Question about Freezers
My table top freezer is not freezing
I just bought a table top PRIVILEG freezer and after i connected it i found out that it work a little and keep tripping and so it will not cool. what may be the problem.
I need your assistance
  • Starnley Johnwells
    Starnley Johnwells May 11, 2010
    since the the temerature keeps going down
    or up may be due to the bad thermistor/sensor. The readouts to the display does it show
    correct temperature?or due to faulty indications of those
    sensors. when you unplug the fridge
    and turn it back on -did it show the actual temperature. does
    thae sensors read temperature correctly or Its like something starts to
    affect the sensors after short while the fridge is on.
  • 700 Answers
If its tripping the breaker you mayu have too many devices on that circuit or a loose wire causing the amperage togo up after it runs awhile I would go and tighten all the wires first on the breaker panel then the plug and then see iff it still does it. Let us know if thiss solves the problem oir if it fixes it. Thanks for using FixYa.
Posted on Jan 09, 2009
Freezer does not freeze anymore
the freezer usually has the condensor coil sandwiched ilong the outer cabnet and in the back the lines come out in to the compressor compartment as a tech i have found the steel line rusts where the epoxy coating is no longer in tact so i would say you most likely have leaked out the refrigerant
Feb 10, 2013 | Freezers
Modle evl201nxrq00 not cold enought to freeze food
I need you to feel the top of the compressor and tell me how hot it is. Also tell me if the condenser fan next to the compressor is running. If the top of the compressor is too hot to keep your hand on top the problem may be the=> 4356738 Start Relay also found here=> 4356738 Start Relay Here is a link to the repair parts list=> EVL201NXRQ00 Repair Parts List You can see the parts listed on page 5 and 6 of the above parts list. Hopefully this is the only problem causing your freezer to stop freezing as well. If the 4356738 Start Relay is defective it will cause the problems by not allowing the compressor to run or start very well also cause the top of the compressor to overheat. You may also need to change the=> 8210224 Capacitor also found here=> 8210224 Capacitor And the=> 2-34286-021 Overload also found here=> 2-34286-021 Overload Feel the top of the compressor first and let me know the results and we will go from there, Thanks Sea Breeze
Dec 05, 2012 | Whirlpool Freezers
Why is my freezer not freezing
I had this happen to my freezer and I had to install a fan in the freezer by a repair man and then it worked like brand new.
Jul 18, 2012 | Bush BAF55143W Freezer
Not freezing
Check your circulatation fan. It may be stuck. Keep me informed The Raz Shack
Apr 20, 2010 | Frigidaire 14.1 cu. ft. Upright Freezer...
Freezer goes in cycles - some days it freezes fine then other days we wake up and the meat, etc that is in the freezer is no longer frozen. Freezer is on top of refrigersator. Refrigerator is fine
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Mar 07, 2010 | Maytag 15 cu. ft. / 425 liter Upright...
Upright freezer. I can put a cup of water in the
Is any thing infront of the fan or vents?
Feb 17, 2010 | Freezers
Freezer not freezing at the top. But tray at the bottom freezes.
Jan 14, 2010 | GE 16.7 cu. ft. Upright Freezer FUF17DTR
Brandt apollo fridge/freezer - food defrosts + salad freezes
Check the vents in the fridge side and close a little if you can. On the freezer side just for good measure>>>>
Jan 05, 2010 | Freezers
Frigidaire FP120V Fridge is too warm, yet freezes in crisper
There may be vents that need to be closed and or opened a little for proper adjustment.
Jan 04, 2010 | Freezers
Top part of upright freezer not freezing and bottom part collecting ice.
check for food blocking any vents and for good measure>>>>
Freezers Logo
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
