Question about Lexmark T642 Laser Printer
Error 906 for mfp t642 - Lexmark T642 Laser Printer
    Problem Solver:
  • 13 Answers
  1. Turn off the printer and let it sit for at least 10 minutes.
  2. Then power the printer back on.
    • If the error does not return, try printing a few print jobs. If the error still does not return, continue using the printer as before but keep an eye on it for the next few days. If the error does not return, it may have been an isolated incident.
    • If the error does return, you can perform an NVRAM reset on the printer. Note: Please do this only as a last resort before requesting service. Resetting the NVRAM on the printer will cause the printer to return all customer-defined settings to the factory defaults. To perform an NVRAM reset:
      1. Turn off the printer.
      2. With the printer still off, press and hold the following three buttons: Select, Go, and the right arrow (>) Menu button. All three of these are located on the printer's LCD screen.
      3. While holding the three buttons down, power on the printer.
      4. Continue holding these buttons until you see Performing Self Test, Clearing NVRAM, or Restoring Factory Defaults on the printer's LCD screen. You can then release the buttons.
      5. If the error does not return on power up, continue using the printer but keep an eye on it for the next week or two.
        • If the error does not come back, the printer should be fine.
        • If the error does return, the engine/system board will most likely need to be replaced.
Posted on Feb 06, 2009
What can i do when my lexmark T642 printer displays 922.02 service fuser error when the printer was never used?
It could be the connector to the fuser from the LVPS is not connected properly. It could also be the Thermistor on the fuser is bad.
Jan 31, 2017 | Lexmark T642 Laser Printer
T642 wont print unless I cycle the power after a certain amount of time
The error 0x80004005 is a permission issue in Windows. Try running the file as Administrator.
Nov 09, 2012 | Lexmark T642 Laser Printer
Lexmark T642 929.00 Service toner Sensor
The most common cause of this error is the toner cartridge. For more details on how to troubleshoot this problem, please click on the below.
http://bitly.com/oTXG4M
If you need further assistance please contact Lexmark Technical Support.
Oct 17, 2011 | Lexmark T642 Laser Printer
Lexmark T642 output bin error
Remove all option output like 4-bin mailbox, expander or stacker, if you have any, and see if problem persists. If this doesn't help, if there is no paper where the exit bin is, most probably the exit flag is out of position, stuck or possibly broken. This article might help you resolve the problem. Just click on this link: http://bit.ly/dhOTEo. Thanks.
Aug 05, 2010 | Lexmark T642 Laser Printer
T642 getting a watchdog error with no other error codes
Hi, the way to fix this problem is by updating the firmware on your printer. Go to support.lexmark.com/printerfirmware and use the following keycode: lsstp240 that will download the firmware that you need to flash to your printer. To flashed you can do the following. If your printer is connected to the network then go to a browser and where you will type the Url (ex www.fixya.com) type the IP address of the printer. Then go to configuration, then go to Update firmware and browse for the firmware that you just downloaded and hit send. The printer will start beeping and saying updating firmware do not turn off. Once the firmware update is complete then the printer will restart and you should not see the watchdog error again.
Dec 30, 2009 | Lexmark T642 Laser Printer
Lexmark T642 When printing, LCD displays
this error is a scanner lost lock error and can be caused by the scanner or the logic board. if this error comes up immediately on power up the scanner motor is not initializing by percentages of failure the scanner is approximately 85% the logic board 15% i would change the scanner
Nov 23, 2009 | Lexmark T642 Laser Printer
920.07 code on a t642
a 920 error means your fuser is under temperature at standby. you should replace the thermistor it cycles the fuser on and off to maintain these temps
Nov 06, 2009 | Lexmark T642 Laser Printer
Lexmark T642 Laser Printer error message922 02
Service fuser error requires a maintenance kit, this is approx $1000 + installed, if this is new, I would be taking it back because it shouldnt have this error. You possibly might be able tto fix it by replacing the fan in the back but thats only worked for me in approx 1 out of every 10 times.
Jan 13, 2009 | Lexmark T642 Laser Printer
Printing Issue - Lexmark T642
Chip on toner is bad, try puting in old one to reset and switch it with new one, sometimes turning off and on several times helps.
Mar 12, 2008 | Lexmark T642 Laser Printer
Lexmark error codes
Too many to list here. Try justmanuals.com, you can get the service manual for about $10.
Jan 14, 2008 | Lexmark T642 Laser Printer
Lexmark T642 Laser Printer Logo
518 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
