Question about Datalogic PSC QuickScan QS6500 Handheld Barcode Scanner
Problems with very small Barcodes
I use a Datalogic Quickscan QS6500. I can´t read Barcodes that have less than 4 characters. An older Scanner (DLC6090-M1) reads the small Barcodes without problems. Is it a problem with the datalogic scanners???
  • billybarcode May 11, 2010
    call me...I can probably help. It's probably a set-up based on the symbology of the code. Some codes, (I 2 of 5 for example) have minimum and maximums available. It's probably a set-up problem - or if the barcode is physically "small" i.e. high density, it could be you have a scanner that wasn't designed for it. My number is 1-866-306-7226 and I am in Mountain Time, so bear that in mind when you call. Bill Matisz qdata inc. 1-866-306-7226
Default settings set a global limit of 4.
You can set the global minimum code length by following the instructions in the user manual on page 24:
1) Start
2) Set Global Min Length
3) Scan the number on page 303: I.e. '0' followed by '3' to set length to 3
4) Set
5) End
Posted on Apr 23, 2011
Printed id barcodes, they will not scan
Check the quality of printed barcodes. ink and paper quality can cause an issue
Sep 27, 2013 | Datalogic QuickScan® QS6000 Plus...
Programming tab suffix
This manual may have the right barcode images to program your scanner.
http://www.posguys.com/download/QS6500BT_Manual.pdf
If not, a call to the manufacturer is how I solved the "how do I program the scanner" issue I had to solve.
Best of luck! Jon : )
May 30, 2013 | Datalogic QuickScan QS6000 Plus Bar Code...
Quickscan 6000 will read not read programming barcodes
usually there is a laminated like square piece of paper that gives you 4 options to scan and one of them is auto
Jun 06, 2009 | PSC QuickScan 6000 Plus Handheld
Cannot get the datalogic qs6000 to scan 39 or 128 barcode
Sounds like you need an updated driver for your POS scanner.
Other than that, try checking the scanners setting your software and make sure it is set for 39 and 128 bar codes. There is usually a setting that will specify what codes the scanner is going to read.
You can always shoot an email over to the datalogic guys and see if they have any more input on the situation.
Jan 22, 2009 | Datalogic QuickScan QS6000 Plus Bar Code...
PSC 6000 Plus not scanning
There are a few questions:
What kind of cable do you use?
USB, SERIAL, PS2
What kind of computer?
Normal computer or Laptop?
Then...
When you recieve the scanner like new you always have to program it.
First you do
Reset to factory defaults.... Never do this with working scanners
then
you have to program it.
First the Connection type
and then if needed a computer type.
After that you usually have to scan a suffix.
This means when you scan a barcode it needs to do something after.
normally it doesn't give Enter after you scan.
That is what the suffix is for.
and then you scan additional symbologies to scan
Like Code 39, UPC A etc. etc.
It needs to be programmed with the manual you recieved.
if you don't have it you can download here.
http://www.scanning.datalogic.com/sitefiles/manuals.aspx
go down in the list to quickscan 6000
and programming manual.
please don't print all the pages. only what you need.
If you need more help i will hear it.
good luck.
Jan 09, 2009 | Datalogic QuickScan® QS6000 Plus...
Datalogic PSC QuickScan QS6500 Handheld Barcode Scanner Logo
620 people viewed this question
Top Datalogic Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Paul Bade
 Ian Kayhan
Ian Kayhan
Are you a Datalogic Computer and Internet Expert? Answer questions, earn points and help others
