SOURCE: Cd stuck
unplug the unit and as you plug it back in start pressing the eject button in one second intervals as it powers up. This should command it to eject before it tries to read the disc.
SOURCE: adding turntable to bose music wave system
Hiya, sad to say it wont work even with the correct plugs. If you really need/want to get it going, you will need a RIIA pre amp to use to convert the turntable levels to an acceptable level for the bose. Once you have that, then get the correct matching plugs for the bose (sames guys that supply the preamp should be able to help). Suggest a google search in your area "RIIA PREAMP" and see who supplys.
Best of luck
SOURCE: I have an older Bose Wave radio without a CD. Can
If it has another input then yes if not you will have to get a A/b switch.
SOURCE: my bose wave radio II remote is not working. I
It will work without the remote, but can ve very unconfortable. If you have a webcam or digital camera or cell phone with camera, then point it to the small lamp in front of the remote and press any button. If the light blinks or keeps on, then the problem may be on the radio receptor. If light is dark, then take it to an electronics store an ask for an INFRARED LED DIODE replacement. This should work well.
SOURCE: what type of battery goes in the remote for a BOSE
We have a Bose Acoustic Wave Audio System II, and our remote uses nickel metal-hydride batteries CR2032.
