Question about Microsoft Windows XP Home Edition
Repeating Startup I have a new problem with a new set-up. I just installed a new motherboard and cpu. Finished formating the HDD and upgrading to XP SP3. I installed the video drivers and MS office, restarted the and everything was fine. I installed a fire wall (Zone Alarm Pro) and drivers for the sound card. Now the computer is locked into a repeating start up. I gets all the way to the desk top, I get a message about activating the fire wall, then the system resets itself and goes back through the same procedure. Win XP SP3 Motherboard: Asus M3A78 Pro CPU: Athlon X2 6500 Memory: 1G DDR2 667 HDD: Maxtor 160G
    President:
  • 949 Answers
The first thing is to make sure that you did not use quick format,
then after the OS is installed you have to install the chipset drivers
for the motherboard, then you install the graph drivers, then sound,then lan, So I would say the best thing to do is go to asus
find your board and download all the drivers, Asus is the top board on the market and there site is awesome and have all the drivers you need. So reinstall windows,no quick format,also, when you see the page to setup windows,look down and pick delete the drive,then it asks you two more times,pick yes, the you will see the same page
with the drive showing a little white box, pick apply, this will set the full size of the hard drive, then you see the drive,(C--new raw)
now install windows to this and format. when all is done, install your chipset driver,restart system and so on. Hope this helps.
Posted on Mar 23, 2009
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 72 Answers
U Will Have to Work in Safe Mode:
Press F8 Continuisly on Startup.
Go to Safe Mode:
Uninstall Unwanted Applications
Helped.Or Reformat;
Posted on Jan 09, 2009
HOE DO I REMOVE XP OPERATING SYSTOM FROM HARD DRIVE
Are you trying to upgrade from xp to windows 7? First check if your hardware can support windows 7. You should have atleast 2 GB or above memory, 60 GB of HDD for windows alone so 320 GB HDD would be recommended. Your cpu should be dual core or core 2 duo atleast. If those are checked, upgrade to windows should delete your windows xp.
Or the other option is format the partition of the HDD where windows xp is installed.
Let me know more. So that we on the FixYa can help.
Good luck
May 28, 2014 | Dell Inspiron Computers & Internet
Intel D955Xcs wont boot sata hdd after bios upgrade
1:)Use the original windows xp and repair it!
2:) Check the ram
3:)If you can LOGG INN  with SAFE MODE and log as ADMINISTRATOR and when u have logget inn go start + run + msconfig +enter +startup + DEALBE ALL + restart
4:)Replace WGA
5:)CLEAR CMOS
 if all of those options wont work so :
TAKE THIS HDD AND PUT IN ANOTHER PC
GO TO THE COMPUTER MENAGMENT + DISK MENAGMENT MAKE THAT HDD AS PRIMARY AND ACTIVE AND PUT BACK TO THE ANOTHER PC!
IF U NOT GET HELP OF ALL THOSE TRY LIVE ASISTANCE WITH ME AND I WILL HELP TO FIX IT OK?
Oct 20, 2007 | Computers & Internet
Hi there, my problem is ,my windows xp can't startup. i thought my OS has problem, then i try to reformat it (reinstall winxp). the format process fail to complete as well. I try to format same HDD to...
There are a few things you can try . First , try this : the computer is off . Turn it on and Press F1 key repeatedly or whichever key applies to your computer that enables you to access your BIOS settings . Then , using the arrows you will select boot options or boot settings . Then , you want to arrange the boot order device sequence so the CD is first. Some computers display a boot device options when you first and computer on by pressing a special key, like ESC or F12. You want the computer to boot from the CD ROM with your XP disk in the drive. This should allow you to properly format the HDD and install XP. If that doesn't work , check your BIOS settings and select the default configuration , then be sure to exit using the exit dialogue box and select exit saving changes and then yes when prompted . Then, do the device boot options thing one more time with the CD as the first boot device .
Apr 27, 2010 | Microsoft Windows XP Professional
Hi guys, I'm new in this forum and I really need some help. I have a p4vmm2 motherboard with Intel Celeron 2.0 Ghz CPU and I want to upgrade it with Intel Pentium 2.4 CPU motherboard. I have already tried...
Whenever you try to upgrade motherboard and CPU's with Windows XP, you're probably going to have to format your drive and re-install XP. When you originally install XP it detects the motherboard and IDE controlers for your hard drives and installs the drivers needed but it doesn't install all drivers for motherborads and IDE controlers. When you swap out motherboards and the system tries to fire it doesn't have drivers available for the new motherboard and can't complete the boot into windows. Every once in a while you get luck and the new and old motherboard can use the same drivers but this is very rare. So when upgrading motherboards plan on backing up your hard drive of all files you need to keep and being prepared to format and re-install windows.
May 15, 2009 | EliteGroup P4VMM2 V8.1 Motherboard
Motherboard and cpu upgrade
Your hard drives are not setup for that mobo run the windows cd again/safe boot if you can (via f8) but do not format just install
Jan 03, 2009 | Computers & Internet
Emachine W2047 No BIOS Start Screen
Replace motherboard. Processor socket burnt out, contact me for further support at compdoctor2005@btinternet.com
Dec 07, 2008 | E-Machines EMA IMPERIAL GV (845GV) TG3...
Not booting up
The OS doesn't like all the changes that were made. To keep people from cloning hard drives and putting them in whatever machine they want, microsoft winxp recognizes even subtle changes, upgraded cpu, memory video cards etc.
  1. put the hard drive in the old machine
  2. run link
  3. Software
  4. click on Installed Program
  5. click on licenses
  6. .click on report
  7. quick report licenses html
  8. click on print
  9. select page 1
These are the key codes for your machine,
now put hard drive in new machine, boot with xp pro cd and choose repair option. re-enter key code when prompted and telephone Microsoft in activation wizard.
Apr 08, 2008 | EliteGroup GeForce 6100SM-M Motherboard
My system doesn't see 500GB HDD (SATA) (Seagate Barracuda)
Can you see this HD in:
Control Panel/System/Device Manager?
In Computer management?(Rt.Click My Computer/Manage/Disk management)? You can also format the disk here.
Oct 14, 2007 | Soltek SL-75FRN2-RL Motherboard
Hdd upgrade problem
Try reversing the connections so the new drive is detected as the primary master.
Oct 07, 2007 | Gigabyte GA-7VTX Motherboard
Microsoft Windows XP Home Edition Logo
98 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
