Question about Hoshizaki Cubelet Ice MakerDispenser Water Cooled LED Sensor Operation
Water works fine - No Ice
I have 2 of the large Hoshizaki machines Model DCM-270BAH. One of them stopped making ice 5 days ago and now the other has quit. The water works fine on both. I just had a repair man in that replaced one of the small motors under the front panel of one machine but that hasnt fixed the problem. Any ideas?
    Sergeant:
  • 288 Answers
Does it sound like everything is running, only the machine isnt makinf ice? If so, there is a small triangular housing with a hose connected to the small motor on the left under the front panel. shut off the machine and remove the 3 screws on the triangular housing. inside there is a spring and a round rubber disk. take these items out and clean them. its amazing a tiny amount of debris will cause this to not work. install the reverse as you removed thewm, turn the power on.
Posted on Nov 06, 2007
I worked on a hoshizaki km-500mae when i turn it on the first cycle it makes good ice but after the first cycle it makes little pieces. why?
time the cycle. if it is only running about 5 minutes and going into harvest, look for sump loosing water. Look at where the unit drains (like a floor drain) while the unit is running to see how much, if any water is draining. does not take much to make an early harvest. also, sump may not be filling up completely but with just enough water to satisfy the float.
Feb 16, 2015 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki dcm 500 freezing up suction line
This calls for a tech that is familiar with this stuff. I have one a work and it runs great but I can't fix me. There several things it could be. Is it waking water anywhere. And does it run constantly.
Jan 28, 2013 | Hoshizaki Freezer Commercial Ice Machines...
Whirlpool refridgerator ice machine mod.ED2PHE water will not come into ice machine. it was working fine until 2 days ago.
check water line is open, check filter seated properly,make sure of on/off lever or switch or turn off water supply to fridge and check line for possible clog, and also on filter
Jan 24, 2013 | Whirlpool Refrigerators
Hoshizaki M# DCM-270BAH-OS runs for days then freezes up evap coil and stops water inlet to evap.
There is a thermostat probe sat on the front of the evaporator to tell the control board when to harvest. Check it is tight in it's holder. Check the condenser is absolutely clean and filters clear. You can adjust the thickness of the cube. set it on the thinnest setting and see if it harvests before freezing solid.
Jun 15, 2012 | Hoshizaki Freezer Commercial Ice Machines...
I have a model # f-450 mah ice machine. After the bin gets full of ice it stops making the ice but the water continues to run and runs out of the machine. Any ideas on how to stop this?
Sounds like the water valve is stuck. Probably needs replacing. Turn off water after machine shuts down and see if water stops. If it does, water valve is most likely the issue.
Mar 01, 2011 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki ice maker am-50bae . Made ice regularily--- filled ice bin half way...next day-- all ice melted away with no more new ice? next day shut off for 3 hours now o new ice.
make a few quick checks. If there are water filters on the system, be sure they are not restricked. Could be clogged. Next, check the bin stat. It usually is mounted in the ice bin. If it breaks or goes bad, it shuts down the machine. Start there and let me know if I can be of any further help.
May 19, 2010 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki ice machine makes ice but won't drain. Makes ice but won't drain properly, after about 3 or 4 days water starts leaking out of the machine onto the floor. Removed all ice and water and repeated...
My first question is, does the drain have a vent in it? If not, you may need to install one to be able to break the vacuum experienced when the unit flushes after a drop of ice. The vent will be a tee off the drain and a stand pipe that goes up about 5-10" vertical. My next question is has the drain in the plumbing (not the ice machine) been flushed, snaked or tested to see if it can handle the amount of water the ice maching dumps?
Jan 17, 2010 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki Cubelet Ice MakerDispenser Water Cooled LED Sensor Operation Logo
234 people viewed this question
Top Hoshizaki Kitchen Appliances - Others Experts
Dennis Boxerman
Marvin
Marvin
Kolbrun...
Are you a Hoshizaki Kitchen Appliances - Other Expert? Answer questions, earn points and help others
