Question about Microsoft Ethernet MN-120 Network Adapter
Limited connectivity within Wireless Network
I have several computers and a games amachine connecting to my Orange Livebox. In trying to add another Windows XP SP2 machine with Linksys 54G PCI card to the network I get a limited connectivity message. The signal strength is good, but when I examine the settings for the connection I see a private IP address of 169.xx.. and a DHCP setting of 255.255.255.255 which is diagnosed as an illegal DHCP address with Net diagnostics through Windows Help. I also get a statement that the IP address is set to automatic private address, but I can't find out how to change, or what is causing the mismatch.
  • 85 Answers
Reinstall ur lan drivers then contact ur service provider
Posted on Jan 30, 2009
I have lost the password for my LIVEBOX C640 router on orange. I am connecting a new NETBOOK but it keeps asking for the password. My original laptop still operates on the router wireless
If you have forgotten your wireless security password then you need to add new password because it is saved in * and # format so you need to add new code.
You need to configure your router.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on wireless settings enable wireless then enable WEP Security then add WEP code .It isyour password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Let me know if you need further assistance.
Thanks for using FixYa.
Apr 05, 2010 | Computers & Internet
Can you explain to an idiot, which exactly what is the correct way to connect Powerline Adapters to orange livebox, I have connected Powerline Adapter to yellow ethernet socket is this correct with the...
Plug the PowerLine adapter into the wall
Plug one end of the ethernet cable into PowerLine wall adapter
Plug the other end of the ethernet cable into the Orange LiveBox
Plug the Orange LiveBox power adapter into the wall
Mar 09, 2010 | Powerline Ethernet Network Adapter
Wireless connection using livebox and belkin usb adaptor
You most likely need to reconfigure the livebox settings. The Livebox lost the settings because it was unplugged too long. Most router settings can be accessed by typing in 192.168.1.1 or 192.168.0.1 in the URL address bar of any web browser. From there, make sure that all other switches and devices on the network are on the same network. Meaning if your Livebox default gateway is 192.168.1.1 make that the switch that other devices are connecting to the network through are assigned the IP address 192.168.1.x where x is any number other than 1. I hope this help, I know its not comprehensive enough but once I'm a 'Guide' you will be able to chat with. Then we can have conversation via IM Chat. This is my area of expertise.
Jun 17, 2009 | IBM (34L1209) Network Adapter
X box 360 wont connect to orange livebox!!!
there could be a problem with the xbox wireless adpter which it maybe a fautly item
Feb 18, 2009 | Microsoft Xbox 360 Console
Girlfriend has new aspire one we are trying to connect to home wireless network on orange with a live box acer was set up to someone else's network we can get it to see livebox on acer but will not connect...
You need too set up a totally new network.goto networks,click setup new network and follow the instructions. You will need the password for the livebox and more than likely need to call your network provider. If you have a desktop pc in the building its probably easier to set up a Home network
Oct 25, 2008 | Acer Computers & Internet
Belkin wireless adapter g usb
WPA is safer as all in all it's a lot harder to crack due to being a lot more characters in the passkey. The easiest thing to do would be explain how i have mine set up. And you could compare the 2.. As i have XP Desktop & Vista aswell. So your Laptop connects ok now but is still an unsecure network.. On your Dektop. When you try to connect. Are you entering the 26 character key on the bottom of the livebox?
The main thing to realise with the Livebox is everything is reversible.. And to not worry about changing something..
So let's get this started, When you open up the " Connect To A Network " you can see your Livebox-XXXX. Next to that does it say "Unsecured Connection"? If this is the case then your Livebox is still not properly configured.. What i would recommend doing is starting a fresh with the Livebox, and i explain how to set it all up from Default. icon_smile.gif
IF you don't remember your internet login details then go to "Configuration.adsl" and click My Services then Internet. Your info will be in there. Hopefully you remember your password.. icon_smile.gif
If you don't know how to do a reset of your liveox. Press and hold the "1" button on the back of your livebox. Unplug it from the mains whilst still holding the "1" for 10 seconds. Then plug it back in. [ still holding the "1" ] The lights will flash a bit and after a minute or two it will go back to normal.
