Question about Indesit W 123 Front Load Washer
Washing power drawer, the fabric softner section
Indesit 1200 w1235 the fabric softner section is always full of water, how can drawer be removed for cleaning
  • alancotton10 Jan 09, 2009
    Thank you worked perfect
  • Indesit Master
  • 3,463 Answers
Pull the drawer out as far as it will come and then grasping it firmly, give it a good tug towards you, this will free the drawer to enable you to thoroughly clean every piece of it, particularly the conditioner parts of it.
Get a piece of wire with a bend on the end, and poke it in to all the holes in the top of the dispenser compartment, this will clera any blockages there.
Plz rate my solution, and feel free to leave any comment.
Thanks.
Posted on Jan 09, 2009
Fabric drawer section fills with water after every wash
the siphon cap in the fab con section of the draw is blocked the water is drained away by using a siphon remove the draw from the machine you should see a up-stand with a removable cap on it take it of and clean all the gunge out
Feb 26, 2014 | Creda Washing Machines
The fabric conditioner drawer is always full of water at the end of the cycle, i have tried cleaning it and running the machine empty but nothing has worked.
fabric conditioner drawer is always full of water This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 02, 2011 | Washing Machines
Water in the fabric softner compartment after wash cycle
You need to poke all the holes clear in the top of the dispenser housing with a piece of wire or similar.
This should solve the problem.
Dec 15, 2009 | Washing Machines
THE FABRIC SOFTNER DRAWER IS ALWAYS FULL OF WATER ON OUR TRICITY BENDIX 1000 WASHING MACHINE
This is usually because the fabric softner draw is prone to colgging due to a build up of gunk in the holes that drain the softner into the machine at the appropriate time. Remove the drawert (There is usually a thumb press release at the back of the drawer you will see if you pull it out as far as you can.
After removal, wash the drawer all over (paying particular attention to the bottom of the drawer). If you have a garden hose, take the drawer outside after you have cleaned it and turn the hose on, full belt, and blast out all the waterways in the drawer to make sure they are clear. Refit the drawer and this should sort out the problem
Oct 09, 2009 | Tricity Bendix Washing Machines
Fabric Softner
that is normal you can either add water to make it drain or pull out the drawer and dump it.
Sep 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I have a Bosch WFF 1401. I removed the drawer as I sometimes do to clean it. Since I replaced the drawer the softner section is always filled with water and never empties.
There can be 2 reasons. The centre section dispenses the fabric softener in the last rinse. It works on a syphon effect.
If it is not assembled correctly the water flows over the side to avoid a flood and leaves the middle section full at the end. Make sure the inner pipe is inside the outer pipe and that both are completely clear of softener residue. As you have just reassembled it this is the most likely cause.
The second reason is the water inlet can become blocked therefore not creating sufficient flow to create a syphon effect. It gets blocked with black gunk and needs to be cleaned with pipe cleaners or a long cable tie. There are 4 rectangular holes above the centre section, near the front. They can be seen easily if you take the drawer out.
Hope this helps
Nick
Jun 24, 2009 | Indesit W 123 Front Load Washer
Jetstream 1200 wont take away fabric softner
strip and clean out the soap tray then remove the tray and clean the fill water holes above it with a stiff washing up brush.
Mar 16, 2009 | Zanussi ZWF1430W Front Load Washer
Clogged fabric Softener
I had the same issue, and ran vinegar through the fabric dispenser with a load of towels. Not only did it solve the 'sour towel' problem I had with that load, it also cleared my fabric softener section. Now, I water down all fabric softner when I use it, which is less frequently!
~Steph
Nov 11, 2008 | GE Energy Star WCVH6260F Front Load Washer
Frigidare Front Load Washer dispenser drawer wont drain.
I think you have something stuck in the fill hose.. Remove the top two or three screws in the back.. then pull out the hose that goes to the tub. I bet you will have something in there.. most common is the inside liner to a bleach cap..let me knowif this it it... krazytech
Sep 08, 2007 | Frigidaire GLTF2940ES Front Load Washer
Fabric Softner Drawer
Hotpoint Aquarius WMA42 Front Load Washer
a 4 THUMBS rating is appreciated for answering your FREE question..
Feb 11, 2007 | Hotpoint Aquarius WMA42 Front Load Washer
Indesit W 123 Front Load Washer Logo
261 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
neilmoto
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
