Question about Philips 105S51 15" CRT Monitor
Phillips monitor 105s,width is problem
While pressing width button width remain same no increasae neither decrease
  • 55 Answers
Change 8pin memory ic of monitor .
Posted on Apr 21, 2009
How can I decrease brightness and contrast?
To help you change the brightness and contrast settings from the LCD monitor, please follow the instructions mentioned below,
The control buttons are located at front panel of the monitor. The Brightness Button is used to select the Brightness/Contrast adjust functions. Press to switch functions or adjust settings.
To decrease the brightness or contrast press (-) button & to increase (+) as per your adjustment.
GuruAid.com
Mar 29, 2016 | Dell E173FP 17" LCD Monitor
Explain how the monitor buttons work
Monitor Icon Description of icon function moncont.gif Power - Turns the monitor on or off.
Brightness - Using this button or wheel the user can increase and decrease the brightness on the screen.
Contrast - Using this button or wheel can increase and decrease the amount of contrast on the screen.
Horizontal Size - Allows for the picture on the screen to be stretched to the horizontal edge of the monitor.
Vertical Size - Allows the picture on the screen to be stretched to the vertical edges of the monitor.
Horizontal Position - Allows the picture to move moved horizontally, once in the center the user can then use the Horizontal size to stretch it to have an equal amount of black border on each side.
Vertical Position - Like the Horizontal Position, using this button or wheel the user can move the picture up or down to center the picture more appropriately.
Full Screen - Sets monitor to full screen.
Degauss - This button will degauss the CRT, restoring possible color impurities. After this button has been pressed the degaussing circuit will be activated and then deactivated after a few seconds. Pressing and holding this button for a few seconds may cause your computer monitor to reset all data.
Corner and Trapezoid Correction - Using this button or wheel the user can either round the edges of the picture or move the picture inward like an hour glass or outwards.
Vertical Linearity - Sets the width of the vertical lines.
Moire - Removes or reduces the Moire effect, if any.
OSD Controls - If the monitor contains OSD controls, allows for the OSD menus to be adjusted.
Power Management - Allows the user to define the power management settings through the monitor itself and not the software.
Monitor Status - Displays the current monitor settings such as refresh rate and other settings.
Language - Sets the language on the monitor.
Aug 16, 2014 | Computers & Internet
I have a Philips 105S5 15" monitor and its OSD is
"OSD Lock" is the On Screen Display Lock, a feature designed to prevent you from accidentally changing any of the settings of the monitor. To disable the OSD lock, press and hold the menu button for 10-15 seconds.
Dec 30, 2010 | Philips Standard 105S Monitor
How do you adjust the height and width of the screen?
there will be buttons on the screen monitor....front/side/back
one for the function and others for increase / decrease...etc...
u r the best judge how to do it...as the monitor is with u...ur machine has to be on and the monitor should be getting signal and in working mode...for u to adjust
Dec 22, 2009 | E-Machines eMachines Monitor E15T4
I need to adjust the hieght and depth of the screen on monitor X173W LCD
The buttons on the monitor are used for this.
With computer and monitor powered ON, press the [menu] button on the monitor.
use the on-screen labels to guide you. Press the button labeled <-> to adjust width, press the ^ v labeled button to adjust height, etc.
Press the [menu] button to exit.
Sep 26, 2009 | Acer Computers & Internet
The brightness adjustment bar appears on the screen all the time
Press the menu button on monitor select the brightness press the menuside button increases or decreases.after select exit oress the exit button on monitor.
Jul 13, 2009 | Compaq CV 7500 17" CRT Monitor
My screen adjustment buttons aren't working properly
other way to adjust your screen right click on desk top then press properties then settings. thank you....
Feb 04, 2009 | Philips Standard 105S Monitor
Ibm E54 monitor width problem
1.To replace TIP122 and it's related transisters (A733,C945) tracing TIP122 pins
2.Change Flyback caps
3.Open OSD select ZOOM Option and press 20 sec OPEN SERVICE MODE decrease the Width option &save it
4.Switch off the monitor
IF these solution was usefull pl appreciates rating
Nov 19, 2008 | IBM E54 15" CRT Monitor
More Brightness
on the front of the monitor there are key buttons naming menu, ok button and left & right arrow marks buttons first press menu button then go to brightness then by using arrow keys you can increase & decrease the brightness once you are finished decreasing r increasing press ok button.& there are many other settings you can change like contrast etc....
Feb 07, 2008 | LG Flatron 775FT 17" CRT Monitor
IBM MONITOR ON SCREEN DISPLAY
This is a problem in the monitor itself. The computer has absolutely no control over the On Screen Display. Most likely the button that controls contrast is stuck. You might try blasting the button with canned air. Sounds like it might be time to buy a new or used monitor.
Jul 31, 2007 | Samsung SyncMaster 551 15" CRT Monitor
Philips 105S51 15" CRT Monitor Logo
210 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
