Question about Garmin nuvi 350 GPS Receiver
How to switch between maps ?
I have Nuvi 350 with preloaded US maps and Europe maps on the SD card. How to switch between different maps or to redirect nuvi to use the maps from SD card. Thanks Slav
  • slaveys Jan 21, 2009
    Thanks Jim,
    The problem is I can't see the second map. All  I can see is the preloaded one...The other one is downloaded from IN and even it is unlocked I can't see and activate it.  Any ideas?
    Slav
  • snakebitmac Feb 15, 2009
    i have a nuvi 760 that isn't seeing the Euro maps on sd. When I go into map info, only shows north america I can see the sd in the nuvi while connected to laptop. I'm in europe and need these maps to get around, especially with Carnival stating this week:)
  • Garmin Master
  • 2,130 Answers
Please click on the wrench symbol, then map icon and then "map info". You will see (2) maps listed with check marks next to them. Uncheck the map you do not want to use. Check mark the map you want to use. This is how you switch between maps.
- Jim
SHARCNET-USA
Posted on Jan 09, 2009
  • SHARCNET-USA
    SHARCNET-USA Jan 21, 2009
    What are the file names on the SD card? It should be gmapsupp.img not gmapprom.img.
    - Jim
Garmin NUVI 350 only loaded Southeast States Want all 49 states
Try using a compatible SD card to have Garmin Express load all 49 states to the SD card. It is possible that you do not have enough free memory in your NUVI 350 for all 49 states.
Dec 31, 2016 | Garmin nuvi 350 GPS Receiver
I bought the europe sd card. If I insert it will I lose all the US data?
No, the US data is on the unit itself. Adding an SD card with maps only increases the number of maps your unit can handle, it doesn't replace existing maps. You'll have to go into settings to change the view to European maps.
Sep 18, 2011 | Garmin nuvi 350 GPS Receiver
My nuvi 3760T does not have enough space to load europe map. Can I remove preloaded north america map and reload at a later date without losing it?
If you have the map downloaded from the garmin website to your computer you could remove it and replace it later. However a better option might be to download the map of Europe to your computer and install it to a micro SD card. A 4 Gb card would hold the map of Europe and you don't risk losing your North America map. You can get details of how to set up the map on your micro SD card at http://www.fixya.com/support/r5628920-update_garmin_satnav_maps
While this link is mainly about how to update your maps it has a section on setting up maps on an SD/Micro SD card also.
Mar 26, 2011 | Garmin GPS
How do I change the flash card in a Garmin Nuvi? I have been given a card with maps of Europe on it but don't know how to swap it out with the U.S. card currently in the GPS.
Hi. Save yourself the effort and do not change the flash card with another preloaded one. Your US maps are registered to your specific GPS and will work only in your GPS device and no other. Similarly the Europe maps from someone else's GPS will not work in your Nuvi.
To get the Europe maps active and working, your only option is to buy the maps (on DVD) and register them online with Garmin. This is an expensive option, but unfortunately it is the only option.
Jan 19, 2011 | Garmin GPS
Purchased sd card with eurpope maps for my nuvi 205 that is preloaded for north america. how do I use it?
Put the card in the slot. Go to setup and select the map. If you're outside Europe, the screen will be blank (GPS fix is outside the map area).
Jul 29, 2009 | GPS
I need help installing a map onto a gramin sat nav
No. They are refering to maps sent from the computer to the Garmin device. Maps are not transferred off the SD card to the unit. Simply insert the SD card into the device and the Garmin will read the maps from the card.
to double check follow these steps
  1. Power on the unit with the card in
  2. Press Tools
  3. Press Settings
  4. Press Map
  5. Press Info (or map info)
This page should list out both your UK and Ireland maps(old as dirt) and your new Benelux and France maps as well
Apr 20, 2017 | Garmin Nuvi 600 Car GPS Receiver
Add Europe sd card to Garmin 660
No. When you plug in the SD card, the Nuvi will load the map from your SD card. Once you get to the main menu, select the wrench symbol, then the map symbol and then "map info". You should see both the US and Europe map. Make sure the Europe map is checked. You can uncheck the US map. This is how you switch between maps. The reason why you have to have the extra map on the SD card is because the Nuvi can only have one map on it's internal drive, one at a time.
However, backing up your US map is a good idea.
Good luck,
- Jim
Nov 21, 2008 | Garmin Nuvi 660 GPS Receiver
Going to Mexico and my garmin will not display it.
There are a variety of Garmin® GPS devices that come preloaded with mapping not just for the United States but also for Europe and Mexico. Any nuvi® that has 70 in the model number will have preloaded mapping for North America and Europe.
Example: nuvi 270, nuvi 370, nuvi 670, nuvi 770
Also, some specialty models will have preloaded mapping for North America and Mexico. These units include the nuvi 200 Mexico (p/n 010-00621-2A) and the Nuvi 260W Mexico (p/n 010-00656-37).
To obtain Mexico maps, go to this link:
http://www8.garmin.com/cartography/mapSource/citynavntmexico.jsp#price
Oct 11, 2008 | Garmin GPS
Europe SD card wont work
tap on the wrench, tap on map, tap on about map, there you should see the base map checked, and the Europe map unchecked, uncheck the us map and check the europe map by tapping on the check box. leave the menu.
May 27, 2008 | Garmin nuvi 250W GPS Receiver
USA MAPS
You need to buy a preloaded SD card, purchase maps from Garmin and download them to a blank SD card.
Dec 10, 2007 | Garmin nuvi 350 GPS Receiver
Garmin nuvi 350 GPS Receiver Logo
3,068 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
