Question about Epson Stylus C46 InkJet Printer
Red & Green led is blinking continiously after carriage initial.
Cartridge holder is not moving.
  • 1 more comment
  • pliv_123 Jan 25, 2009
    Yes I have the same problem , the carriage moves very very slowly, in fact it does not move along the way it should , but goes back again .
  • Anonymous Feb 03, 2009
    red and green ledis blinking continously and alternatively
  • meikevertje Feb 04, 2009
    Red and green led is blinking continously after carriage initial.
  • 353 Answers
The Waste Ink Pads are deemed to be saturated and should be replaced. You can overcome this problem temporarily bu using the SSC utility - download from
http://www.ssclg.com/epsone.shtml
and reset the Protection Counter. However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer. A copy of the service manual is available from a number of sellers - just Google "Epson C46 Service Manual.
Posted on Jan 31, 2009
When i turn on my tv it tries to boot, blue mitsubishi home screen come up, i hear fan then it all shuts off while green light blinks.
Try a reset. Start by unplugging for 1 minute, then plug back in & if still won't restart try the following. If none of the following work, you will need a technician.
Initializing the TV in many cases can remedy a problem.
In the 2006 product line Initialization is now a user function.
Pressing the front panel "INPUT' and "FORMAT"
buttons at the same time activates Initialization. When
complete all user settings will have to be set again. The
table in Figure 4-3 list the User Initialization procedures.
Note: Pressing INPUT and FORMAT is the same as
the Initialization in the Option Menu (MENU-2-4-7-0)
Order Name Procedure Results Notes
1 System Reset Press <System Reset>
on Front Panel
Hardware & TV operating
software reset.
POWER/Timer LED flashes for 60
seconds. No customer settings
are changed.
2 User Initialization
Press <INPUT> &
<FORMAT> on Front
Panel at the same time.
All customer Audio &
Video settings are reset to
factory default.
All customer settings will need to
re-configured.
3 Reset System
Defaults
From the remote, press
<MENU> <1-2-3>
<ENTER>
except V-Chip are reset to
factory default.
Netcommand, Channel Memory,
etc., will need to be re-configured.
SERVICER
PROCEDURE 4 Initialization
<MENU> <2-4-7-0>*
select "INITIAL" press
<ENTER>
All customer settings are
reset to factory default.
re-configured.
MITSUBISHI RESET / INITIALIZATION CHART
CUSTOMER
PROCEDURES
Figure 4-3
Figure 4-4
LED Indications
The front panel LEDs, refer to Figure 4-4, also assist in
determining the cause of a symptom. Figure 4-5 illustrates
normal LED operation. Figure 4-6 shows the
LEDs response when a problem is detected and indicates
the possible cause.
Power/Timer
Indicator
Status
Indicator
Lamp
Indicator Condition
Off Off Off Off (standby)
Blinking green
fast Off Off Initialization (10 - 65 seconds)
Off Off Blinking
green fast Lamp runs for 1 min after PTV off
Green Off Off Power On
Blinking green Off Off Power On Timer is set
NORMAL LED INDICATIONS
Power LED Status LED Lamp LED Condition
High Temperature - check ventilation air flow.
(Temperature sensor is disconnected.)
Off Off Blinking yellow Lamp cover is open.
Lamp failure (Lamp fails to turn on)
Off Off Red (Lamp turns off after lighting)
Lamp is broken
Off Blinking Red Off Fan Stop
Off Red. Off Circuit failure. (Run Error Code Check)
Apr 08, 2015 | Mitsubishi WD-65731 65-Inch 1080p DLP HDTV
How can I open cartridge holder on my epson stylus photo 1400. It's stuck over on the right and red lights are flashing.
Turn on printer, and unplug power chord while the carriage moving.
Then move carriage by hand freely.
Sep 02, 2014 | Epson Stylus 1400 InkJet Photo Printer
Epson R230 with green led and red led blinking
This is general error of the printer. When you have to change the new mother board you should be initialized it then it can be ready mode. When you try to initialization you need printer printer adjustment program. You can batter find out from google & write down EPSON Stylus R230 Printer Adjustment program or ink reseat program.
Jun 12, 2013 | Epson STYLUS R230 InkJet Photo Printer
The red LED continiously lights cann't print, both LED constantly lights.
This means that your waste pads are full and the printer needs to be reset with software email me and I will send you the software
Aug 20, 2012 | Epson Stylus C46 InkJet Printer
Red and green lights are flashing alternatively and colour ink cartridge has run out. How do i change the cartridge?
Flashing alternately mean waste pad full. Reset using SSC utility or Adjusment program/resetter. But, you must replace cartridge before. Turn off printer, unlock carriage lock (left side of carriage at parking position). Move carriage by hand to replacement position. Replace ink tank. Reset using the resetter.
May 21, 2010 | Epson Stylus C46 InkJet Printer
Its stop printing and the LED power light green and orange at the center blink, like there is a paper jam.
Feb 11, 2010 | HP DeskJet 1280 InkJet Printer
Pixma MP610 will not start up. Was working OK. Just under 1 year old. Printer detected by computer, and print carriage lifts, but will not move. Ink in all the cartridges Front lights blinking alternately...
6A00 indicates a problem with the carriage lifting mechanism. Simply put there is beam kind of thing that the cartridge carriage assembly on which the print head rides on and something on it is obstructing the carriage assembly. The fix? Open the printhead cover and turn on the printer. You will see that the carriage arm is extended and tries to move back to the initial printing position but it can't. Just give it a little helping hand and bingo! The print head moves to the correct position. You will then have to clean up whatever is blocking its path. Usual culprits being ink, paperclips, tiny bits of popcorn(or anything else you prefer eating while printing!:)
Let me know if you need more help,
Sai.
Jan 03, 2010 | Canon Office Equipment & Supplies
Blinking red light
You have a cartridge refill
The fuse is 250mA (250 volt but this is not critical) go and 315mA. The fuse is 3/4" inch long (20 mm) round glass with metal ends. The electrical contacts are not in the cartridge they are inside the printer. There is a plastic fuse holder on the cartridge, even the starter cartridge. If you face the cartridge with the green roller horizontal and down, the fuse holder will be on the right side just above the phillips screw and in front of the white gear you can see inside the cartridge. The fuse installs horizontally, (in line with the green roller). You just simply pop it into the holder. (I wish I knew how to post a photo, it's really easy when you figure it out.) This will stop the annoying flashing red LED and your system tray will say the cartridge is full. Good luck!!!
Oct 10, 2009 | Samsung ML-2510 Laser Printer
Carriage won't move over to install new innk cartridge
Personally. my carriage move (ink maintenance button) stopped working within the first month...i have this printer for almost 6 years now, I just manually move the carriage over by hand
Dec 16, 2008 | Epson Stylus C62 InkJet Printer
No response
If you´re pressing the ink button and the carriage still does not moves is cause the level of the ink is low, but it does not finished yet. You must use the printer more, then the red light will stop to blink and hold on, then you´ll be able to change the cartridge.
Apr 19, 2008 | Epson Stylus C60 InkJet Printer
Epson Stylus C46 InkJet Printer Logo
139 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
