Question about Zanussi FJD1266W Front Load Washer
E90 error flashing on screen, manual has no error reference E90. Wash starts at 59 minutes but 20 minutes later may only show 54 minutes remaining and will not progress through wash cycles. Display panel also loosing light display periodically.
Electrician checked wires in pcb board and display panel
problem corrected
Posted on Jan 11, 2009
What does e90 mean?
  • E90 Error - YouTube www.youtube.com/watch?v=IhHvw2K7XO0
    • BY D CUTHRELL
    • 3 MIN
    • 24K VIEWS
    • ADDED 2012-11-16
    Video embedded ยท E90 Error Code on Frigidaire Washer cleared with Hair Dryer.
  • Frigidaire E90 Error ' eHow www.ehow.com > Home > Home Appliances > Washer & Dryers Frigidaire E90 Error. Frigidaire front-loading washing machines offer a control panel with keypads to set the desired wash cycle and any options, as well as monitor ...
  • Zanussi Washing Machine displays an error code E90.? howtomendit.com > ... > Household Appliances, Washing Machines How to fix anything. Free repair help - zanussi washing machine displays error code e90.
  • Dec 23, 2015 | Washing Machines
    My washer stops &and F-20 appears on viewer. Whats wrong with my washer
    water problem check screens in hoses and valves !! rrors F1, F11 and F20
    • Error F1 indicates a communication error between the computer and the washer. Unplug the washer for a minute and plug it back in, as this may correct the problem. Error F11 indicates a motor control error. It can be caused by improper voltage. Unplug the washer and check the connections. This may fix the problem. Error F20 indicates lack of water entering the machine. If there is no water in the washer, check that the water valves are turned on. If there is water in the washer, press "Stop" twice to drain the washer. Unplug the machine and check the hose connections.
    Read more : http://www.ehow.com/info_12006668_error-messages-kenmore-he2-plus.html
    Feb 21, 2015 | Kenmore HE2 Plus Front Load Washer
    When I run the 59 minute wash it ends with Error E14 code, short washes end OK.
    WOW 1 cycle is 59 minutes sounds like a big waste to me .most of ours on a non computerized machine might take 30 hour total
    Jan 28, 2015 | Washing Machines
    I have a 10 beep continous and showing e90 on my frigidaire washer, what will i do?
    E90. The E90 error code is not a common error but it may occur when the washing machine electronics get wet for some reason. This may happen if wet clothes are left in the washer for a prolonged period after the wash cycle ends or if the same load is washed repeatedly.
    Basic Reset
    One of the first steps whenever an error code appears on a Frigidaire washer is to perform a simple reset to the machine. To reset the washer, press and hold the "Cancel" button for 15 seconds. Then try to set a new wash cycle and press "Start." Note that any clothes that have finished washing should always be removed promptly after the cycle is done.
    Feb 26, 2014 | Frigidaire Washing Machines
    E90 error
    If the cancel button reset does not remove the E90 error code from the display, try a full power reset. To accomplish this type of reset, unplug the washing machine and wait 15 minutes or more. Then plug the washing machine back in and make a new wash selection. If the error code does not return, normal function may resume.
    Unfortunately, if the cancel button and/or full power reset attempts do not eliminate the E90 error code, it is very possible that the electronic control board will need to be replaced. Here is the board to order.
    Nov 29, 2012 | Frigidaire FAFW3577KR - Affinity 3.5 Cu....
    I have a electrolux front loader ewf 1087 that shows the code e90 on start up...i have cleaned the plug that the blue wires go in to & still flashes e90 con soneone help..thanks
    The E90 error code is not a specific code. The error code E90 is just a group error code. It is indicating a communication error between the two boards in your machine. It does not indicate where the problem may be. A power glitch may have caused the E90 error code or a loose connection. One of the control boards could have failed. If it did not clear by unplugging the washer, I recommend a technician come out to properly diagnose your washer
    Jan 10, 2011 | Washing Machines
    All lights flash and error E90 shows on my Zanussi ZWF1631 washer
    e90 is a cable problem linking main board to user board on the front
    Jan 12, 2010 | Washing Machines
    An error message E90 is flashing on my Zanussi washing machine (wdj1294 I am not sure if this is correct) and beeping. I can't turn off the error and obviously the machine won't start a wash as I also...
    don't know exactly what e90 means but each time it happens we turn of the power on wall switch for a half hour and the problem seems to right itself
    Jul 07, 2009 | Washing Machines
    Electrolux 1087 E90
    call frigidaire for factory service or have the dealer replace it
    May 08, 2008 | Frigidaire ATF6000ES Front Load Washer
    LG WM2077CW (UE error code)
    For "ue" an unbalanced load is sensed three times; re-adjust your load in the machine. What is the capacity of your machine, you could weigh your dry clothes........refer manual.
    For e1, it could be a water sensor problem. Check to see if the inlet valve is okay and not clogged, water shd be in good pressure. If this is okay, open up behind after taking the plug off the wall. There is a thin tube coming from the switch area to the outlet pump area; disconnect this from the top carefully and blow into it, it should be free; if it is clogged you will hav a water level problem. Unblock and refit carefully.
    .....& rate me if helped.
    Jan 09, 2008 | LG WM2077CW XL Front Load Stackable Washer...
    Zanussi FJD1266W Front Load Washer Logo
    308 people viewed this question
    Top Zanussi Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
    Richard Roth
    Richard Roth
    Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
