Question about HP PSC 1315 All-In-One InkJet Printer
Prints is slanting to left (not line up straight).
  • liminhg Jan 12, 2009
    I tried it, but it doesn't work. The slanting is half an inch from the top to bottom.
  • 495 Answers
Hey, i think this could be a paper alignment problem. Align the paper properly in the tray.
Posted on Jan 09, 2009
Have problems with little vacuum lines, they are broken
Any auto parts store sells vacuum tubing in bulk. Just get as much as you need and replace the lines piece by piece. Cut with scissors to get a straight cut. Diagonal pliers cut on a slant and the end result looks sloppy.
Oct 27, 2012 | 1992 Ford Explorer
Holes won't line up to put new starter in place. On the chevy 1ton pickup.
COULD BE WRONG STARTER CHEVY HAS MANY SIZE V8 ENGINES FOR TRUCKS ENGINES ARE 4.8 - 5.3 - 5.7 - 6.0 - 6.6 AND 8.1 POSSIBLE YOU HAVE WRONG STARTER.
Jun 27, 2011 | Chevrolet Silverado 3500HD Cars & Trucks
I take a picture with my canon xsi camera and the picture comes out slanted. from the top of the picture it goes right to left.
If you're holding the camera straight and the photos are still slanted its possible the sensor has been jarred in which case you'd need to talk to a repair shop as that's not a repair I recommend trying to do on your own.
May 10, 2011 | Canon EOS Rebel XSi Digital Camera
I ran a new line for my dryer and instal;led a new breakewr in the panel wire the plug as such black wire to one slanted term the red to the other and white to the one in the middle straight one when i...
Black on one slant, white on other slant, red in the middle. Red and green are ground wires throughout electrical. Black and White are always hot and nuetral.
Aug 05, 2010 | Dryers
Convergence lines are SLANTED. Red line is above
Your TV most likely a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Apr 26, 2009 | Hitachi 53FDX01B 53" Rear Projection...
Convergence lines are SLANTED. Red line is above horizontal center on left side on screen and below horizontal center on the right side of screen. Also left of Vertical center at the top of the screen and...
did you check the six 3.5 pico fuses that are next to the ICs? They will often be open ( blown) when the ICs fail. Also check the two 5 amp IC protectors on the G board as those protect the two ICs so its possible they have blown also a 5 amp pico can be substituted for the two IC protectors.
Apr 26, 2009 | Sony KP-46WT500 46" Rear Projection...
Vertical lines slanted on photocopier
Is it the same result when you place the original on the glass as when you use the Automatic feeder? If copy is straight when you use the glass, then the rollers on the feeder need cleaning (with a damp cloth) -Lift the cover where paper feeds and clean grey rollers,also, and more importantly, clean the darker roller which has a plastic white roller pressed to it with a heavy spring assembly.
If copies are slanted either way you make a copy, make sure to check the paper guides in the tray are snug
Feb 17, 2009 | Ricoh Office Equipment & Supplies
Printer prints crooked (8.5 x 11 from paper tray)
check that the paper guides on paper cassette are hard up against paper edges
Oct 27, 2007 | Brother HL-2070N Laser Printer
Slightly slanted screen/picture
your main filter capacitor in power supply has gone defective.
just replace it .
every thing will be normal.
good luck.
Oct 17, 2007 | Toshiba 36AF43 36" TV
Problems with taking pictures of horizons and buildings
This Nikon's expertise to fix - contact customer support- they may repair or offer a replacement.
Jun 04, 2007 | Nikon D50 Digital Camera with 18-55mm Lens
HP PSC 1315 All-In-One InkJet Printer Logo
35 people viewed this question
Seeker5211
Seeker5211
