Question about Irons
Replacement parts for homedics ps-200 steamer
I need a replacement for the water tank for my ps-200 steamer. Any suggestions?
    New Friend:
I'm looking for same thing.
Posted on Jun 10, 2016
4 Suggested Answers
SOURCE: Need a User Manual
my home touch ps200 has the reset button that wont reset ?
Posted on Mar 22, 2011
SOURCE: water left in steamer - need to clean clear tank
I'm willing to try this to clean the mold out of the steamer container and possibly the rest of the attachments:
1. Empty the water reservoir completely. 2. Place 20 mL of CLR or bleach into the reservoir. 3. Fill the reservoir with hot water. 4. Shake the reservoir to mix and let stand for about 1 hour. 5. Empty the reservoir completely. 6. Rinse the reservoir 3 or 4 times with cold water. 7. Fill the reservoir with distilled water. 8. Run the steamer into the ventilated air a couple of times to ensure that there is no CLR or bleach residue on the evaporation elements. Thus, there will be no bleach on your cloths.
I have the same problem and will try this out tomorrow. I will tell you how it turns out.
Posted on Aug 07, 2009
  • 1335 Answers
SOURCE: i need to purchase the thermostat/steam generator
I would call a Rowenta service center to find the part and cost. If you are in the US go to the After Sales Service, Service Centers at
http://www.rowentausa.com/rowenta/frame.aspx
If you are outside of the US go to the www.rowenta.com site and select your country.
Posted on Aug 09, 2009
Use Manual Garment Steamer Model PS-300
If you have the Home Pro Professional Garment Steamer PS-300 from Homedics, the Homedics website has the manual on their support page. Go to http://www.homedics.com.ph/instructionbooks/ .
then use the drop down menu to select the PS-300. Click on Download to get the instruction book. Note: the file is a PDF, so you will need Adobe Reader or a similar program to read the manual.
I hope this helps.
Jan 20, 2014 | Irons
Iron with auto shut off will not restart, why?
The thermostat is the problem, I used aew3656's solution posted elsewhere, and took care of the same problem on my steamer, just take out the damaged thermostat and use it as a sample to get a new one from any electronics supply store, BTW dont forget to buy thermal grease, it helps dissipate the heat so your steamer won't overheat, and the thermostat wont't go off every 2mins.
May 25, 2010 | Homedics PS-200 Iron with Auto Shut-off
PS-200 Iron with Auto Shut-off: Can you really fix problems with a steamer? Is ...
The thermostat is the problem, I used aew3656's solution posted elsewhere in FixYa, and took care of the same problem on my steamer, just take out the damaged thermostat and use it as a sample to get a new one from any electronics supply store, BTW don't forget to buy thermal grease, it helps dissipate the heat so your steamer won't overheat, and the thermostat wont't go off every 2mins.
May 16, 2010 | Homedics PS-200 Iron with Auto Shut-off
No steam coming out
Is the red overheat warning ligth on? if so, press the reset button, that should reset the thermostat and make it work again.
Mar 13, 2010 | Homedics PS-200 Iron with Auto Shut-off
Plugged in, reset button is lit, won't go off
The problem is the thermostat (NC 150 C). A replacement is available at Digikey.com, item R2015025 (part no. 317-1468-ND) It's a simple replacement with the bottom removed.
Apr 20, 2009 | Homedics PS-200 Iron with Auto Shut-off
The ps 300 will not heat although the on light is on
I bought one of these units at a Salvation Army Store still in the box brand new. I experienced the same problems (power was lit, but the breaker would trip and turn unit off). I opened the unit up and since I have knowledge of circuits, I bypassed the breaker (trips when it reaches a predetermined temp). I did however add a CRUCIAL electrical component that makes this possible an keeps your house from burning down - a added a simple dial thermostat (like one from a single electric plug-in coil stove top). Bottom line, I took on this project moreless for fun and I would NOT RECOMMEND anyone try this unless you have some knowledge about electrical circuits.
Feb 18, 2009 | Homedics PS-200 Iron with Auto Shut-off
Home touch 300 no steam coming out
Hold the hose straight up fully extended for several seconds--it says to do this in the manual--and works great
Nov 15, 2008 | Homedics PS-200 Iron with Auto Shut-off
Would you return this PS200 steamer?
If the steamer starts making a "gurgling" noise, like its running out of steam, hold the hose straight up for several seconds. It says to do this in the manual and gets the steam flowing again--works great!
Jun 13, 2008 | Homedics PS-200 Iron with Auto Shut-off
Irons Logo
2,460 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
