Question about Toshiba 46H83 46" Rear Projection HDTV-Ready Television
BLACK BOX When I try to play a DVD I get a black box on the screen. I have tried several ports and playback units with the same results
  • 2 more comments
  • timb44266 Jan 09, 2009
    no picture behind the box. Box is black
  • timb44266 Jan 10, 2009
    I have tried three different portable units. I even plugged into the front of the set. The same black box appeared. The picture around the box is fine. The box may go away for a few seconds but always comes back. But only when we try to play a DVD.
  • dhurt May 11, 2010
    Might sound stupid, but is this a portable DVD or a home DVD that oyu are hooking up?
    Can you see the movie behind the box, or does it not play at all?
  • 43 Answers
Sounds like you have your "closed caption" feature turned on. Go into your TV menu and turn it off.
Posted on Jan 12, 2009
If I tell you will you send me 9.99
Posted on Jan 10, 2009
Technika tv/dvd the dvd is only in black and white and wont play the discs
you can try using a DVD cleaner disk on your unit, try several times to make cretin it is clean then try your DVD`s again, if the unit was stored in a damp area this may be a problem, DVD players can be finicky due to this, there may also be a manufacturing defect in the unit that made it fail prematurely.
Jan 09, 2012 | Televison & Video
Black box won't go away during DVD play
is it just during dvd's or does it happen at other times
Sep 25, 2008 | Sony KP-53S35 53" Rear Projection...
Sony cd/dvd player dvp ns67p with black screen show
try switching the plug ins ( the colour wires9red,white,red)
Dec 16, 2008 | Sony DVP-NS300 DVD Player
Black box covering one-half of TV screen
Try turning off the text box function of the closed captioning.
Aug 02, 2008 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Black box on top of screen during HDD playback mode
Problem solved! Thanks Panasonic Tech Support!!
In case anyone else has this problem, I'll tell you what I found out. This model DVD recorder does not have closed captioning functionality at all. So if this happens to yours, it is not the DVD recorder causing the problem. It is a setting on either your TV, cable box, or whatever else you have hooked up to it.
In my case, my daughter must have accidentally hit the "Text" option on our TV's caption menu. I changed that option back to its original setting, and the mysterious black box is gone.
Jul 29, 2008 | Panasonic DMR-EH50 DVD Recorder
Black screen instead of DVD playback
try changing the dvd drive speed in the system configuration, it may be at standard, change it to fast
Jun 25, 2008 | Sony PlayStation 2 (PS2) Console
VHS play back
I am having the same split screen black and white problem. I don't think anything simple will fix this. I have looked into the unit and almost all the video processing happens on one little PC board under the DVD. I think that the capacitors on the bottom of this board are at fault, as there have been MANY noted failures of Panasonic Professional DVC decks due to these type capacitors failing.
Oct 22, 2007 | Panasonic DMR-ES40V DVD-Video Recorder
Toshiba 46H83 46" Rear Projection HDTV-Ready Television Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
