Question about Intex 2500 Gal Easy Set Swimming Pool Water Filter Replacement Pump only
Setting up of Intex pool filter
We bought a second hand intex 14 foot metal frame above ground pool but are unsure on the setting up of the pool pump/filter. It did not come with an instruction manual. Please help
  • Chris May 11, 2010
    What kind of pump did you recieve with the pool? Wall-mounted or ground unit? And are there any holes in the wall (approx. 2-4 in.)?
  • 77 Answers
SOURCE: Looking for an intex filter pump
The best solution to this problem not to find a replacement intex pump/filter. I suggest getting a system with a 50 square foot cartridge filter and a 3/4 hp pump such as hayward or pentair offers. You will be amazed at the difference a little quality can make.
Posted on Apr 28, 2009
SOURCE: Intex filter model 633 with no instruction manual on how to set i
You can go to the website for Intex products and once you get to product section you can find and download a pdf manual
Posted on Aug 05, 2009
SOURCE: need instruction manual to set up my pump for intex easy set up
The correct website is intexstore.com
on the right side, about half way down the page there is a blue box that says instructional set up video and manuals. You then click on pumps and on your model, and you can open it there.
Posted on Aug 24, 2009
  • 10865 Answers
SOURCE: I need the instructions to set up a 18 round metal
Hello. Go to the link below, enter the model and year of your pool and then you can select a video and or a downloadable manual of instructions. Joe
http://www.intexcorp.com.hk/proifv/proifv_dl_client.jsp?source=intexstore
Posted on May 07, 2010
MOTORWIZJ
  • 1383 Answers
SOURCE: how do you prime the pump for intex ubove ground
THIS HAS PRESSURE ON THE PUMP WHEN IT IS HOOKED UP TO THE POOL , NO PRIMING IS NEEDED. NOW IF IT'S HIGHER THAN THE WATER LINE OF THE POOL THIS KIND OF PUMP WILL NOT WORK , YOU NEED A PUMP THAT HAS A HAIR BASKET . THESE YOU FILL THE BASKET UP AND REPLACE THE LID AND YOU PRIMED IT.. . IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
Posted on May 26, 2010
Wish to upgrade cartridge filter pump to sand filter pump. Pool size 15' X 48" / pump 1000 gph - 637R /Item no 56945 Which intex sand filter is the best one?
First, understand that sand doesn't filter as finely as cartridges, so "upgrade" may be the wrong word. Cartridges filter down to about 10 microns, sand filters to 25-30 microns. (i.e.the cartridge will catch particles up to 3X smaller than sand will.)
If you still want to change, get the biggest sand filter available that you can comfortably afford. For superior results look at above ground pump/filter packages built by Hayward or Pentair. Intex products are just built to margin and are not designed for long term usage.
Aug 31, 2013 | Intex "" Metal Frame Pool Set (56998e)...
How do i connect a salt water system to the pool
if you use a salt system in an above ground pool, the steel frame work will last less than 2 years before it rusts out
talk this over with the pool experts first and then have them help you with the system needed
Oct 25, 2017 | Intex Automatic Salt Water System for ...
24' x 52" metal frame pool, need copy of set up manual.
I don't have an instruction manual for this particular pool, but I do have general installaton instructions for above ground pools with metal frames and liners. The pool liners are the same to install no matter what type of pool you have, so this should help!
Jun 09, 2010 | Intex "" Metal Frame Pool Set (56998e)...
Where does the skimmer sit on an intex metal frame pool
i have mine sitting about a foot to the right of the intake on the pool, that way it keeps a clear line from the skimmer to the intake to the pump/filter to the outlet
May 30, 2010 | Intex "" Metal Frame Pool Set (56998e)...
How much salt to start with a 15ft round pool
Assuming you have the Intex salt water system and the easy set pool, here's what the manual says:
15x33" - 65 pounds (80 for metal frame)
15x36 - 65 pounds (100 for metal frame)
15x42 - 80 pounds (110 for metal frame)
15x48 - 95 pounds (N/A for metal frame)
hope this helps!
May 28, 2010 | Intex Automatic Salt Water System for ...
Hayward pump hose and intex pool
Im thinking that hot glue would not harden completly in a direct sun situation not to mention the potential mess
What I did was go to my local hardware store and bought rubber o rings ( sorry dont remember what size) put them on the fitting slipped the hose over it and clamped on top of that area. Has been fine all summer
hope you figure it out
Aug 04, 2009 | Intex Automatic Salt Water System for ...
Apr 07, 2009 | Intex Krystal Clear Model 635 Pool Filter...
Intex 2500 Gal Easy Set Swimming Pool Water Filter Replacement Pump only Logo
732 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
