Question about Xerox Phaser 8500/DN Printer
Xerox 8500 excessive ink use
Slef cleaning occurs every time 8500 printer is used
  • 4 more comments
  • scandamail Jan 09, 2009
    THanks but whether on standy or powered off it goes through a cleaning routine everytime it comes back on and so is drinking ink!
  • scandamail Jan 11, 2009
    My printer goes through the routine that you state but shows no error, however it does this every time it hibernates!
    I am away on business and will not be looking at my e-mails until Friday, in the meantime thank you for your help.
    RobertMcL
  • dale_holman Feb 02, 2009
    I have the same problem, it started with a loose power cable. It got better after I removed and reinserted it, but still goes through a warmup and purge cycle at least 2x each day. The office has the ink locked up now and I cannot print until the office manager arrives and issues another single block of ink.
  • scandamail Apr 02, 2009
    I use Xerox ink and I leave it on standby never plug out, but it goes through its cleaning cycle every time it warms up. Maybe this is a Xerox way to have you buy more ink.
  • Paul Douglas
    Paul Douglas May 11, 2010
    Hi scandamail: Let me know if you printer does this and any messages that you get with errors.
    If printhead, ink reservoirs, or jetstack temperature are below purge
    threshold, the printer performs a head clean cycle.
    1. The printer waits for the printhead to reach its purge temperature.
    2. The printer moves the wiper to the bottom of its travel and tilts the printhead
    forward to its print position to check the ink levels. If the ink level is low, ink is
    melted into the appropriated reservoirs.
    3. The printhead tilts to the standby position and moves the wiper assembly to the
    purge position in front of the printhead faceplate.
    4. The purge pump begins the pressure purge after about 2 seconds the purge pump
    solenoid opens.
    5. The printhead tilts forward against the wiper assembly (wipe position) and the
    purge and wipe cycle begins.
    6. The Control Panel indicates the printer is performing the cleaning process.
    7. The printhead is moved left to the tilt zone, where the printhead can tilt back
    without interference, and the media path motor moves the wiper to the bottom of
    its travel to engage the printhead tilt cam. The process motor rotates the printhead
    tilt gears, which tilt in order to move the printhead to the forward print position.
    8. After the print engine is in a known, valid state the Control Panel display shows
    the warm-up progress (the Ready LED flashes). When warm-up completes, the
    Ready LED displays solid.
    9. The temperature of the printhead, drum and paper preheater are allowed to
    stabilize at their operating temperatures and ink is melted if needed.
    10. The printhead is homed to the print position for printing.
    11. A cleaning page is printed at this time, if a purge was performed.
    12. A start page is printed (if enabled).
    13. The Control Panel displays a message that the printer is initializing and then
    ready.
    14. The print engine is initialized and is ready to print.
  • Paul Douglas
    Hi scandamail:
    Do you power off the printer every day?
    if so what happens is that everytime you power the printer on it goes through a purging routine. That means that the dry ink is cleaned from the print head. Keep your printer powered on and you should notice a difference.
Hello Phaser 8500 owners,
I found a way to restrict the wasting ink problem of excessive cleaning cycles:
Just unplug the connector of the ink pump. One can find this pump behind the left plastic cover. Unplug the connector of the pump during the excessive cycles and put it back on again after.
To my experience the cleaning cycles come too soon or too often.
Good luck,
Tim
Posted on May 09, 2011
    Scholar:
  • 49 Answers
One of the reasons this could be happening is because you are using non-xerox ink so your print head needs to clean it out much more often. Be careful using other ink as this can destroy the machines printhead which is more expensive then the machine itself to replace. What you could try is installing the new printhead firmware, it might help! Follow the link below and good luck!
http://www.office.xerox.com/perl-bin/product.pl?page=sprt&product=8500_8550&country=United%20States&language=en
Niallbt
Posted on Mar 30, 2009
  • Niallbt Mar 30, 2009
    My solution is a last resort, you should never plug out a solid ink machine, it should be plugged in at all times. Otherwise it will use up loads of Ink.
Printer printing horizontal blue lines across the page. lines are spaced apprx 1 inch apart have aligned, cleaned and recalibrated printhead but problem still occurs
Program malfunction, uninstall HP Printer programe and reinstall your version for the printer from www.hp.com remember to load the complete program.
