Trekstor DataStation pocket x.u 120 GB USB 2.0 Hard Drive
Problem for Trekstor DataStation pocket x.u 120 GB USB 2.0 Hard Drive
External harddrive not recognized
By pohliflo on Jan 09, 2009
trekstor datastation pocket x.u 120 GB can not be installed, where can I find driver?
Solution #1
posted on Jan 09, 2009
Somewhat Helpful)
Alcatrazx
Rank: Wiz
Rating: 79%, 46 votes
Hi there
I am assuming that you are installing this on VISTA or XP. First of all you should make sure that you are actually connecting to a reliable power source because most of the time the USB enclosre you are connecting to would not supply sufficent power to power up the drive so I do not think that at this point in time it is a driver issue. Also make sure that if you have 2 wires you connect BOTH and not just one of them to the USB. If you have WIN XP Service pack 1 upgrade to Service pack 2. Vista should be ok. Another thing you should check is that if you have another computer (different brand if possible) see if this drive works fine on the other one. Also make sure that if you are connecint you hard drive to the FRONT USB try the BACK ONES and seee if that improves matters. Last thing you should check is the BIOS settings: make sure that you are the voltage of the USB's is set to the highest possible and that the mode is USB 2.0 (in CMOS). Hope that these solutions will solve your issue!
CHEERS
Was this helpful?
Yes
No
Popular Solutions for Trekstor DataStation pocket
Questions and Unsolved Problems for Trekstor DataStation pocket
Do you recommend Trekstor DataStation pocket x.u 120 GB USB 2.0 Hard Drive?
Answer
Answer
problem with hdd at start up press enter and F4 to continue
Answer
my buffalo hd-ce1.otu2 will not power up
Answer
how can i remove the hard drive from the trekstor datastaion pocket x.u aluminum casing? plz help... (More)
Answer
I have a TrekStor g.u. pocket 320GB but i decided to re install windows XP. Now i lost the CD and... (More)
Answer
my trekstor datastation pocket x.u. 120 GB can't be installed, please where can I find the driver?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Hard Drives Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
