Question about Sony VAIO PCG-K35 Notebook
The screen brightness is dull
The screen brightness on my vaio pcg41m is dull and dark, unable to restore to correct level
  • HW_Dude
    HW_Dude May 11, 2010
    Assuming software was not changed recently in anyway, does the brightness seem to change or flicker at times when you move the screen ?
    Does the lower part of the screen warm up a little bit ?
Monitor is set to 100%--still too dull
If the picture is dark, on screen brightness will not overcome this.
Apr 01, 2014 | IBM E74 Monitor
I DONT SEE ANYTHING IN MY SCREEN BUT TOTALLY DARK
If you shine a bright light at the screen and you can see something, the back light/inverter may have failed. If nothing at all, check on an external screen.
Mar 22, 2014 | Sony VAIO Notebook
Image very dark
go nto the main setting and clear everything and reset it you will have to start from new but the brightness will improve
Apr 29, 2013 | Optoma MovieTime DV10 Multimedia Projector
The color is very dull with the exception of red everything has a red tint to it other than that the rest of the 50" screen is very dark. Watching t.v. or movies are out of the question the color is...
Thats a very common problem caused by bad CRT coolant which will need replacement to restore the set back to normal colors and brightness levels. You can get the CRT Coolant kit at www.tvrepairworld.com which fits your model. The kit contains the coolant for all three CRTs and the CD with instructions.
Jun 24, 2011 | Philips Magnavox 51MP392H Rear Projection...
Leapster 2 screen to dull to see
The leapster 2 screen is so dull you can hardly see the writing and programs. Very dark in colour. You can see colour arounf the edge of screen but the darkness overpowers the screen.
Jun 06, 2010 | LeapFrog Leapster 2 Learning System
How to adjust the brightness on my sony vaio pcg-k17?
To adjust the brightness control, press Fn + F5 and release, plus the RIGHT ARROW or LEFT ARROW keys to increase or decrease the value.
On most notebook computers you can use the Fn+F5 keys to lower the screen brightness level, and the Fn+F6 keys to raise the screen brightness level.
May 18, 2010 | Sony VAIO K45 Notebook
Screen goes dull at times
The dulling picture really sounds like a lamp failing. You would need the sony lamp xl-2100u
The ghost image may be easier to fix, sometimes as lcds age you will get a slight shift in a color. deep in the sony menu there is a parameter (menu-setup-imageshift) that will give you 3 levels of correction, this may solve this issue.
Dec 04, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
My screen on my camera is very dull and its very hard to view my pictures. model number dsc-t5
go to a dark area or switch off all the lights to view the screen...or see if your camera has an adjustment to control screen brightness
May 11, 2008 | Cameras
Sony vaio screen dark then light
your laptop inverter is going bad. need to replace. you can get it on ebay cheap. the inverter is responsible you the lighting up of your screen. thats the solution REMEMBER TO RATE THE SOLUTION
Apr 09, 2008 | Sony VAIO VGN-N130G/W Notebook
Sony VAIO PCG-K35 Notebook Logo
270 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
