Dark Screen Hi Guru, my fujitsu lifebook S series screen suddenly gone very dark. Software seems to be working okay. If I look very closely and carefully I could see start menu very faintly under a table lamp. What is wromh and ehat should I do. Please help! Tash
  • Anonymous Apr 13, 2009
    i have the same problem with my dell inspiron 5100 pc notebook anyone know how to fix?
My lifebook has a black screen but windows running
It could be the monitor or graphics card or CCL are done. Or maybe a simple small switch that shuts-down the light when the lid is closed. I repaired a HP that the switch had "stuck" in the closed position, you could see the screen in the bright sunlight and see the windows OS. The background light,CCL in older machines, was not lit. I once had to access the rear of the monitor, in a laptop, to re-insert a loose ribbon cable that had jared loose causing the screen to go dark.
Oct 29, 2012 | Fujitsu Lifebook P8010 Notebook
Fujitsu lifebook screen will not come on
Could be a dead screen, use your vga, hdmi or svideo port to an external monitor or tv, if you get video there, then your laptop is still working and it is your screen. Check to see if you see any pictures on your screen but it would show in really really dark picture... if that is the case it is your screen backlit bulb that gone bad and the screen will need to be replaced. If nothing appears on your screen but you get picture to a external monitor via s-video, hdmi or the vga port then it could be that you have a loose cable connection or bad wireing somewhere between your latop base and the screen. If nothing at all appears on your screen or the external monitor source then you have a promblem with your laptop.... and those promblem can be in a wide range of trying to seek out the defective part.
Jan 14, 2011 | Fujitsu LifeBook S6520 Notebook
My laptop displays very dark
Unfortunately, (Isay that a lot on this site), your lcd screen is backlit with tiny flourescent lights, sounds like these have been broken not much to do except talk to a local tech and hope that he has an lcd screen to swap or steal parts from.
Sorry my prognosis is not better...
Ed Meyer
Owner
AACS
www.alwaysaffordablesolutions.com
May 22, 2009 | Fujitsu LifeBook® S2210 PC Notebook
I have a fujitsu lifebook N6460 the screen flickers and goes out
Sounds like you back light or LCD inverter is going out, If you don't hear a whine then it is just the LCD screen, if you hear that whine then it is the inverter. An inverter will run 40-60 dolloars as opposed to and LCD screen which usually start around 100 and go up...
Hope this helps, if so please rate my solution accordingly.
Since it seems as though you dont move it very much you might be able to hook an external monitor up to it and using the Fn+F5 button swap it to use the external monitor untill you can get it repaired.
Mar 18, 2009 | Fujitsu LifeBook N6460 Notebook PC...
Some black colors are replaced with red blue flickreing in whites
Hi there
Firstly reinstall the graphics drivers, if its still the same there is a problem with the graphics card and you'll have to have it looked at.
Good luck and thanks for using Fixya!
Feb 06, 2009 | Fujitsu LifeBook C2340 Notebook
Fujitsu Lifebook C2330 Monitor dark
ih some older lap tops have a wheel on the side of the screen that enables you to adjust the screens light or darkness. please excuse me if I am stating the obvious but I am not totally familiar with this model
as for the hissing this sounds like the fan needs cleaning as it is running under speed and causing the system to slightly over heat which is why the light keeps flashing..
In reply to your question with regard to can it be fixed is it worth it. if it was mine I would take it apart and clean the fan. In your case you should take it to a small out let to get it checked over. Hope this helps
Sep 15, 2008 | Fujitsu Siemens AMILO Pro V7010 Notebook
Laptop screen gone dark
I had a similar problem on my Fujitsu-Siemens Lifebook C-1020 and I had to replace both the C/C inverter that the CCFL lamp. Easy to find/replace the inverter (only take care of input/output plugs), tricky to find/replace the CCFL lamp (because of diameter, lenght and toxic Hg content).
Zpp
Have fun!
Mar 09, 2008 | IBM ThinkPad T42 Notebook
Your LCD backlight is not working. It is fixable but it is not a repair I would recommend to the typical user. The reason is that you have to disassemble a fairly good portion of the laptop to access the light source and/or the electrical components that control it. If you have excellent attention to detail, patience, experience with the disassembly and handling of electronics and the tools then give it a try. It is also important to also realize that by doing it yourself you risk the real possibility of damaging your laptop beyond economic repair then it may also be worth a try. Otherwise I would strongly suggest you take your laptop to the local authorized repair shop.
Feb 03, 2007 | Fujitsu LifeBook C2330 Notebook
Computers & Internet Logo
151 people viewed this question
David Payne
David Payne
