Question about Eclipse Premium 34230 Car Audio Amplifier
Information on the Eclipse Premium 34230 Car Audio Amp
I recently just bought the Eclipse Premium 34230 Car Audio Amplifier from a friend but I can't find out online how much this amp is worth or Peak power.
  • Craig Struhs Jun 03, 2007
    additional: if you can answer this for me my e-mail is wahsfbplayer@yahoo.com.. Thanks for all your help!
Specs: 370x2 RMS@ 4 ohm STEREO (the AMP DOES NOT BRIDGE) CLASS A/B (also do not run it 2 ohms unless you like smoke) 0.004% THD @ 4 ohm 105db S/N @ 4 ohm weighted 200 damping factor 11.85" (width) x 2.05" (height) x18.50" (length) 16lbs Worth somewhere is the 200.00 range if it is in really good condition
Posted on Jun 06, 2007
Model 34230 powers up then one second later green power light slowly fades off. What can it be?
if ur fuse is not blown it might bee to wires touchin of grounding out it will put it into protector mode
Nov 21, 2010 | Eclipse Premium 34230 Car Audio Amplifier
How do i know what to turn the knobs to on my amps?
The gain should not be more then 3/4 and the other levels are all on your music preference and hearing taste...
Oct 26, 2009 | Eclipse Premium 34230 Car Audio Amplifier
Volume button wont work only to lower volume works
Are you talking about the Amp working in lower volumes or the cd player? If it is the amp do you have the speakers bridged.
Mar 06, 2009 | Eclipse Premium 34230 Car Audio Amplifier
Problem
you need to get a bigger ground wire and the cut in and out will stop the cutting in and out is the protection mode starting if it cant hold the thump a capacitor 2farad will hold the bass
hope this helped
Feb 15, 2009 | Eclipse Premium 34230 Car Audio Amplifier
CD Playerr not working properly.
hi, have you tried to clean the lens of the unit?
chris
Feb 14, 2009 | Eclipse Premium 34230 Car Audio Amplifier
Help my fuse is blow!
If the amp blows fuses only AFTER you send remote turn-on voltage to the amp, the amp probably has blown output transistors. To eliminate other possible causes, read through the following page.
Amp Troubleshooting
Let me know if you have any other questions.
Aug 25, 2008 | Eclipse Premium 34230 Car Audio Amplifier
Car Radio
hello. you can find what your manual at this linkhttp://www.eclipse-web.com/us-index.html.!!! hope this help's you. let me know "GOOD LUCK"
Aug 17, 2008 | Eclipse Premium 34230 Car Audio Amplifier
Amp turns on and off
loose power connections. check your terminals.
May 19, 2008 | Eclipse Premium 34230 Car Audio Amplifier
Reset
You need to conform that you have a good ground and 12v on the remote & B+ terminals.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
Dec 25, 2007 | Eclipse Premium 34230 Car Audio Amplifier
Eclipse 34230 no base
If the woofer isn't moving significantly, try the following settings:
gain at highest (most sensitive) setting
crossover at highest frequency
subsonic filter at the lowest frequency
If those do nothing and you have a dual voice coil woofer, you may have one coil reversed. If you disconnect one voice coil and the woofer moves significantly more, check the polarity of all speaker wire connections.
Here's a brochure for the amp:
http://cartoys.com/cartoy/pdfs/eclipse_amp_manual.pdf
You're correct. this amp cannot be bridged to produce more power. It's minimum safe load is 4 ohms per channel. It's essentially two bridged amps in one chassis.
Oct 16, 2007 | Eclipse Premium 34230 Car Audio Amplifier
Eclipse Premium 34230 Car Audio Amplifier Logo
538 people viewed this question
Top Eclipse Car Audio & Video Experts
xxxxxx xxx
Steve Sweetleaf
Steve Sweetleaf
Are you an Eclipse Car Audio and Video Expert? Answer questions, earn points and help others
