar 27, 2011 | Office Equipment & Supplies
My Canon Pixma MP600R insists that paper is jamed in machine, despite the fact that jam has been cleared and paper is being ejected when machine is switched on
The simplest thing would be to try unplugging the printer from the power source. Let it rest for 5 - 10 minutes then plug back in to the power supply and see if that resolves the problem.
If not you are going to need to do a thorugh inspection to verify that all paper remnants have been removed.
The following is for the MP600:
Issue: ERROR LCD: The paper is jammed. Clear the paper and press [OK].
Solution: Removing paper jams MP600
Removing Obstructions or Jammed Paper If [Paper output slot - The paper is jammed. Clear the paper and press OK] appears on the LCD, follow this procedure to clear the paper jam Clearing paper jams from the auto sheet feeder (ASF) or paper output slot
Clearing paper jams inside the printer
Clearing credit card-sized or 4" x 6" paper jammed inside the printer
ASF / Paper Output Slot
  1. Turn off the printer.
  2. Remove paper from the ASF.
  3. Gently pull the jammed paper out.
    1. If paper is visible from the ASF, use both hands to pull the paper out slowly.
    2. If paper is visible from the paper output slot, use both hands to pull the paper out slowly.
      The above illustration shows a PIXMA MP500.
  4. If the paper tears and a piece of that remains inside the printer, open the scanning unit (printer cover) and remove the paper from inside the printer.
    Note:
    Be careful not to touch the components inside the printer.
  5. Turn on the printer and confirm that the Alarm light is off.
    (If the jammed paper remains in the printer, the paper may be automatically ejected.)
  6. Load paper back into the ASF.
  7. Press to clear the message and continue printing. If you are printing from an application software, follow the instructions displayed on your computer.
Top
Paper jams inside the printer
  1. Turn off the printer and disconnect the power cord and USB cable.
  2. Remove the jammed paper slowly using the following procedure.
    1. Open the rear cover to check if the paper is jammed.
    2. Pull out the cassette and check if the paper is jammed inside the cassette area.
    3. Stand the printer with the left side down, holding the document cover.
    4. Press the tabs together and pull the green cover toward you.
    5. Check if the paper is jammed.
      (If you were not doing Duplex printing, you do not have to follow this procedure.)
    6. Close the green cover and place the printer back to a normal position.
  3. Reconnect the power cord and power on the printer. Confirm the Alarm light is off.
  4. Load paper back into the ASF or cassette.
  5. Press to clear the message and continue printing. If you are printing from an application software, follow the instructions displayed on your computer.
Top
Clearing credit card-sized paper jammed inside the printer
Credit card-sized and 4" x 6" sized paper must be loaded properly. If this media is not loaded properly, it will feed into the printer and will not exit. Credit card-sized paper should only be loaded in the ASF and in portrait orientation. 4" x 6" sized paper can be loaded in the ASF or cassette. But must be loaded portrait orientation.
If credit card-sized paper was loaded in landscape orientation in the ASF and did not eject (exit), please follow this procedure.
  2. Load the same paper type that is jammed inside the printer in portrait orientation.
  3. Power on the printer.
    The paper stock in the ASF will automatically feed the jammed paper from the printer.
  4. To resume printing, load the paper in portrait orientation.
If 4" x 6" sized paper was loaded in landscape orientation in the cassette and did not eject (exit), please follow this procedure.
  2. Open the rear cover.
  3. Fold in four a piece of letter-sized plain paper.
  4. Push in the folded paper until it hits the jammed paper.
  5. If the jammed paper is visible from inside the printer area, pull it out and proceed to step 7.
  6. If the jammed paper cannot be pulled out, push in the folder paper from the rear so the jammed paper is in between the feed rollers.
  7. Pull out the folded paper and close the rear cover.
  8. Power on the printer and confirm that the Alarm light is off.
    The jammed paper should automatically eject.
  9. To resume printing, load the paper in portrait orientation.
Trust this is helpful.
Dec 10, 2010 | Canon PIXMA MP600 all-In-One InkJet...
The paper is not feeding through. it is getting caught on one side, then jamming
the roller on one side isn't picking the paper while the one on the other side is. Hwnce the uneven pull on the paper force the paper sideways and then jams.
This is usually caused by dust in the interior of the printer so try this:-
This is sort of scenario could be caused by dust inside the printer. Dust prevents the rollers from having a firm grip on the paper while picking paper. When one roller has a firm grip and rolls the paper well while the other doesn’t, jam/crumpling results. So I will suggest you get a long handle brush and try to reach as far inside the printer as possible and brush (from the back and front; if you have a blower please use it as well). This, if properly done should do it. Brush especially the rollers etc.
Mar 26, 2010 | Canon PIXMA MP460 All-In-One InkJet...
Recurent paper jam on Cannon Pixma MX300
Some printers have a certain paper height or paper load you can have loaded at one time. I would try loading a smaller amount of paper and see if that helps. If it still does the same thing your paper thickness lever may be damaged.
Sep 07, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Mp460 feeds more than one pages
Hi ...
There is no hardware fault in this perticular situation. This happens because of paper loaded. There are 2 possible resolution to this problem:
I) Fan paper prior to inserting it into the MP460
  1. Remove paper from the ASF.
  2. Open the paper output tray. (See <2> in Figure 1 below.)
  3. Set the paper thickness lever according to the media being used. (See <3> in Figure 1 below.)
    Note: For paper thickness lever settings, use the following setings for the media type being used: Right side: Envelopes / T-Shirt transfers. Left side: All other media types.
    * Figure 1
    The illustration shows the PIXMA MP460
  4. Fan out the sheets of paper so that they do not stick together.
  5. Load paper in the auto sheet feeder with the paper's print side facing up. (See <1> in Figure 2 below.)
  6. Align paper to the right edge of the auto sheet feeder. (See <2> in Figure 2 below.)
  7. Pinch and slide the paper guide to the paper's left side. (See <3> in Figure 2 below.)
    * Figure 2
II) Load fewer sheets into the MP460
Don't forget to vote if this helps ... Cheers :)
Jul 17, 2009 | Canon PIXMA MP460 All-In-One InkJet...
Every time I try to print, the printer grabs the paper crooked.
There's a leaver where the paper comes out, make certain it's to the left when printing with paper and to the right for envelopes.
Jun 14, 2009 | Canon PIXMA MP460 All-In-One InkJet...
Jamming problem
try this
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Mar 06, 2009 | Canon PIXMA MP460 All-In-One InkJet...
Cannon mp780 paper pulls to right hand side and jams everry time
printer loading tray have problem /something struck at left side of tray /check if something/if none / sometime it connot be seen its hide five cents .
clean also the incoming roller and outgoing rooler w/cotton tips w/ rubbing alcohol. test the printer.
Jan 08, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Paper Jam!!--Only one side pulls
Call Canon. I'm on the hold with them at the moment... Just finished speaking with them. They are sending me out a new printer, free of charge and including ups shipping label to send back to them. Sending the one I have back in the new box. Give them a call. They were really helpful and tool all of 5 minutes. Good luck. Kim
Apr 30, 2007 | Canon Pixma MP500 All-In-One InkJet...
Canon I960 InkJet Photo Printer Logo
79 people viewed this question
old marine
old marine