Mar 15, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
Ir 8500 cannnon copier black shade on paper
hi dude i dont think u have problem with drum cleaning blade coz it not making trouble for me from last 5years.
just replace the crona wires both charge and transfer and clean the whole scanner mirors .
thanks
May 16, 2010 | Canon imageRUNNER 8500 Copier
Problem for HP Color LaserJet 8500 Printer Black line on the left side printed page while making copy on HP. This problem occurs only while loading the page on the top tray HP 8500 printer. No black line...
This is usually caused by something on the scanner glass. Check for dried ink or correction fluid on the scanner glass. We have a short article about solving this type of issue posted here: http://www.ccl-la.com/blog/index.php/lines-on-scanned-or-copies-pages/
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Apr 28, 2010 | HP LaserJet 8500 Color Printer
Printing has become faded. can I fix it?
Check your manual and it will tell you how to put the printer into slef clean mode. Run that 4 or 5 times and it should fix the problem. If not you may have to take the printer to a repair depot.
Jul 10, 2009 | Epson Stylus RX580 InkJet Photo Printer
Paper jam
it takes a little bit of disarming because you've got to clean the rubber rolls that "pull" the paper, a pair of grey rubbers almost cilindrical with a flat side located over the top of the paper, and happens that you cant clean them properly if you dont disarm the printer. These rubbers must mantain their "stickyness" to be able to pull the paper properly and with the use they become dirty.
That is the problem, so take your screwdriver and some isopropilic alcohol and ...........good luck.
Dec 04, 2008 | Kodak Professional 8500 Thermal Printer
Xerox 8500 Error 07,101.43:20955
That has to do with the process drive gear box. May be mis timed or a gear broken.
Apr 11, 2008 | Xerox Phaser 8500/DN Printer
Brother MFC 8500
Hi, Make sure the rear cover is closed. 2. Usually when you get misc symbols on the printed page the machine couldn't recognize the print job. I would try printing something from another file and see if the problem occurs.
Dec 01, 2007 | Brother MFC 8500 All-In-One Laser Printer
Canon BJC 8500 WASTE INK FULL
How to Reset Waste Ink Protection Counter Canon Pixma IP8500 Printer
Instructions:
Resetting Waste Ink Counter Canon Pixma IP6000, Canon MP450, Canon Pixma IP8500
1. Turn off the printer.
2. Whilst pressing Resume button also press on POWER.
3. Then Press RESUME button and release POWER.
4. Then Press RESUME button again .
5. Then release all buttons.
6. Led Indicator should be green and stay green.
7. Click RESUME button 4 times if you wish to try again.
Then See Table Below:
Orange - Service test print ONCE - Orange - Service test print.
Green - EEPROM information TWICE - Green - EEPROM information print.
Orange - EEPROM initialization 3 TIMES - Orange - EEPROM initialization.
Green - Waste ink counter resetting 4 TIMES - Green - Waste ink counter resetting
Orange - Destination setting (Press Power then Press Resume 3x) 5 times - Orange - Destination setting (Press Power Press Resume 3x)
Green - Print head deep cleaning 6 TIMES - Green - Print head deep cleaning.
Orange - Green, Orange - Return to menu selection 11-13 TIMES - Orange, Green, Orange - Return to menu selection.
Green - Left margin correction 14 TIMES - Green - Left margin correction.
8. Turn off printer.
9. Restart Printer.
Good Luck!
Tinteiros - Magic Inkjet Flush (Ebay)
Nov 07, 2007 | Canon BJC 8500 InkJet Printer
Phaser 8500 cleaning page
You can't. Just simply stated. It is the way it's designed.
Per Xerox below
NOTE: The automatic printhead cleaning cycle cannot be disabled.
The printer performs automatic printhead cleaning cycles to remove air bubbles or foreign matter that can cause a printhead jet to malfunction. An automatic printhead cleaning cycle is performed when the printer is first powered ON, or if the ink has cooled to the point that a cleaning cycle is required.
Powering OFF the printer longer than 3 or 4 minutes will also cause the printer to perform a printhead cleaning cycle when the printer is powered back ON, which uses ink. To minimize ink consumption, keep the printer powered ON at all times.
Sep 13, 2007 | Xerox Phaser 8500N Printer
Xerox Phaser  8500/DN Printer Logo
316 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
