Downloading i want to download the media center
Please cna you clrifiy when you men by "i want to download meida center"
Who's media Centre
Posted on Mar 20, 2009
How to Download Windows Media Center?
windows media center no longer supported by windows
means a few steps to get it right
will need RAR opening software on computer
windows 7 and 8 download how to
windows ten how to
How to Install Windows Media Center on Windows 10
Oct 19, 2016 | Computers & Internet
Windows media player won't work
Which operating system ? Which version of Media player ?
Though designed with Windows 7 in mind, Windows Media Player 11 (WMP 11) is fully compatible with Windows XP.
The trick is knowing which version of WMP 11 to download.
Different versions of the software exist not only for Windows 7, Vista, and XP, but also for both 32-bit and 64-bit Windows XP.
Additionally, WMP 11 is only compatible with XP if it is using Service Pack 2 or Service Pack 3. Before downloading the appropriate installation file, you will need to verify which version your system requires.
Open the "Start" menu.
Open "My Computer."
Click "Help", then select "About Windows."
This will display a window with system information.
Find the listing that specifies your Service Pack. If you are operating without Service Pack 2 or 3, you will need to install one (see Resources).
Open the "Start" menu and click "Run." Within the text field, type "winmsd.exe."
Click "OK." Select "System Summary."
Find the heading labeled "Item."
Under this heading should be the word "Processor."
The value associated with "Processor" will determine which version of Windows XP you are running.
If the value begins with "x86," you are running a 32-bit version.
If it begins with "ia64" or "AMD64," then you are running a 64-bit version.
Download the Windows Media Player installation file that matches your version of Windows (see Below).
http://windows.microsoft.com/en-US/windows/downloads/windows-media-player
Open the file once it has finished downloading.
This will launch the installation wizard.
Follow the onscreen instructions to install WMP 11.
The program should now run normally.
How to Fix Windows Media Center
Windows Media Center is the home entertainment hub on a Windows computer.
With Media Center, you can play live television, songs, DVDs and slideshows.
It is preinstalled on Windows XP Media Center Edition, Windows Vista Home Premium/Ultimate Edition and Windows 7 Home Premium, Professional, Enterprise and Ultimate editions.
From time to time, users run into issues trying to play audio or video files, or with an extender connected to Media Center.
Extenders are devices that allow you to "extend" the Media Center onto a TV screen or larger display.
The Xbox 360 gaming console is an example of an extender.
Launch Windows Media Center from your computer's Start menu.
Scroll down to "Music" on the Media Center home screen.
Select "Music library."
If you find an empty folder under "Music Library," navigate to the folder on your hard drive that stores your music file and add it to Media Center's library.
If the problem isn't an empty folder, look at the file extension on the music file that won't play. Media Center can't play files with unknown or incompatible extensions.
If you find a questionable extension, skip that file. Click once on another file with a different extension, one you know is compatible with Media Center, and then click "Open" to test if you can play that one.
Media Center will play MP3, CDA, WAV and other music file formats.
Open Windows Media Player from the Start menu if you receive a codec error while trying to play either audio or video files.
If you open the file in Media Player, the codec will download automatically.
You should then be able to play the file in Media Center.
Troubleshoot your firewall settings if a Media Center extender doesn't work.
You'll have a problem using an extender if Windows Firewall blocks it.
Go to "Control Panel" from the Start menu and double-click on "Windows Firewall."
Click on "Allow a program or feature through Windows Firewall."
Click to check "Media Center Extenders."
Click on "Apply."
Check external speaker cables to make sure they're connected if you can't hear any sound. Check the computer's volume settings by clicking on the "VOL+" icon at the bottom right corner of the main Media Center screen to make sure the volume is not turned off or down too low.
You may need to reconfigure your speakers if you're having volume or sound issues.
Scroll down to "Tasks" in the Media Center home screen and select "Settings."
Click on "General" and select "Windows Media Center Setup."
Click on "Set Up Your Speakers."
Follow the on-screen prompts to reconfigure your speakers.
Dec 01, 2013 | Gateway ONE GZ7108 All-in-One Desktop PC
Sony VAIO VGC-RB38G PC Desktop needs the media center re-installed
I would seriously doubt that your kids know how to remove Media Center. Maybe they just removed the icon from the desktop. Click Start/My Computer and open the Local Disk C. Look for the Programs File Folder. If you are using Windows 7 or Windows Vista there might be two Program File folders (Program Files and Program Files (x86). Look thru the program files folders for the Windows Media Player Folder or Windows Media Center Folder. Open the folder and look for the Media Player. When you see the Icon you can Right Click on it and select Properties. If the Type of File in the properties windows says Application, that is probably the program that runs. You can close the properties window and double click on the icon and see if it runs.
If it runs, you can close it and go back into the folder and Right Click on the icon and select the option Sent To then select Desktop (create Short Cut). Right Click on it again and select option to Pin To Start Menu.
If you just want to download and install it again.
Get onlineand got to www.google.com In the google search box type: "Download Media Player" or "Download Media Center" (without the quotes). Select a site from Microsoft that will download and install it.
Apr 30, 2012 | Computers & Internet
My media center is not working,when i traced the location it says it has been deleted,,,so how can i have it back the deleted media center??///
Yo! I will have to direct you to a website where you can download anything for your computer.you can download drivers and applications from them.you can also visit ASUS website to download the driver. please follow the link below..
www.download.com
Jul 31, 2011 | ASUS Computers & Internet
I had put new hard drive i took it to fry to download widows but missing media center cant watch cable any more
for Win vista media center.
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGCRA840G&upd_id=2439&os_id=28
This utility updates the VAIO® Media Center to version 6.0.00.10100 and provides compatibility with the Microsoft® Windows Vista™ operating system.
Mar 26, 2010 | Sony VAIO VGC-RA840G PC Desktop
Media center will not play movies dvds
try to download video codecs for media center. or you can download VLC media player for you to play your dvds
Mar 25, 2010 | Computers & Internet
Dell Media center
go to Dell.com........go to drivers and downloads.......check to see if there is an update for the media center from them if there is download and install. When media starts up just reduce it so that you don't shut down in order to get any updates for media center. If Dell doesn't have one try Windows updates and see what updates they have for your system. If you have any questions just ask and I will answer as soon as I get it.
Thx
Aug 01, 2009 | Dell Inspiron E1505 Notebook
I want Download Windows media center edition how to download from thish software by internet.
Download utorrent from utorrent.com then download this:
http://isohunt.com/download/31113159/windows+media+center.torrent
And open it with utorrent.
Jan 22, 2009 | Microsoft Windows Vista Ultimate Edition
Computers & Internet Logo
61 people viewed this question
David Payne
David Payne
