Question about Panasonic PT-47WX53 47" Rear Projection HDTV
The color converter
My 47" Panasonic projection T.V. is showing a cruved line with part of the screen missing. And the colors are not right also. A TV repairman
said that he thought it might be the color converter. Can I change that my self. Rob
    Problem Solver:
  • 17 Answers
Seems to me you maybe experiencing a convergence issue rather than the color converter. (Don't know what he means by that for that I am an a tv repair technician).
If it is what I beleive it to be, you need and experience tech to do the work for you. It usually contains replacing two convergence IC packs along with some resistors and sometimes power supply parts. All wich requires good soldering work.
Posted on Jan 09, 2009
I have a Panasonic pt-53x42 projection tv. I believe i have a convergence problem. I have double lines running along bottom of screen..Any help please...
Yes,this problems is 100% convergence problems,it dead.The tv have colors lines R,G,B mis alignments anywhere in the pictures,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to solved the tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 23, 2010 | Panasonic PT-47WX53 47" Rear Projection...
The Panasonic mod# pt-47wx49e has started to have a blue and a yellow shadow on the right side of the screen. the rest of the screen is normal. The operating instructions give you diddle to on. Do you have...
Ur tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignments,have colors shadows or 3D colors pictures.The tv convergencce board the 2 STK convergence ICS and some or all it resistors are dead.These parts must be replaced to solved the tv picture convergence problems.The shop,will cost u $300-350 for parts and labors.
Oct 10, 2010 | Panasonic PT-47WX49 47" Rear Projection...
RED ARCH ON LEFT BOTTOM CORNER
This is a very common failure on Projection TV sets.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
You can see some example photos and find a solution here...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Jul 16, 2009 | Panasonic PT-47WX53 47" Rear Projection...
No convergence of color lines
You can get the PT47WX49 Convergence repair kit at the following link which contains all the parts and complete detailed photo instructions on CD so you can do the repair yourself.
www.tvrepairkits.net
Jun 25, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic 47 inch Projection tv PT-53WX42F
Sounds like your convergence chips are going. Unless you are real handy with soldering iron I would suggest having a tv repair shop service it(probably cost $200-300). If you are handy then I believe the chips you need are Sanyo STK392-110. There should be 2 of them. be careful if you order them online, there are lots of chinese knock-offs out there.
Apr 19, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Samsung 52" rear projection tv convergence problem?
THE PROBLEM IN YOUR TV. IT'S THE CONVERGENCE. YOU NEED REPLACE THE CONVERGENCE STK'S AND AFTER THAT YOU NEED DO ADJUSTMENTS.
Jan 14, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Proscan 5700 rear projection tv
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 06, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Back screen lights are out of sync
This projection TV is made up of 3 projectors R G and B (Red,Green,Blue) These colors mix to create the other colors all you have to do is both convergences
Nov 10, 2007 | Panasonic PT-47WX51 47" Rear Projection...
Color Fading
check your menu settings if not there then you may require board level service.or eprom sub menu adjustment.
Dec 02, 2006 | Panasonic PT-47WX42 47" Rear Projection...
Panasonic PT-47WX53 47" Rear Projection HDTV Logo
46 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
