Question about Lexmark P6250 All-In-One InkJet Photo Printer
P6250 says cartridge error, even though there is one installed.
They are new cartridges, the black is ok.
It would start working for a short period if I cleaned both contact areas, but when returning after a day or so it would say please insert a cartridge!!
    President:
  • 8,637 Answers
Normal 0 Sounds like it may have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the software install, asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 24, 2009
Install black cartridge error message on a hp2055dn printer
error install black cartridge though the cartridge is new and installed properly
Nov 08, 2012 | HP P2055DN LaserJet Monochrome Printer
PLEASE HELP ME WITH ERROR 6A80[canon 4600]
first you proper installed software by original driver cd deliverd by cannon after if problem still continue then check cartridge but cartridge should be ok , specialy in cannon cartridge demo cartridge working for very short period replace new one originally cartridge, or if your printer sensor ribbon deeply scrached it should be replace.
Feb 19, 2011 | Canon PIXMA iP4600 Color InkJet Photo...
Cartride error 50c on display
Hi there Error 50c
ok ok try see if this works
Regarding the Dell A940 "Error 50c"....the user guide doesn't seem to mention "Error 50c". They do, however, mention a "Cartridge Error" on page 52 of the manual. They claim this means that the printer has detected a short circuit (fuse/resister) in the cartridge. As you may or may not have noticed in the manual, this is what they recommend doing about it:
1) Press Power to turn the printer off.
2) Lift the printer cover/lid (scanner unit) until the scanner support holds it open.
3) Turn the printer on.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
4) Remove the color ink cartridge.
5) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the black cartridge with a new black cartridge.
If the error message does not display, repeat steps 1–3 and then go to step 6.
6) Reinstall the color cartridge and remove the black ink cartridge.
7) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the color cartridge with a new
color cartridge.
If there is no error message (indicated by flashing lights), repeat steps 1–3 and then reinstall both ink cartridges.
8) Lower the printer (scanner unit) until it is completely closed.
If you get the error message again, while both cartridges are installed, replace both of the cartridges.
Basically, what they want you to determine is,....if the short circuit is with the "black ink" cartridge or the "color ink" cartridge and then replace the cartridge that has the problem.
You may have to buy a new cartrige.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Oct 31, 2009 | Dell A960 All-In-One InkJet Printer
Dell printer model# A940 50c error
Test your cartridges.
Remove the color ink cartridge then lower the cover of your printer. If the error message displays again, replace the black cartridge with a new one (or return the new one). Reinstall the color cartridge and remove the black ink cartridge then lower the cover. If the error message displays again, replace the color cartridge with a new color cartridge.
Note: My manual indicated that the printer might have detected a short circuit in a cartridge. I returned a month old black cartridge got a new one and my printer is working fine now. Good luck.
Nov 10, 2008 | Dell A940 All-In-One InkJet Printer
Dell A960 cartridge problem
Does the black cartridge print? If not did you take the tape off of it? Error 50 is a generalized error reading relating to a number of cartridge problems. If the color cartridge is empty, it may be theproblem although I have not found this to be true on Dell printers. If you remove the color cartridge and reinstall it the reading will indicate its full (even though it isn't. This may solve the problem.
Sep 19, 2008 | Dell A960 All-In-One InkJet Printer
I keep getting cartridge error or it prints a blank page. There is no tape on the cartridge and they are installed properly. It prints sometimes but not all the time Printer keeps saying cartridge error
This has been just happening with me aswell - I just changed the colour cartridge with the black cartridge ran out but i kept it in as it told me to place one in. Trying to print out but black ink wont come - just blank pages - surely the colour cartridge can make black? However, if you have the colour cartridge and are on microsoft word or similar, change the colour of the writing to dark navy and it will print out documents.
Aug 26, 2008 | Lexmark P6250 All-In-One InkJet Photo...
Lexmark p6250 does not detect black cartridge
did you do a clean and recalibration on these new cartridges/
You may also need a new set of drivers(never hurts)..get em here
Mar 22, 2008 | Lexmark P6250 All-In-One InkJet Photo...
"Cartridge Error" in the display.
I got this from Lexmark this morning didn"t work for me but it may help somedody else worth a try C/P. You need to clean NVRAM on Lexmark P6250 printer. Please find below the steps to clear the NVRAM on the Lexmark P6250: 1. Press the "Up" arrow and "Menu" button at the same time. 2. Press the down arrow until the LCD displays "Clean NVRAM." 3. Press "Select."
Nov 30, 2007 | Lexmark P6250 All-In-One InkJet Photo...
Lexmark P6250 All-In-One InkJet Photo Printer Logo
166 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
