Question about D-Link DGS-2205 5-Port Gigabit Ethernet Switch (DGS2205)
It has the green power light, but no activity lights
Basically, it looks like it died. I get power, but my computer
can no longer sense the switch. It keeps saying cable disconnected. Doesn't work on any of the ports tried.
is there anyway to reset the box? powering on and off doesn't help.
I've opened up the box, but nothing obvious like a fried chip was seen.
Anyone else have a similar problem and solution other than going a ahead and buying a new one?
  • 1 more comment
  • Anonymous Feb 07, 2009
    i have the exact same problem and Dlink says there is no way to reset it. they can only offer an RMA if you still have the proof of purchase
  • infinity9999 Mar 17, 2009
    Same thing happened to me last night. Power and no link on any port. =(
  • Anonymous May 04, 2009
    Same problem here, except powering off and on fixed the problem.
  • 70 Answers
SOURCE: Port speed issues with my DGS-2205
Gigabit swich does not enough for a Gigabit network, you also need to get your computers to support it, that means Gigabit network cards, buy if you don't have and you really need to, they are quite cheap these days.
If the above is not the case than it is barely possible, but worths a check, if you are using simple CAT5 cable instead of CAT5E or CAT6 (cable type is written on the cable, see for yourself)cable for the network?
If this is true consider doing a rewireing if really nessesary for speed, but cat5 is ok for gigabit around 10 meters distance for very good speeds.
However to do a little speedtest on your own first is not a bad idea at all, try to copy some big files between 2 computers and check the speed, 100Mbit networks used to do speeds about 8-10 Mbytes/sec that should do it for most networks, gigabit networks can do more, my record in my home network was 50-60Mbytes/sec, but mostly it's around 30Mbytes/sec.
Remember, better cable can do better speed and sometimes length affects network speed if the cable is very long (above 50 meters). And prepare, that you are not really going to reach the theoretical maximum speed of 125Mbytes/sec with common PC hardware. Maybe with some RAID based system or SSD can help you out, but most people don't really need that kind of speed.
Posted on Nov 26, 2008
  • 7 Answers
SOURCE: d-link lights are all on
I don't think it has anything to do with the voltage its an issue with the ship on a certain batch , again not all the DES-1228P have that issue only few.
I am sure if you contact D-link they will replace the switch as it is a 5 years warranty
Posted on Mar 03, 2009
  • 591 Answers
SOURCE: I have a D-Link DGS-2208 8-Port Gigabit Ethernet
Could it be that green is high speed and amber is low speed? Or vice-versa?
Posted on Nov 15, 2009
  • 6826 Answers
SOURCE: there is no power coming
Sounds like the power supply to the switch may be bad, if it doesn't turn the power on.
Check the voltage of the power supply with a multimeter to see what the transformer power supply is outputing.
Posted on Aug 02, 2010
  • 12 Answers
SOURCE: I have a DLink DES-1008D 8 port switch. ! port
Are you using the original power adapter ?
Use only CAT5 UTP fast-Ethernet cables no longer than 80 meters.
Connect just 5 or 6 computers to see if the problem resolves. Sometimes the internal buffer on the switch (the store-forward buffer) gets full, so the switch resets and stop forwarding packets until it get it's buffer cleared.
I hope it will help you.
Posted on Mar 08, 2011
The motion light says it has a manual override. I thought this was to be able to turn the light on so it wont shut off until I turn it off. Is this what the manual override means?
Good afternoon Amanda
There is a 'Dusk to Dawn' mode in these lights in which it will turn on continuously for 6 hours once it senses dusk, and then go back to the automated sensing mode for the rest of the night. This is triggered by turning power on and off twice within three seconds. See the manual here (
Defiant MST18920lwdf Use And Care Manual Feature Selection Troubleshooting )
If you follow this link, there is a forum with the same question and a walk-through of how to toggle the switch for manual mode.
how do activate manual mode to keep light on longer on LED Motion security...
That should get you off to the races. Good Luck!
Nov 18, 2015 | Defiant Flood Lights. 180 Degree Outdoor...
Display POWER ON but SC25 not working.not reset
my regservo need to active plz help me for activation code
Dec 29, 2013 | Pioneer Elite SC-25 7.1-CH A/V Receiver
Hi, if I change my computer to my Nissan 300ZX 1986 I have to reset my computer or simply change it. Thank you for answer.
There is no re-setting. You just change it out. Be sure and disconnect battery before unplugging the ecu. It's a simple swap and go.
If yours is like my '87 Sentra, there is no trouble code capability, but there are limited diagnostic functions. The red and green LED lights and the diagnostic switch (on/off), can tell you if problems are present in the system or not. You just have to follow the diagnostic procedure.
