Question about Bose Lifestyle 28 System
I have a bose dvd home entertainment system, (2 months old) yesterday i unpluged all the speaker cables and power cables to the sub because i was having a carpet fitted and since have put the plugs back in i have heared a 'whurling, whistling sound through all speakers exept the centre one. it sound like very slight interference? i dont know whats caused this? when checking i had pluged them all back in properly i noticed that the 'power plug' (which has small teeth on it + has to go in a special way) had one of the teeth bent slightly, do u think this cud b wots causing the noise?? my boyfriend thinks because of this its caused a power surge and blew my system!!!!! is this possible or do u think maybe a need power cable cud fix it?? help!!
  • angela_ramse Jan 10, 2009
    bose are going to send me a new cable free!! brill, ill try this and see. thanx. x
    Sniper:
  • 51 Answers
You are right, when there is a power supply problem this will occur so please check the power chord and try ok
Posted on Jan 09, 2009
I have a bose 321 system and I was wondering if there is a way to turn the bass up and down without the remote. I lost it
321 Home Entertainment System - Bose Product Support
worldwide.bose.com/productsupport/.../321.../page.htm...
Bose CorporationDiscover product support for your 321 home entertainment system. ... Learn how to setup and place your system components. more » ... You can adjust bass and treble levels to suit your listening preferences and your ... Discover how to use buttons on your remote and media center control panel to ... Get Adobe Reader.
[PDF]3•2•1 Home Entertainment System - Bose
worldwide.bose.com/axa/assets/pdf/.../og_321.pdf
Bose CorporationJan 29, 2002 - within the system enclosure that may be of sufficient magnitude to constitute a risk of electric .... Turning off the internal speakers in your TV .
Jan 18, 2016 | Bose 321 Series Iii Dvd Home Entertainment...
I have a wireless speaker system that home base plugs into an external music source, can In somehow connect it to the Bose 3-2-1?
Yes, it can. The Bose rear panel has RCA jacks for right and left channel audio outputs. You'll need a connecting cable with RCA plugs on the Bose end, and whatever kind of input connector your wireless speaker system needs.
Jan 13, 2011 | Bose 3·2·1 Entertainment System...
Is the subwoofer from the Bose acoustimass 10 series IV Home Entertainment Speaker System a power sub?
The entire speaker system is passive. That is, it requires amplification for each channel.
From the manual: "Compatible with A/V receivers rated from 10 to 200 watts per front channel and 10 to 100 watts per rear channel; rated from 4 to 8 ohms".
Dec 09, 2010 | Bose Acoustimass 10 Series IV Home...
Cd music is skipping on bose 321 system and one channel of dvd audio will stop playing. Disk player has also started making loud vibration noise after loading dvd or cd. This didn't used to happen. On CD...
The Bose® 3·2·1 GSX Series III DVD home entertainment system puts you at the center of exciting home theater with just two visible Gemstone® speaker arrays and a hideaway Acoustimass® module. Setup is simple because, unlike traditional five-speaker surround systems, there are no center or rear speakers. An elegant media center features a progressive scan DVD/CD player with an HDMI output and AM/FM tuner. You'll enjoy vivid detail in your movies and sports with video resolution up to 1080p over HDMI.
Apr 04, 2010 | Bose 3 2 1 GSX System
Hello, i have a vizio flat screen tv and i don't know the correct places to connect the cables of my Bose Lifestyle 48 Series IV DVD Home Entertainment System. Please help me
Does the Bose have HDMI out? Does the tv have an HDMI socket?
If it does just connect them both together. All inputs i.e. cd, ps3 dvd etc will go into the Bose.
Aug 09, 2009 | Bose Lifestyle 48 Series IV DVD Home...
Bose 321 have dvd picture but no sound HDMI
check the power suply behind the acoustimass set to 115v, not to 230, that will solve you problem
Apr 12, 2009 | Bose 3 2 1 GSX System
Whurrling, whistling, noise comming from speakers??
this dosent seem to be a power problem contact bose their systems are lifetime warrenty
Jan 09, 2009 | Bose Lifestyle 28 System
BOSE LIFE STYLE SYSTEM SOUND (AUDIO) GOES QUITE FOR A SECOND
This was posted a while ago, so I'm sure it's probably been solved by now. For anyone with audio issues using this or any other Lifestyle system: If you experience audio problems (no audio, intermittent audio) from more than just 1 source (especially if it involves internal sources like DVDs or the radio) then just reset this by unplugging the power for about 30+ seconds from the bass module and the media center DC power. Check the audio input cable (multi-pin din going from the media center to the bass module) for bent pins.
If this doesn't solve the problem, you could try replacing the input cable, but those are usually pretty robust. You could call Bose at 800-367-4008 for tech support or to set up a repair if this fails.
Dec 14, 2008 | Bose Lifestyle 38 DVD Home Entertainment...
Bose Lifestyle 38 Unsupported Format message
All you have to do is carefully take the top off and clean the "Iris" which is the reader with a little alcohol and cotton swab. Bose will charge $165 plus shipping to do this. Go to website metacafe.com and search how to clean DVD players and it will show a video, easy to understand.
Nov 10, 2007 | Bose Lifestyle 38 DVD Home Entertainment...
Black and White images Only
Go to the menu system and change your system from NTSC to PAL, or vice versa. Instructions for this are on p.39 of the manual.
Jul 27, 2007 | Bose 3 2 1 Series I DVD Home Entertainment...
Bose Lifestyle 28 System Logo
146 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
