Question about 2wire 2700HG-B Router (2700HGB)
Ext antenna for 2700 hg b router
I need to increase the power of the signal of my router 2wire and I would like to know is somebody knows how to do, seen that there is no "antenna in" in this router. what can I do?
regards
copyweb
  • 40 Answers
This model does have an antenna, it actually has three all internal. As long as it's not a UK version you can adjust the power output settings.
Log into your router settings usally you type:
http://home/managment - (I know management is spelt wrong)
In here you can adjust all manner of setting, including power output settings.
If it is a UK version, visit http://www.the-scream.co.uk/forums/t22658.html
This guy explains how you can upgrade the firmware of your router so you can change the power settings. Please read it through carefully however as it doesn't work on all models.
Hope this helps.
Posted on Jan 11, 2009
  • 192 Answers
Well you should contact the manufacsuer for the antina upgrade kit. ALso there is a kit where you canplug on eathernet corde into this adapter and plug it directly into the wall and plug the recivers that the around the parimater of the house.
Posted on Jan 09, 2009
How can I boost the signal of my AT&T 2WIRE router/modem?
You can increase the range of your router but you need to purchase another wireless switch. What you have to do is buy a wireless switch and grab a computer network cord and plug it into your 2wire modem. I would advise just turning your the 2wire's wireless off. If the new router isn't strong enough you can buy directional antenna's or larger antenna's which should help with the range issue.
Unfortunately you can't purchase an antenna that you can directly attach to the 2wire.
Make sure that the switch you buy has external antennas that you can change out. If not and the range isn't strong enough then it could cause more headaches down the road.
Apr 07, 2011 | 2wire (1000-400108-001) Router
How do I get my brother 1250 printer to print automatically? It used to print automatically when I clicked on Print but now I have to go into the ?Print Options and click on the Hold button twice before...
2wire lost password reset 2wire dsl modem sbc 2wire router modem unlock 2wire 2wire 1701 hg ... 2wire homeportal 2wire 2700 2wire can't get ip address .... default 2wire password 2wire modem att white paper 2wire gateway ip address .... usb 2wire hpna linux working for 2wire wrt350n and 2wire modem ...
groups.google.com/group/alt.languages.catalan/.../a1f780eac37721f2
The 2Wire HomePortal is a wired solution that offers subscribers hassle-free, ... Cisco-Linksys EtherFast Cable/DSL Router with 4-Port 10/100 Switch ... 5.0 out of 5 stars I could not ask for anything better than this., December 17, 2006 ... I waisted my money. My tech guy said it was an older generation unit, ...
www.amazon.com › Video GamesMac GamesHardware
Jul 20, 2010 | Brother HL 1250 Laser Printer
How to increase signal for 2Wire 2700?
Increase the WiFi power of your 2Wire 2700HG-B
If your 2700HG-B is one of the ex-SBC/AT&T refurbs that are available from Caneris, eBay, etc. and it is on firmware v4.25.19, then you can easily increase wireless power levels from 1 to 10 using the Management and Diagnostic Console. According to Wireless Power levels, power level 1 is ~25mW, 4 is ~100mW and 10 is ~400mW. (Other variants of the 2700HG may only go from 1 to 4 but the link shows how you may be able to hack the power setting to higher levels.)
1. MDC -> Local Network – Wireless Settings -> Additional Settings -> Power Setting
2. Physical orientation.
New 2Wire 2700HGs come with a bracket that orients them in a vertical position. Presumably 2Wire designed the 2700 series to work best that way. The 2700s have two antennas but they are inside the box and cannot be reoriented like the external antennas on most other WiFi routers.
My refurb didn't come with the bracket so like most people I set up mine horizontally. But I kept wondering if orientation matters.
Well it sure does. Changing to vertical orientation increased the power level as reported on my remote PC from "Good" to "Excellent." The remote PC is a couple of floors above the 2700HG. It is possible this increase will not be as pronounced if your remote PC is located horizontally away from the 2700HG.
It is very easy to make a bracket. I used the plastic screw-on cap from a 1kg jar of peanut butter. With a hacksaw (what an appropriate name, eh? wink.gif) I cut a 1¼" slot like so.
If you are not into peanut butter I imagine you can find a plastic lid or similar, about 4" in diameter, to use instead.
