Question about MTX RT202 Car Audio Amplifier
Rt 202 led light red and no sound
My amp rt202 led light is red and willl not put out any sound wat should i do?
  • 1 more comment
  • kjnrydr Mar 22, 2008
    My amp light is red and fuses are good but there is very low output. I can feel the output but can't hear it.
  • Anonymous Mar 15, 2014
    what does it mean if the red and green led lights on my amp flash in an alternating pattern?
  • Anonymous Mar 22, 2014
    I have a 1000 wat t1 fos gate power amp and when I cut it on it do sent put any sound out but the power light stays on
  • 156 Answers
With the system turned off, disconnect the speaker wires from the amplifier. Turn on the system. If the light stays red, then the amplifier has an internal problem. If the light turns green, then your problem is a blown speaker, or a speaker wiring issue.
Posted on Jun 04, 2007
What can you advice me to do? i have a UPS SURTD5000XLI, indicating a red Led light, but when i remove it from the AC power source, the Red Led also remove & when i flog it again to the AC Source it...
Is red light on for overload or for battery?
If on overload, try reducing the load on the UPS. If red light on overload persists buy a new UPS (overload fault hard to repair).
Red light on battery - replace the batteries.
Red light on boost or buck, may mean that the nominal voltage of ups and the limits need to be changed/corrected.
Jun 23, 2014 | APC Smart-UPS RT 5000VA (SURTD5000XLI) UPS...
No red led on front panel & wont power on at all
Check the wall outlet to see if you have power going to the TV. Next, the case will need to be opened; look inside for a fuse near the power wire. Beyond that you will need someone with TV experience to help you.
Jan 12, 2013 | Coby LEDTV2226 22 in. TV
Next to no output from amp. verified all connections and power, ground. Protection LED not on. green LED light is on. verified sub is in working order. this amp is need of a service. what can be done
well... you have to wire the sub correctly to the amplifier to get good sound.. you could be giving it like an 8 ohm load and this will cause the amp to put out barely anything at all.. www.the12volt.com and the subwoofer wiring diagram willl tell you all you need to know...
Dec 02, 2009 | Kicker ZX300.1 Car Audio Amplifier
Not producing any sound
Have you confirmed that the speakers are in good working order?
Sep 11, 2008 | MTX RT202 Car Audio Amplifier
No power
You might have toasted you amp, take it to a car audio shop and ask them to test it for you.
Jun 23, 2008 | MTX RT202 Car Audio Amplifier
Car audio
hi, your amp seems to be getting power but the cables might be wrong so it's not getting enough power. the light on the amp should be green if everything is going well. are you sure the cables are suitable for your amp?
Sep 11, 2007 | MTX RT202 Car Audio Amplifier
Red LED "Protection Light is on" What is the problem
The red light means the amp is in protection mode. A few things can cause protection mode..... First disconnect the subs completely from the amp, and turn it on, if it powers up you have blown subs. Also try checking the main power wire at the battery...sometimes the current your meter is seeing is backfeeding from the remote wire, so your main power line could be blown at the fuse under the hood. hope this helps
Jul 17, 2007 | Crunch BlackMaxx BMX2250 2 Ch 1000W Amp...
Amp not putting out sound
This is not a problem that a normal comsumer should try to repair themselves. It's time to take it to a pro. It sounds like you have blown out at least one of your output channels. If you are getting any red light at all then the good news is that the power supply section of the amp is probably still good. About half of all the electronics in your amp is for the power supply section. The other half is for the actual amplifiers of the amp. Good luck, I hope it's not too bad.
Jun 14, 2007 | Alphasonik PMZ12005A Car Audio Amplifier
MTX RT202 Car Audio Amplifier Logo
464 people viewed this question
Top MTX Car Audio & Video Experts
hoyzee1
Mark Skinner
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
