Question about GE GSL25JFR Brushed Steel Side by Side Refrigerator
Water/Ice machine controls acting up
For almost 2 years this fridge has worked great, but now we have a little problem. The only button on the front ice/water dispenser that works properly is the lock button. The others kind of work, by this I mean when they are pushed they switch to the selection. If the blower in the refrigerator side is blowing when a button is pushed it stops and then about 10 seconds later comes on again. I did it a few times to make sure that it wasn't coincidence. Also when you take a cup and push the switch to get some ice or water you get nothing. Instead of the light coming on like normal when the switch is pushed in, it comes on afterwards. Also when the switch is pushed in there is a clicking noise at the control board in the back of the fridge. I have looked at to see if any fuses were blown, but the fuse is ok at the bottom of the board. The clicking seems to be coming from the top part of the board. Sorry if this is a bit much, but wanted to include all details that I could think of. Bob
  • Robert Bice Jun 04, 2007
    Thank you for the reply, but now it is doing something else as well. Now, it almost seems like it is in a loop of clicking. I can hear the blower motor try to come on then there is the clicking sound from the relay, it stops and then starts all over again. Doing this in about 7-10 second cycles. I did find that on the control board on the back there are 3 plugs on top with wires attatching to them and then under them in the middle there is another plug by itself. When this plug underneath in the middle is unplugged the whole clicking, blower cycling stops. Any ideas as to what that controls. I am all for repairing this myself, but am also realistic that I may need to call repairman if I am unable to figure out what it is. Could it be something as little as that relay has burned out or do you think it may be something more in depth? Thank you for any insight.
    Bob
  • Robert Bice Jun 19, 2007
    I finally broke down and called a repairman the other day. He confirmed that it was a relay that was bad, but then he pleasntly surprised me. He told me that GE was having a lot of complaints about this type of problem and they issued some type of factory recall. He replaced the main board on the back panel and didn't charge me a dime. He told me that GE was footing the bill. Thank you again.
I had the exact same problem with the same model refrigerator. I wound up ordering the part from GE and was charged $69.95, there was no cheaper price elsewhere. The service rep couldn't give me a discount, but it's a lot cheaper than a service call (or replacing the food). GE should reconsider its 1 800 "GE CARES" phone number though. You get the feeling they don't.
Posted on Aug 21, 2007
  • 883 Answers
The clicking noise is likely a relay that turns on the selected function. if you see some square shaped (about one inch by 1.5 inches tall) plastic parts on the top of the board, touch them while someone pushes a switch. if you can feel and hear the click, then this is normal. still do not know of your solution though.
Posted on Jun 03, 2007
SOURCE:
My ice machine stopped working on my fridge it's only 1 and 4 months old.any suggestions
If a year old there is no warranty for the ice maker or the dual water control valve. Feel around the ice slots to see if there is still sitting there? What is the model number of your fridge? If the ice tray slots are empty fill with tap water until near full and if the water freezes and the ice maker drops the ice into the ice container the problem will link to a water control valve problem. If there is ice in the slots and ice maker is on and does nothing then the problem is the ice maker and it will need to be replaced.
Nov 23, 2015 | Refrigerators
My freezer stopped working
couple things to check, make sure your adjustments are all set for the middle, freezer and fridge settings,, also pop the front grill from the bottom and make sure your coils are clean, I do my freezer andfridge twice a year, Sometimes people try to set a freezer colder or a fridge colder and it messes with the way a freezer works that is why i say make sure your settings are in the middle.
May 31, 2015 | Refrigerators
I have a subzero BI42 SD fridge. Just replace the water filter. It now does not make ice. Turned on the icemaker but get a blinking ice indicator on the control panel. Looked into the trouble shooting...
this is abrand new fridge.if the ref is less than 2 yr old. better call a tech. your problem FOR SURE. water valve, ice maker, or a combination of 2. also tell your tech. to check the arm in the i.m. and the brackett. do not trty to replace the ice maker. is a little tricki.(SUBZ.less than 2 years old is cover by the manufactor subzero. zero money for you.)
Apr 19, 2010 | Sub-Zero Bottom Freezer Refrigerator
Fridgidaire Mini Fridge not cooling
pulled off back panel on inside of freezer, to find it was a solid block of ice. thawed, and plugged back in... working properly
Feb 08, 2010 | Electrolux Refrigerators
I have a LG LSC26905SB refrig that has stopped getting power to any part of the fridge. The compressor does not run and the lights do not light up on the front (water/ice area) or inside the fridge. I...
Possible control board failure ...you may notice the freezer lights do work but nothing else.There is a diagnostic push button on the board located on the top of unit under a panel where the power cord enters. andrews electronics .com is the oem provider for this very expensive control board.
Jul 12, 2009 | Refrigerators
Hooked up waterline to side by side frigiedaire,
Your inlet tube that goes to the icemaker may be frozen. To Check: Shut off water supply to Fridge, disconnect the water line that goes to the icemaker at top back. Use a flexible item to insert in the water line connection. I used a zip tie. If the flexible item won't all the through to the ice maker, the line is frozen. Thaw out the tube from inside the freezer with a hair dryer. Re-connect everything, you now have ice . . . Solution #2: You may have to replace your "Water Inlet Valve" located at bottom right rear of Fridge. Easy to do, just follow the color codes, be sure and shut off the water.
Jun 12, 2009 | Frigidaire GLRS264ZA Side by Side...
Ice and Water not dispensing. Light button not working
INSIDE THE DISPENSER ASSEMBLY IS A SEPARATE ELECTRONIC BOARD THAT CONTROLS THE DISPENSER.
OCCASIONALLY, THE DOOR SOLENOID OR THE CUBE ICE SOLENOID WILL SHORT OUT CAUSING A BURNOUT OF THE DISPENSER CONTROL BOARD. CHECK FOR A BURNT SMELL COMING FROM THE DISPENSER HOUSING. IF YOU SMELL IT, THE BOARD AND/OR SOLENOID NEED TO BE REPLACED.
Apr 10, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Relay clicking, not cooling either side
check you paperwork , and manual. sounds like a compressor issue, which "should" be covered by 5 year manufacture warr. reason i say "should" is hte warr's all changed jan1/06. only one year form there . but check your manual itll have the warr info in it
Mar 20, 2008 | Hotpoint HSM25GFRSA
GE Model TFF24RWC Side By Side Ice/Water not Dispensing
I had that issue and a myriad of other issues with my GE side by side fridge. I replaced the control panel $100 and all three problems I had went away immediately.
1. Ice and water dispenser quit working
2. Howling noise 12 hours out of the day
3. Clicking noise
Jan 06, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE GSL25JFR Brushed Steel Side by Side Refrigerator Logo
106 people viewed this question
Top Refrigerators Experts
Sal De
Brad Goodale
R.A. Ellis
R.A. Ellis