Anyway, with about 10 minutes of work you can quadruple the output power of your 2700HG and more than double the signal strength.
P.S. Yes, I realize I am using WEP encryption and that it is not very secure. One of my remote PCs only has 802.11b with only WEP support. I am not particularly concerned. Several of my neighbours have their WiFi APs wide open. One even has the file systems of his PCs completely exposed to the world. They are an easier target than me
Mar 22, 2010 | Computers & Internet
How to connect 2wire 2700 HG-B router to voice modem motorola
that 2wire only works with DSL services, if you are using cable internet then no it wont work. If the surfboard digital voice is just a VOIP router then yes, plug the surfboard into one of the ethernet ports on the back of the 2wire.
Jun 06, 2009 | 2wire 2700HG-B Router (2700HGB)
Unable to connect 2 routers need help!
Do you have any funky subnets for your Cisco router? Do not connect the wireless router to your network yet, as it may have the same IP address as your other router.
Basically the easiest way to do this is to set a dedicated IP for the 2Wire router on the Cisoo router. Then make them stay on the same subnet, but give an IP range for your Cisco router, like 1-50 or something. If you give the 2Wire router IP .51 for instance, then give the Wifi users on the 2Wire IP range from .52-75 or something.
Make the 2Wire router only use wifi and not serve DHCP addresses. Then you setup the 2Wire router to get its info from the Cisco router.
I searched and there is no howto out there for doing this with a Cisco router. However, here is one I used to setup a similar scenario with a Netgear router. It worked. If you are able to translate a bit, it might work for you:
http://kbserver.netgear.com/inquira/default.asp?ui_mode=answer&prior_transaction_id=306896&action_code=5&highlight_info=16778323,235,239&turl=http%3A%2F%2Fkbserver.netgear.com%2Fkb_web_files%2Fn101236.asp&answer_id=6056802#__highlight
Here is another article:
http://kbserver.netgear.com/inquira/default.asp?ui_mode=answer&prior_transaction_id=306896&action_code=5&highlight_info=16777285,246,260&turl=http%3A%2F%2Fkbserver.netgear.com%2Fkb_web_files%2FN101496.asp&answer_id=6056800#__highlight
Let me know if you are able to work through this. You need to give the 2wire router a static IP and you need to NOT use it for wired connections, and not use it to serve DHCP settings.
Jan 21, 2009 | 2wire 2700HG-B Router (2700HGB)
2Wire 2700HG-B router: what MODE? VG or mixed? or G mode?
Here is a link to your user guide: http://www.2wire.com/pages/pdfs/5100-000326-000.Rev.A.pdf
See page 26 (page 31 of the pdf file) - it will help you find which mode your router is set in.
Hope that helps :)
Dec 18, 2008 | 2wire 2700HG-B Router (2700HGB)
2 wire 2700 hg-b
The 2Wire 2700 is a residential gateway, a modem and router in-one. There is an RJ-11 jack in the back of the gateway and this is where your dsl phone cord plugs in. There are four RJ-45 jacks in the back for connecting devices using ethernet cable. As a router is can operate both wirelessly and wired. For wireless operation you'll need the WEP key which is located on the tag on the bottom of the gateway. It's the number enclosed in brackets, between the two bar codes.
Redneck Geek
Sep 09, 2008 | 2wire 2700HG-B Router (2700HGB)
2wire 2700 HG-B
Does it turn on at all?, if so what color is it?
Jul 19, 2008 | 2wire 2700HG-B Router (2700HGB)
ATT 2wire 2701 HG-DSL lite on, but bad connection
If you have a 2wire HG2701 it experiences problems. You will need a new modem or a new router. I have one but it has the same problems. I went to FRYS Electronics and bought an speedstream modem. WORKS PERFECTLY
Feb 19, 2008 | 2wire 2700HG-B Router (2700HGB)
D-Link AirPlus G DWL-G710 WIRELESS EXTENDER
the IP address must be different on the router & extender but use the same subnet mast. The extender has to have the gateway set as the IP address on the router.
Sep 16, 2007 | D-Link AirPlus G Wireless Range Extender...
2wire 2700HG-B Router (2700HGB) Logo
493 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