Go back to "configuration.adsl"
Username: Admin
Password: Password
If i start from the top section and work down it should make it easier to follow:
My Services>Internet>Connection Parameters Filled In..
Phone Over ADSL> Nothing needs changing
Digital TV> Nothing Needs Changing.
Liveprinter> Nothing Needs Changing.
Submit
Security> Associated Devices> Will Be Empty
Firewall> Medium
Wireless Connection> Channel Number> 11
Security Key(WPA-TKIP)> Same As What's On Bottom Of Livebox.
Enable Wireless Lan> Ticked.
Submit
Configuration> Update> v5.10.7-uk
Administrator> Change the password while you're there..
Submit
Advanced> Wireless> Pairing Time> 10 minutes should be fine.
Your Livebox name can be left as it is.
WPA Security Only
Wi-Fi Easy Pairing.. Might aswell leave it on..
Submit
Now if we set up your laptop first.
Go into Connect To A Network. Your Livebox should be there. It also SHOULD say Secured Network. If there is a Red Cross then you will need to do what i suggested yesterday on my previous post.
Go back to connect.. Enter the 26 char. passkey with caps lock on.. And you should be connected no problem.
Now for the Desktop.
when you log on.. In the taskbar in the bottom right should be something to do with wireless networks. Double click this.. If it mentions something about using the software that came with the device.. Then use the software.. If not then windowsXP will show your network. Double click it.. Enter the same 26 character code.. And you SHOULD be connected.
Let me know if that works.. Sorry for the really long post, but detail is something i do quite well... icon_smile.gif
May 26, 2008 | Computers & Internet
Orange Livebox and NIC
Sounds like an internal problem with the Orange Livebox NIC controller.
If you have an other router Lynksys/belkin you could try it would isolate the problem definitively
Nov 26, 2007 | Powerline Ethernet Network Adapter
Can't set up wireless connection
  1. Check in your system: Click Control Panel, then double click System. On the Hardware tab click Device Manager. Click the (+) sign besides the Network Adapter. See if the Packard bell wireless adaptor is there. If its is not there, right click the Network Adapter and click Scan for hardware changes, and reinstall the network adapter.
  2. If the Packard bell network adapter is already there, click Start and click My Network Places. On the left side of the Network Connection, click View Network Adapter. The wireless network adapter should be there. Right click the wireless network adapter and choose properties. Give check mark on Show icon in notification area when connected (to show you if there is wireless notification), and give check mark to Notify me when this connection has limited or no connectivity (to show if the wireless network is disconnected). and click OK
  3. Turn on the orange broadband livebox. And right click the the wireless network connection (on Network Connection) and choose View Available Wireless Networks. And the click the Orange broadband Livebox to use this wireless Network connection.
I hope this solution is helpful to solve your problems
Best Regards
Blackrobin
Nov 16, 2007 | Computers & Internet
Connecting powerline ethernet adapters through orange livebox
Try to eliminate the problem into smaller parts. Try networking the two via the same power outlet via a multiple power board first in the same room. I don't have much experience with these powerline ethernet but i'm sure the configuration of these will be very similar as wireless router / access points and wireless adapter cards. However what I do know is that your power outlets need to be on the same "phase" of your electrical power system, so if you do this test I suggest (from one outlet board) you know the equipment works and your setup procedure works. then try seperating again and if it still doesnt work, check if your power outlets are wired on seperate phases (depends if your house has 3 phase wiring incoming to your home or not). Try another room or another outlet.
Oct 13, 2007 | Powerline Ethernet Network Adapter
Wireless probs Packard bell notebook L4
Their website has help with your setup and problems... here is the link below http://www.orange.co.uk/time/livebox/ Hope this helps Was my solution helpful? Please rate Thanks in advance
Sep 14, 2007 | Intel Anypoint Network Adapter
Microsoft Ethernet MN-120 Network Adapter Logo
260 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