Here's how: Make sure diagnostic switch on ecu is off. Run engine at 2000 rpm for 5 minutes, at no load. Look at green led: if it flashes at least 5 times in 10 seconds (that is the oxygen sensor making it flash), turn car off. Turn diagnostic switch on. Turn key to on, do not start engine. Check led's: if red is off and green on steady-No problems present in system.
If the red light is on and green light is flashing, post back and I can furnish the rest of the diagnostic procedure-basically, you will be checking voltages and resistance of all solenoids and relays the ecu controls. The green led may flash in two different sequences (either longer flashes and short pauses, or longer pauses and short flashes) when in diag. mode (with the red led on), and that will lead you down two different diagnostic routes. Pretty simple, really, and pretty effective. Took me hours and hours before I realized I even had this diagnostic function.
Aug 18, 2013 | Nissan 300ZX Cars & Trucks
My linksys network switch is not connecting network computer, what can i do to get it back to work?
Do you have any activity lights on the Linksys? If not your switch has no power a hardware problem. Try to power off for 5 seconds and restore power on the Linksys unit. Try to shut down (do not restart) all computers. Are all the activity lights off? If not again power off the Linksys for five seconds and restore power. Power on the computers and verify the activity lights are now green for each computer. If the computers are not networked and the activity lights are green, check your network settings on your computers, which could have incorrect TCP/IP settings or workgroup. If one activity light is not green for that Ethernet connection, check your cable connection or replace the Ethernet cable. The workgroup should all be the same name. The TCP/IP address should be the same with the exception of the last set of host digits which should be unique to each computer address.
Jul 27, 2010 | Linksys SR224 24Port Ethernet Switch
All palm information has vanished.
Your battery may have 'died' or not been recharged in the cradle. Make sure the light on the cradle is on (green) when the Palm is correctly seated. If not, follow the cable from the cradle to the serial port at the back of the computer. The other wire entering that connector comes from the power pack - check that the power pack is plugged in to the power supply and is switched on. If he green light still isn't illuminating then the power pack is suspect and may need replacing.
After it has been in the cradle with the green light on for a couple of hours, do a hotsync. This should restore some of the data. If you get this far, then you will need to follow the instructions in the manual to restore your programs. If the battery is dead then I think it is unlikely you will get another since Palm no longer services the Vx
May 09, 2010 | Palm Vx Handheld
The usb receiver no longer seems to accept any mouse commands. Basically the green light no longer comes on and the mouse no longer works no matter which usb port I plug into.
prob it is busted. you should try reseting it. there is a small button at the bottom of either of the device that once press you'll be able to activate it.
Aug 23, 2009 | HP Wireless Optical Mouse
Monitor appears to be dying. It is taking longer
If you can solder you should be able to repair the unit. The problem in most likely bad capacitors in the power supply. If you go to our web site at: we have pictures of what to look for and replace. Just open the monitor back and get to the power board, replace any that look like the pictures and you should be back going. If you don't want to do the repair yourself we do offer a repair service contact me at if you want us to do thhe work.
I hope this helps, if so please rate my solution.
Corporate Computer
Jul 31, 2009 | Sceptre X9G-NagaIV 19" LCD Monitor
When comp pluged in just a green flashing light
If you are sure that the 110 volt power is coming into the computer then the most likely problem is that th epower supply died. Obtain a new one of the same or larger wattagge as the one you are replacing . It does nto have to come from the manufacture of the computer.
Nov 26, 2008 | Compaq Presario SR1000T (568657) PC...
Question on BB2125 2 Channel Amp
Hi jgoudie
It is a signal sensing turn on unit, so will not turn on until you have supplied signal to it. Plug it into a signal source and see what it does. But unfortunately, in my experience the protection light coming on means there is a fault in the amp.
You can download the user manual for the amp from here. Click downloads in the middle of the page:)
Aug 17, 2008 | SpeakerCraft BB2125 2-Channel Amplifier
Princeton Digital VL1916
In my years of working on LCD's, your inverter (basically like a ballast in a flourscent lamp) is bad/going out. Crack open the case and look for a big pink and white wire going to a pcb (usually located under a shield) and remove it and check for puffed capacitors. If there are some change them and that usually fixes the problem. If there are no signs of anything wrong on the inverter, get the numbers off the pcb and google or ebay the numbers, usually youll find a replacement realitively fast.
Sep 15, 2007 | Princeton Digital VL1916 19" LCD Monitor
D-Link DGS-2205 5-Port Gigabit Ethernet Switch (DGS2205) Logo
514 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
